BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > AUSTRALIA > First Servive, NO oil change!!!
Studio RSR
      01-23-2014, 11:54 PM   #1
djw007
Drives: F30 M Sport 335i
Hi everyone,
Just had my first service done, 2 months overdue in fact and approx 14,800kms on the car. The car is 15 months old now.
To my amazement they did not do an oil change even though the car was overdue for it's first service and the display was telling me to take it in.
They said it wasn't ready for an oil change and BMW won't let them do it.
I had a quiet chat to the authorised BMW mechanic on the side and he freely admitted to me that BMW are cutting corners on the oil and that they have a vested interest in our engines not lasting forever..read in to that what you will.
He also assured me that his own BMW gets the oil changed every 6 months, and he would not leave oil in a new car for over a year and 15k and beyond as is my case.
I now have no idea when i am supposed to change my oil...
      01-24-2014, 12:42 AM   #2
SteveAus
SteveAus's Avatar
Australia
266
Drives: G20 M340iX
I hear you. Like butter or cream..........if you leave oil too long it will go off.
For the reason you quoted, I was somewhat reluctant in taking the BMW 5 year service deal. I did in fact take up this deal to cover the various other filters that will require replacement.
I was told that you could not change the oil when you wanted without the reset button being activated on the car. But with further investigation, and chatting with my BMW service manager, it appears that you can change your oil at any time (but the oil change would be at your cost if the car did not indicate that it was necessary), however, if you pay for just an oil change you must insist that the service engineer does not reset the oil change period on the car. This is something my dealer has told me can be arranged. He mentioned that this is an Australia-wide agreement.
The oil change period on the car is governed by distance covered and also by time.
This means that over a 5 year period, if you have the oil changed once a year, BMW will likely pay for 2 oil changes and you would have to pay for the other 3 within this 5 year period. This is something I am prepared to live with for my own peace of mind.
G20 M340iX, Sunset Orange, Tartufo Merino Leather, Pretty Well Loaded, OEM Aero Kit, Drive Recorder, BlackVue Dashcams removed and replaced with ACE 2.0.
      01-24-2014, 04:58 AM   #3
David328M-Sport
Australia
101
Originally Posted by djw007 View Post
Hi everyone,
Wow!! Really? No oil change? Seriously?
Sorry, only joking. Fully synthetic oil is supposed to last at least 20k kms, maybe 25k. Nothing to fret about, nothing to get excited about and certainly nothing to concern yourself about what the mechanic had to say. Does his BMW use 100% fully synthetic oil?
I call it absolute rubbish about what the mechanic said, but which engine lasts 'forever'? Then again, when have your read about BMW engines failing because the oil wasn't changed often enough? If things like that were true, it would be common knowledge about BMW engines not lasting as one would reasonably expect. BMW's heritage is built on engines.
This issue has been discussed on pretty much every car forum for years. Some say change the oils every 5000kms, 7.5k kms, 10k kms etc. Others will leave the oil and change it when scheduled. The choice is yours and yours alone. Whatever makes you feel most comfortable about your car.
If BMW service won't change your oil, you can do it yourself (don't forget the filter) or ask an independent to do it. They will most certainly oblige.
Now if you do have the oil changed and they show you how black it is and you then post a photo on this thread to show us how black it is, being black does not mean anything as to the state of the oil. It would need to be analysed and even then the results may be inconclusive unless you tear down the engine to see if there was engine damaged caused by the oil.
In fact, I have read on this site that one owner had the oil analysed and very fine metallic particles were found in the original oil. Didn't cause engine damage. Maybe it might if left long enough, maybe not. No one knows.
I have let the SSI tell me when to change the oil in my cars. I've had BMWs since 1992 without engine oil related issues. My current car's just over 10k kms and I'm not anywhere close to having to change the oil over. My previous car, E90 325i had its first engine oil change at around 20k kms. Issue free.
You choose. No right or wrong in this instance.
Cheers
328i M-Sport, Estoril Blue, Carbon XP 35 Tint, front heated seats, black Dakota, Sports Suspension, Anthracite Headliner, HUD, Pro Nav, Sunroof, hk 600w, Bi-Xenon, 19" 403M wheels, Reversing Camera, DAB+, Xenon, BT Ext Connect, MST turbo intake pipe, MST Cold Air Intake, JB4 on Map 2 with Catless DP produces awesome performance in Sport.
      01-24-2014, 06:38 AM   #4
Sherweeeny
yep
Sherweeeny's Avatar
Australia
111
Drives: 340i
Wouldn't it potentially affect parts like oil pump etc David?
      01-24-2014, 03:04 PM   #5
David328M-Sport
Australia
101
Potentially, anything can happen, yes. However, has there ever been such a widespread BMW issue with engine oil and directly related engine damage in modern day models? I haven't read anything about it. Have you?
Sure, we've read about other widespread (some fairly serious) issues with the F30, but nothing with engine oil. My previous E90 used BMW branded Longlife (LL) oil as did my E46 and E36. BMW call it High Performance LL-01. There are a couple of other BMW LL oils such as LL-04 for low sulphur fuels as well. As they have been doing for a long time, BMW recommend Castrol oil.
