05-13-2015, 10:21 AM | #1 |
Rep 396
Drives: 2014 335i M Sport, 2004 .:R32T
Tire Pressure for 19's
Hey everyone I recently just purchased a set of AG M590 wheels for my F30 M Sport. I got them in 19x8.5 et35 and 19x9.5 et43 with 245/35 and 275/30 tires. My question is what tire pressure should I inflate the setup too. I was never too knowledgeable in deciding on a tire pressure. Any help is appreciated. Thanks
05-13-2015, 10:56 AM | #2 | |
Rep 3,947
05-13-2015, 10:56 AM | #3 |
208
Rep 1,161
Start with 36 psi and adjust from there: if your car is understeering in hard cornering, you can let a few pounds out of the front, if it's oversteering, let a few pounds out of the back. Remember that your TPMS monitoring system will warn you if you have a big differential between individual tires.
05-13-2015, 11:07 AM | #4 | |
Rep 3,947
05-13-2015, 04:53 PM | #5 | |
National Championship #17 and Counting!
793
Rep 1,508
Start with the BMW recommendations, which won't be perfect, but a start. Those 275 in the rear likely need 36psi, the front, 34psi would be my start. If your ride is too stiff, drop 1 psi. Also, hope you have a digital tire gauge. If not, Amazon is a great place to buy one. I use Accutire. Think my good ones were $12-$15 each and light up.
2018 i3s - Melbourne Red, Tera World, Ceramic Film all windows
Packs: Technology, Driver Assistance, HK Audio, Park Distance Control |
05-13-2015, 07:01 PM | #6 | |||
Rep 396
Eric you're saying start off at 36 psi all around? Rolltide32 why do you say the rear will likely need 36psi? Just trying to understand tire pressures not only for my BMW but also in general. Thanks guys for the help! |
05-14-2015, 05:13 PM | #7 | |
793
Rep 1,508
45 psi in any car is likely too high. This high psi actually made your tires more susceptible to pothole damage. high psi means stiff, stiff = hard and less forgiving. For winter tires, I'd likely just go with 33-35psi |
05-14-2015, 08:43 PM | #8 | |
Rep 1,134
05-26-2015, 10:14 AM | #9 | |
Rep 396
http://f30.bimmerpost.com/forums/sho....php?t=1131293 |
