12-07-2023, 03:43 PM | #1 |
Rep 467
NBT_EVO Touchscreen Functionality
RE: KERN417 DIY video to code on touchscreen functionality for NBT_EVO.
https://www.youtube.com/watch?v=bYLxBCGHKC4 I have a 2017 340i with MFG date 11/2016 upgraded from iDrive 5 to iDrive 6 software a couple years ago with a base map and forever FSC code installed. Performed the coding as instructed with Protool instead of Bimmercode: HeadUnit HU_NBT_EVO -3005 DISPLAY_PIP_CONFIG CID_TOUCH > aktiv -300B TOUCH_COMMAND CID_HMI_TOUCH > aktiv Still isn't working. Is there something additional that needs to be coded or is my headunit not compatible? |
12-07-2023, 03:52 PM | #3 |
Rep 801
i thought touchscreen didn’t come out until 2018? if your car was mfg 2016, it probably does not have touch and coding is pointless as the screen doesn’t know what touch is.
12-07-2023, 03:53 PM | #4 |
Rep 149
These are the settings for the touch screen:
CID_DISPLAY_RES => 1280_480 CID_DISPLAY_SIZE => 8_8 Display_VARIANTE => breites_display DISPLAY_SIZE_RESOLUTION => 8.8_1280x480 CID_HMI_TOUCH => aktiv CID_TOUCH => aktiv The you need the touch svreen itself |
12-07-2023, 03:55 PM | #5 |
Rep 467
12-07-2023, 03:56 PM | #6 |
Rep 467
I'll take a look at those additional settings. TY
12-07-2023, 04:03 PM | #7 |
Rep 1,824
Kern's 440i is a 2018, and one thing Kern should've really mentioned in that video is that only 2018 model cars have the touch screen CID, I wouldn't be surprised if some late model 2017 cars have it as well, but as you said Runner340 you have a 2016 manufactured date car, so there's no way your CID is touch screen.
if the OEM screen wasn't programmed from factory to idrive 6, theres a 99.9% chance the screen isnt touch screen. my 2017 340i had a non touch screen idrive 5 NBT EVO screen.
Runner340368.50 |
12-07-2023, 05:07 PM | #9 | |
Rep 529
CID_TOUCH => aktiv Just this two are for touch screen all other are same on non and touch
Successfully retrofit on BMW F30 335xi 248,302,3AG,430,5AG,5AS,6NS,8TH and IHKA3
12-07-2023, 05:10 PM | #10 | |
Rep 467
toxik2460.50 |
12-09-2023, 07:47 AM | #11 |
Rep 228
Drives: 2022 G20 330E
just for the add, most EVO ID4 units will not support APIX2 (actual EVO ID5/6 screen), even after flashing it to ID5/6, it lacks hardware for that, so you can forget about touch screen there.
| MGU Patching/Virginizing | ConnectedDrive activation for US cars in EU (Only MGU/ATM2) | Feature Installer codes | Map Updates | CarPlay activations. | NBT EVO GPS Connector installs. | NBT EVO repairs | Remote BMW Coding |
04-18-2024, 05:13 AM | #12 |
LOADING...
Rep 30
Old threat but hopefully someone will see it. I flashed my NBT EVO ID4 to ID6 (N55 2016/05 MY) my CID is not touch version, want to buy a touch screen but before that how can I be sure if my HU support APIX2 or not? When I installed wifi antenna I took a few pics back of HU, can you check and understand from that pics if it's compatible or not?
04-18-2024, 04:53 PM | #14 |
LOADING...
Rep 30
