04-13-2015, 07:15 PM | #1 |
Rep 61
Wheel spacers for "19 rims recommendation?
Hi guys, am running these dimension on my wheel tire combo and I was wondering if I can add some wheel spacers for them.
Front - 245x35x19 Rear - 275x30x19 What wheel spacers can I add? |
04-13-2015, 07:54 PM | #2 |
Rep 713
You are going to have to provide wheels specs in addition to the tire specs you listed if you want some input.
04-13-2015, 08:08 PM | #3 | |
Rep 1,035
If you are lowered, you might have to consider with your tire/wheel poking that much further outward, if you are going to rub the top of your tires to the bottom edge of the fender. If you are not lowered, then no worries. |
04-13-2015, 10:16 PM | #4 | |
Rep 61
04-15-2015, 09:16 PM | #5 | |
Rep 1,035
If however you are wanting new wheels and need to know what new offsets to get and what will fit, then you'll need to know your current specs/offsets. Good luck bro! ...and welcome to the madhouse |
04-16-2015, 09:24 AM | #6 |
Rep 713
Well I wouldn't say that telling us the specs are irrelevant as the OP is asking for a quick answer. If he wants an answer from us rather than determine it himself as you pointed out (which will give the most appropriate answer) then more details such as his offsets are needed.
VMR V703 have a wide range of offsets for those wheels sizes ranging from ET20 to ET45 and likely you may not need spacers. Do what squidlyboy says or find out what the ET is (should be stamped on the inner wheel rim) or worst case, take a picture to show what how much space you have left. Otherwise, you won't get the answer you are looking for.
