04-14-2024, 11:36 AM | #13069 |
Rep 207
Drives: bmw 428xi
What's the latest software available for EW NBT_04x?
I have the 1.6.16_n installed. Seeing if theres any performance or new features out. |
04-14-2024, 01:58 PM | #13070 | |
Rep 3
Today I discovered that Waze gives the directions if I am listening to Spotify, while if I use Apple Maps or Google Maps I hear them regardless of the sound source. I guess it's a firmware problem because I've tried it in another car with a mmi from mr12volt and it works perfectly. |
04-14-2024, 04:49 PM | #13071 |
Rep 156
04-14-2024, 07:08 PM | #13072 |
Rep 5
Need a help
Hi, everybody!
I really need your help. I bought a car with CarPlay already installed. Everything was fine before, but now the device has completely stopped seeing my phone, the Bluetooth icon is displayed, but there is no CarPlay icon and it won't open it. I have done everything as per the instructions several times (connected my phone to my BMW head device via Bluetooth, then connected it to CarPlay via Bluetooth) but no result. Most likely the problem is in the firmware. I would also like to resolve a problem with the sound: when I connected my phone to CarPlay, it would switch to it from the internal car Bluetooth and the music would stop playing until I manually on the phone to bring playback back through the car Bluetooth again. Is there any way to make the music play on the car Bluetooth and CarPlay at the same time? I'm sure it's the firmware and I'd like to update to the latest version, but I'm afraid of turning my device into a "brick". So I am very much looking forward to your help and advice. I attach a photo of my version (I have NBT). Thanks in advance! |
04-15-2024, 07:45 AM | #13073 | |
Rep 3
04-15-2024, 12:11 PM | #13074 | |
Rep 34
For my opinion, the youtube app is useless. Airplay could be related,that for your device, the firmware has issues but i donīt know. Get in touch with your reseller to get the last version. As far as i know the last versions for Andream/RoadTop devices: Andream 1.6.16R2 Roadtop XX176R2 (XX is the placeholer for the model) |
fe7565552.50 |
04-15-2024, 10:29 PM | #13075 |
Rep 1,584
That is weird. Wonder if this is some sort of a hacked version. Which could be ok, if they do their own feature improvements (programming).
04-15-2024, 11:51 PM | #13076 | |
Rep 1,584
Anything you do is at your own risk! I would first unpair and delete all Bluetooth pairings from the MMI and the car and your phone(s). Then re-pair them all again. Make sure if you use iPhone that under your Bluetooth settings for the CarPLay for device you select "car stereo". Looks like your unit is: RoadTop B2-Version [1] [NBT] Is your pin code 8032? You could also try to re-install the 152 code. The first page of this thread should have the file and the information on how to update it properly. If you are willing to risk on your own to try to update to the latest firmware version 176, and you are sure it's a Road Top NBT then use the ISPBOOT.bin file (do not use GEMINI.bin) from here: https://mega.nz/file/h95hiBbY#eumC9o...mlrgGyOlxYigcs The car should be running during the update, or at least with ignition ON without a chance of the HU/car going to sleep (turn headlight-switch to "parking" and buckle in seat belt). It may take 2-3 minutes. Do not interrupt, better to wait a few minutes more than to take a chance. It may take a couple of tries. But since you are going from a very old 152 version to 176, there are some increased risks. Also, your MCU version may need to be updated, but best not to mess with that at the same time as the CUST Version. Again, do it at your own risk! I had my MMI once near bricked when I did this same upgrade and was lucky to have it worked on the second try. The bonus with the 176 firmware is that you will have an option to use full Bluetooth audio instead of AUX-IN. Read the posts about that in this forum.
0taman1.50 |
04-16-2024, 06:35 PM | #13077 |
Rep 549
Hello everyone! I know this is tue F30 forums but it has the most interaction on this topic so I hope y'all dont mind me posting here.
Just inherited my dad’s mint 2010 e60 535 with CIC. I love it but it has no option for streaming audio. Bluetooth only allows for phone calls. I am interested in either the Andream or Bimmertech MMI box for use with Android Auto. Just had a few questions: If I understand it correctly, the units are essentially the same correct? Any go with one unti and wish they chose the other? Are the harnesses for all CIC units the same? A forum member has a Bimmertech MMI prime unit that bought for his e70 X5 with hifi for sale. Will that plug and play into the e60 (also hifi)? I assume it would since Andream doesn’t seem to differentiate between CIC but Bimmertech said the harnesses are not the same (but they also want to charge me $300 for the cable) Last edited by ryansbmw; 04-16-2024 at 07:11 PM.. |
04-16-2024, 08:39 PM | #13078 | |
Rep 1,584
In the beginning all the MMI units by Andream, Road Top, etc. and Bimmertech were the same. There may be some different chips inside by now, may be better quality, but the basic functions are the same. Bimmertech has the advantage that they hold your hand in installing, etc and they may have added better audio features. But it comes at a cost that is 2-3 times of the others. You have to decide how much support you need. The Andream is about $260-280 and Road Top is about $220-240. Both have US warehouses to ship from and both respond well to follow up assistance. Both provide firmware updates to original buyers. Confirm with them what HU you have and what unit you need. Some CIC units come with 4+2 LVDS (6-pin) plugs, while others have a separate 4 pin and a 2 pin (power/gnd) cable. Yours is probably the 4 pin and separate 2 pin since its older, but worth to look. The harness for all the NBT units are the same ( do not know Bimmertech). The CIC units probably also are the same (not with the NBT), but they have extra mic cables. The latest CIC MMI from Road Top and I think Andream also (confrim with them) does full Bluetooth audio instead of using the AUX-IN. In most cases that provides better audio quality.
