05-30-2017, 11:05 AM | #1 |
Rep 194
F32 LCI Taillights Installed on ALPINA
Finally installed the F32 LCI taillights on my B4.
I believe you have already seen some similar reports posted in this forum, but let me also share my experience just for your reference. < BMW PART NUMBER - EU VERSION > 63217426055 - Rear light in the side panel, left 63217426056 - Rear light in the side panel, right 63217426051 - Rear light in trunk lid, left 63217426052 - Rear light in trunk lid, right < RETROFITTING > The outer lights are literally plug ’n play. No need to swap the connector pins like F30/F31. As for the inner lights, you need to use a retrofit harness to convert the connectors and to add extra signal lines for blinkers. < HARNESS FOR INNER LIGHTS > At first I was thinking about making a retrofit harness for myself, but I decided to use the harness from alpina-527 to save time. Anyway it worked flawlessly. < INSTALLING THE HARNESS > Route and secure the cable from left inner light to the existing harness, then pull the loom end into REM control unit near the battery in the trunk. < CONNECTING TO REM > Disconnect the connector A174*13B from REM and insert the terminal pins of new cables into the pin sockets as follows; - Cable from the left light to PIN No.5 - Cable from the right light to PIN No.13 < RETROFIT CODING > Next up is… coding! I added HO-wort HELC (=LCI_REAR_LIGHT) and VO coded the REM to have it transmit indicator signal/power to inner blinkers over new retrofit cables. I think this way is a lot sexier than tapping the power from outer blinkers. Very easy, isn’t it? It just took about one hour to get everything done. ENJOY THE VIDEO!
[ Present ] 2021 BMW M850i xDrive Coupe (G15) [ Retired ] 2014 ALPINA B4 BiTurbo Coupe (F32) |
05-30-2017, 12:04 PM | #2 |
Rep 343
Drives: 2018 M4 SMB 6MT
EU version so the blinker is orange, right?
alpina-527 sell the harness? |
05-30-2017, 12:19 PM | #3 |
Rep 194
Yes and yes.
05-31-2017, 11:21 AM | #5 |
Fool
1857
Rep 3,542
I never knew the license plate lights dimmed when the car was in reverse. It makes perfect sense, reduces the glare from them in the camera but that's a new one on me!
Billybmw20200.00 AndrewC198910931.00 |
06-01-2017, 01:34 AM | #6 |
Rep 194
Your harness is nicely made. Thanks!
06-01-2017, 01:51 AM | #7 | |
Rep 194
This is an aftermarket license plate LED but it's only available in Japan AFAIK. Another option is coding. Please try the method below I posted in another forum. Bimmerfest - Licence plate light brightness when backing up Cheers,
06-01-2017, 08:46 AM | #8 |
@obriennathaniel_f30 on Instagram
515
Rep 1,063
Drives: 582whp/596wtq '13 335i
is the blinker different than a 3 series? yours seems to flow with the lines, while the 3 series is a fixed angle.
CG Precision VS-1 Exhaust\DR-1 DownPipe | PS2 Turbo\Inlet | PDU PI w/Fuel-it platinum kit & E sensor | GFB DV+ Diverter Valve | BM3 w/AIC2-V|Tune CaryTheLabelGuy | Full E85 | ATM FMIC | ER Chargepipe Inlet/Outlet | AFE Intake | BC Coilovers | PSS 255/40-275/35 Velos Designwerks S3 two piece 19x9/19x10 | Osram Xenarc | LED retro | AWRON digital AC gauge| |
06-01-2017, 03:02 PM | #9 |
Rep 194
Yes, the 4er has a different shape. The 3er's blinker draws a straight line.
06-05-2017, 09:11 AM | #11 |
Rep 194
It depends. Will be 1.2-1.5K USD.
06-08-2017, 09:05 AM | #13 |
Rep 5,897
Drives: 2014 335i Black F30 M Sport
Very nice!
07-08-2017, 01:15 PM | #14 |
Rep 33
Drives: 2016 F36 428i
Sorry this is probably a dumb question, but which is pin #5 and #13? I'm not familiar with the numbering convention on these connectors. Thanks.
07-10-2017, 09:40 AM | #15 | |
Rep 194
You can figure out the numbering when you disassemble the connector.
anguyen5845.50 |
07-10-2017, 11:00 AM | #16 | |
Rep 54
2015 328i M-Sport - Wagner FMIC, ER Charge Pipes, JB4, Injen CAI, Wagner DP, M-Performance spoiler, M-Performance LED Tail Lights, H&R sport springs, Bilstein Shocks, M-Perfomance Exhaust.
anguyen5845.50 |
01-18-2018, 04:50 PM | #19 |
No 55mph
1621
Rep 8,476
U.S. = red
Euro = amber
01-30-2018, 09:07 PM | #21 |
Rep 343
01-30-2018, 10:20 PM | #22 |
Rep 4,031
Funny, coming from the UK I like the red! Was disappointed my first couple cars here had orange, guess it is the novelty factor!
2012 BMW 328i E93 | Deep Sea Blue Metallic - 2015 BMW 328i F31 MSport Sports Wagon | Alpine White - BMW CCA DelVal
