01-29-2014, 11:24 AM | #23 | ||
Rep 32,881
@carzaddict 's explanation above is correct! |
01-29-2014, 11:40 AM | #24 |
Rep 15,858
Doesn't the 3-series get sharper throttle response for both toggled Sport mode, or when selecting DS mode?
I'm sure mine does, when moving to DS, will have to check. I know it does if I've only got the chassis checked. No throttle change in Sport mode, but changes throttle sensitivity in Sport+, plus the gearbox automatically changes to Sport mode. HighlandPete |
01-29-2014, 11:52 AM | #25 | |
Rep 32,881
I'm not sure which modes definitely do/don't activate it. |
01-29-2014, 11:53 AM | #26 |
Rep 3,432
This is a matter that is confusing me a little in getting to know my new car, I have to say..
From what I can work out, the four combinations of drive experience mode and gearbox mode have the following effects in my car (which has VSS and fixed suspension): Drive experience switch in "comfort" and gearbox in D = most relaxed combo Drive experience switch in "sport" and gearbox in D = sharper throttle and weightier steering with some changes to gearbox (typically 500 more revs per gear change). I get the feeling the change itself is still a more relaxed one, like in D. I have to be honest, though, and say that I have not quite worked out in exactly what way the changes change. Drive experience switch in "sport" and gearbox in S = sharper throttle and weightier steering with more aggressive changes to gearchanges (typically more revs per upchange, hanging onto lower gears longer, and a more aggressive change itself) Drive experience switch in "comfort" and gearbox in S (or M) = normal throttle/steering but with some changes to gearbox (typically 500 more revs per gear change). I suspect this switching of the gearbox mode (without the dive experience change) is more to allow manual changes in comfort for those times when that would be useful. Has anybody any further thoughts/observations on the differences between the combinations?
CAR HISTORY - Golf GTI 245 - F30 340i M Sport - F30 330d M Sport MPPK - F30 320d Sport - 997 Gen2 GT3 - 987 Cayman S - 986 Boxster S - Ibiza Cupra - Polo 16v - E30 M3 (Official GB import) - Integra 16v - Mk2 Polo S - Mk1 Golf C
01-29-2014, 12:07 PM | #27 | |
Rep 15,858
As to using more fuel, I suppose it depends how we see it, heavy right foot + sensitive throttle = more fuel for many drivers. I personally don't particularly like a throttle being too sensitive, I like the longer travel of a normal setting, allows for a more controlled throttle modulation. Then I'm not really into the heavier damping of the sport steering mode, takes away from the steering more than it adds, IMO, with a superficial stiffly damped feeling, rather than genuine added weighting. HighlandPete |
01-29-2014, 12:12 PM | #28 |
Rep 680
Is it possible to make sport only change the Steering?
So far the only mode i get options on is ECO PRO the rest don't seem to have user settings (unless they are hidden in the iDrive menu system) |
01-29-2014, 12:41 PM | #29 | |
Rep 11,292
Going back to what the OP is asking..... I think higher torque always makes a car "feel" faster. Diesels have bucket loads at low revs and gearbox D mode keeps the engine at lower revs thus making the car "feel" faster.
Current: Golf R Mk8Previous: Golf R Mk7.5 Mercedes AMG C63 S Coupe F80 M3 Competition Pack |
01-29-2014, 12:48 PM | #30 |
Rep 11,292
This is why even 2 litre diesels "feel" fast. They don't have the bhp, but they have masses of low down torque.
A few years back I had a 2.2 petrol Vectra as a company car and my colleague had the 1.9 Vectra diesel. Both put out around 150bhp - but the diesel felt quicker, due to the torque.
Current: Golf R Mk8Previous: Golf R Mk7.5 Mercedes AMG C63 S Coupe F80 M3 Competition Pack Last edited by dopper99; 01-29-2014 at 12:56 PM.. |
01-29-2014, 12:51 PM | #31 |
Rep 9,709
@d4springer has hit the nail on the head. It is Torque that you 'feel' when it comes to acceleration urge.
Putting the lever in MS keeps the revs high and on a 335d reduced torque but high power. Normally would still mean rapid progress, but with the close ratios of the 8 speed box there is not so much of a gearing torque drop between gears. No point revving beyond 4700 max. 335d power graph; Last edited by NISFAN; 01-29-2014 at 01:07 PM.. |
01-29-2014, 01:01 PM | #32 |
Rep 1,573
press and hold the DSC button for 10+ seconds.
2015i Cadillac Escalade ESV
01-29-2014, 01:18 PM | #33 |
Rep 11,292
Yes, but that has other consequences such as losing the back end if you are not careful.
01-29-2014, 01:32 PM | #34 | |
Rep 1,502
Drives: M4 CP SSII/SS
Back to OP, I haven't noticed the same but will investigate
Current: F82 CP SS/SS
01-29-2014, 01:49 PM | #35 | |
Rep 19,982
01-29-2014, 02:15 PM | #36 |
Rep 347
Right, I'm getting confused. Taking into account peak torque etc., which setting is the quickest accelerating?
Comfort, sport or sport+ and gearstick left or right? |
01-29-2014, 02:23 PM | #37 |
Rep 1,502
Foot to the floor will be much the same in all settings, less the shorter gear changes with stick to left.
01-29-2014, 02:30 PM | #38 | |
Rep 1,919
01-29-2014, 02:33 PM | #39 |
Rep 3,432
I think (and I stand to be corrected) that you need to have adaptive suspension to get the set up menu for sport mode..
01-29-2014, 03:06 PM | #40 | |
Rep 25,113
My car made front page of Bimmerpost
01-29-2014, 03:09 PM | #41 | |
Rep 25,113
Ie you pull away slowly and the box thinks he's off for a nice steady drive, but if you really pushed on in those early stages despite being in the same mode the car would be faster...... Certain it used to be like this so likely to have carried over.
01-29-2014, 03:47 PM | #42 | |
Rep 1,919
It could have something to do with the conditions though... It was chucking it down, it was dark, it was late, roads weren't the best and I was bricking it because this car is seriously fast!!! It seems faster now it's got a few miles on it too. Is that possible or just a placebo again? |
01-29-2014, 04:01 PM | #43 | |
Rep 1,502
Or perhaps I'll just try out using the dynolicious App
01-29-2014, 04:19 PM | #44 | |
Rep 11,292