chuckles01188.50 |
04-17-2024, 12:46 PM | #13079 | |
Rep 5
fe7565552.50 |
04-17-2024, 03:37 PM | #13080 | |
Rep 1,584
04-18-2024, 12:25 PM | #13081 |
Rep 3
Hallo Firefly1337 , ich habe mittlerweile sehr viele Posts von dir durchgelesen auf Bimmerpost über das Andream Head Unit und den updates. Meine Version ist
MCU: 415199BT-HW7-210416(B1280) Ich habe folgendes Produkt im Jahr 2021 gekauft: https://www.android-car-dvd.de/colle...-f21-2013-2017 Ich kann seit langem kein handy mehr automatisch verbinden und teilweise freezet der Bildschirm. Da du so viele threads über updates gepostet hast, wollte ich dich fragen und bitten ob du die neuste updateversion mir schicken könntest und vielleicht kurz sagen könntest wie ich das update anschließend durchführe. Ich wäre dir so unendlich dankbar, da mir der Andream support nicht helfen will mit Updates. Danke und dein f20 ist echt schick!!! |
04-18-2024, 12:33 PM | #13082 |
Rep 3
Hello everyone, Im new here!
I have a head unit for apple carplay from andream: https://www.android-car-dvd.de/colle...-f21-2013-2017 MCU: 415199BT-HW7-210416(B1280) Does anybode know the newest software update? Because I have some issues with mine from 2021. Also would be nice how to install the software. Thank you very much!!! |
04-19-2024, 08:56 PM | #13083 |
Rep 466
I am really hoping someone can help me before I completely lose my mind.
2016 F85. I bought an MMI box from eBay, it looks just like any other MMI with the added harness, bluetooth antenna, USB connector etc. At first I had an Android phone so set it up to use AA. I programmed the radio preset 8 to be the Aux in as it says to do in the instructions and connected the harness and optical cable as per the instructions. I tucked everything away and also tucked away the BT antenna and the USB port (didn't use it). So my issues are : AA is sporadic. Most of the time Spotify works but then for no apparent reason at all it just doesn't. The only thing that seems to fix it is to turn the car off and on again - hardly ideal on the highway :-) Also, the phone.....this is the part that is driving me insane. Almost every time someone calls me they can hear me but I can't hear them. If I dial out it is the same problem, they can hear me but I can't hear them. Here's the really bizarre part......if I just use the phone as a normal phone handset when this happens the phone is somehow posessed and won't dial out at all.....as if the MMI has control of it. So then my Android reached the end of it's life so I bought an iPhone 12. Went to use Carplay and everything worked as it should.....once. Now the iPhone is doing exactly the same as the Android did. Spotify works most of the time but the phone functions might just as well not be there. Tonight I tried to use the maps and get directions - the carplay voice control didn't appear to work so I switched over to the BMW OEM and tried voice control - it clearly couldn't "hear" me. When I went back to Carplay the maps were open with the directions for the destination !!! This thing is so random and I do not do random with tech. It either works or it doesn't - this has a mind of it's own....and mostly doesn't work. Lastly, when any of this is happening I can't even use the in car (BMW OEM) BT phone option. It's as if the MMI somehow has control. Does anyone please have any suggestions before I give up and rip this POS out ? Like I said, the Spotify works most of the time but the phone....it's so unreliable that I can't use it. I asked the seller on ebay and they said - try plugging it into the USB port....very helpful, what is the point of having BT then ? Thanks in advance and sorry for the rant - it's infuriating me.
2008 E88 N54 135i / Cashmere Silver / Beige leather / VRSF catless DP's / BMW Performance Suspension / Whiteline inserts / Aluminum charge pipe and aftermarket BOV |
04-19-2024, 09:15 PM | #13084 | |
Rep 1,584
04-20-2024, 03:36 AM | #13085 | |
Rep 47
Before connecting Airplay, you need to disconnect carpaly's Bluetooth and Wi-Fi connections. Even then, you need to try many times before you can connect it normally. Because the IOS system has updated some programs, we are also changing our software for Adapted to IOS17 and later systems. |
haikf200.00 |
04-20-2024, 04:29 AM | #13086 | |
Rep 3
https://www.android-car-dvd.de/colle...32-f33-f36-f80 That would be very helpful for my device. Thank a lot!!! |
04-22-2024, 10:05 PM | #13087 | |
Rep 8
Thank you? Last edited by usta83; 04-22-2024 at 10:20 PM.. |
04-22-2024, 11:01 PM | #13088 | |
Rep 1,584
https://f30.bimmerpost.com/forums/sh...ostcount=12893
04-24-2024, 06:40 AM | #13090 |
Rep 123
Drives: 2016 M235i 6-Speed Convertible
rebooting 2021 BMW_NBT2_1_G box - what to do?
Hi all!
I haven't posted here since 2022. I have this box which I bought from a aliexpress seller in 2021. I have since forgotten everything I knew on this topic LOL: MCU Version 21.6.7.116 CUST Version v3.6.0.2.ly.b2 HW Version BMW_NBT2_1_G I was never able to get any support out of the seller, but I did get [the current] firmware from another supplier that seemed to help. I'm having frequent disconnects and warm [never full/cold] reboots. No idea if it is hardware, installation, firmware, or some combination. Any advice? is there newer firmware I can get from anyone (I cant get it from seller). At this point, I'm considering "starting over" with a new box if there is a cheap one that is better, and can still use my cheap aftermarket front and rear cameras I added to this box. Advice/help appreciated. Dave Last edited by AbnormallyAspirated; 04-24-2024 at 11:57 AM.. |
andream, android, android auto, apple, carplay, mmi, retrofit |