Personally, I don't see it as anything to be at all concerned about if you car has been using the LL oil or equivalent.
http://www.tds.castrol.com.au/pdf/10...205W-30%20.pdf
      01-24-2014, 04:26 PM   #6
Sherweeeny
yep
Sherweeeny's Avatar
Australia
111
Drives: 340i
David, whilst I agree that for the masses it could be okay, I personally was unable to have my car serviced until close to 30000kms (another story altogether) and have now been driving a loaner for the last month, waiting for BMW to approve and ship out a new oil pump on a 30000km car.
      01-25-2014, 10:49 AM   #7
digitallust
digitallust's Avatar
Australia
99
Drives: 2019 G20 BMW 330i M-Sport
so when you say no oil change, my 320d is showing 1,800km until its service is due, it is also showing 1,800km until Oil change. They would have to change the oil at my service if the car is saying so, would they not?
__________________________________________________
On Order - 2022 BMW i4 eDrive40 M Sport Mineral White, Fully Optioned
Current - 2019 BMW G20 330i M Sport Alpine White
Retired - 2018 - Range Rover Velar SE D240
Retired - 2015 - Mercedes Benz C250d AMG Line W205
      01-25-2014, 11:47 AM   #8
pennektj
Drives: 2013 328xi
Yes... If the car calls for it they will do it. The dealership wants to change your oil but can't bill bmw unless the car is due. If not the dealership could change your oil every 1000 miles and keep billing bmw.
      01-25-2014, 03:51 PM   #9
GAV-F30
GAV-F30's Avatar
Australia
Drives: 2013 BMW 328I M-SPORT
Anyway I prefer to change every 10,000 with MOTUL 8100 X-MAX ll01 or ELF not to sure yet
      01-28-2014, 06:33 PM   #10
Sephanite
Drives: BMW Z4
Do a service yourself if it makes you feel at ease. I know i did one at 40k before my 50k service. I think 15k km is the max i would use an oil before changing
      01-29-2014, 05:36 AM   #11
djw007
Found the "change oil" timer. It says in another 9000kms. So that'll make it at approx 24000kms..
      01-29-2014, 05:44 AM   #12
focal
Drives: 328i 6MT w/ MPS & MPE
I personally do a mid cycle oil change for my past bmw's. For the f30 that will mean every 12500Km. Question will be if you don't use the same LL oil would it even last another 12500 until the dealer changes it.
My independent mechanic uses ELF synthetic usually.
      01-31-2014, 06:00 PM   #13
Sephanite
Drives: BMW Z4
http://www.epicinter.net/some-people...automobiles/1/
      01-31-2014, 07:23 PM   #14
SteveAus
SteveAus's Avatar
Australia
266
Drives: G20 M340iX
Originally Posted by Sephanite View Post
The photos in the link are truely sickening!
Although I didn't need convincing, I will certainly continue my regime of doing oil changes regularly when I want to do them, regardless of when BMW tell me I need to do them.
The relatively small cost for an oil change for my own peace of mind is well worth it in my opinion.
BTW, read the article in the link about the Audi guy porting and polishing his engine with blasting sand - what a total moron!!
      01-31-2014, 08:13 PM   #15
MikeVictor
Australia
210
Drives: anything given a chance
Same here. I tend to change oil about every 8000km, which is about 6 months use for me.
      01-31-2014, 08:18 PM   #16
Sephanite
Drives: BMW Z4
Lol yea I remember that post in the audi forum
      02-05-2014, 06:32 AM   #17
David328M-Sport
Australia
101
Update on engine oil in F3X cars. I spoke with Andrew from Southern BM and he suggested once a year oil & oil filter change. Too long an interval certainly caused engine problems on older cars.
Apparently, BMW have reduced the duration of oil services for more recent build F3X cars and states that BMW may be worried about too long an oil change service interval having a negative effect on the cars.
I believe it's more to do with customer backlash and owners having more frequent oil changes regardless of the SII time frame.
So, I'm considering taking my car to SBM to have an oil & oil filter change, contrary to my initial post. They charge just $295.00.
      02-05-2014, 11:17 PM   #18
GAV-F30
GAV-F30's Avatar
Australia
If you lived in Sydney, Ill do it for you for a six pack $295......... MY GOD
      02-06-2014, 02:09 AM   #19
David328M-Sport
Australia
101
How much is the oil & filter?
How do you dispose of the old oil?
      02-06-2014, 04:00 AM   #20
rjr058
Drives: F30
Filter is about $20, 5 litres of Castrol synthetic oil about $70 (BMW Castrol is $30 per litre). An independent BMW would charge about $160 for oil and filter change.
      02-06-2014, 04:09 AM   #21
GAV-F30
GAV-F30's Avatar
Australia
For my E90 filter was $20 oil I used Mobil 1 was around $70 to $80, My F30 is still around 1400kms so no oil change, will get MOTUL 8100 X-MAX
Old oil and filter I give to my mechanic friend.
      02-06-2014, 01:42 PM   #22
David328M-Sport
Australia
101
It's my independent who wants $295.00.
He uses LL-01 oil, which will up the price.
Is your filter BMW branded?
I'm asking another independent for a quote.
Thanks
