06-13-2018, 11:02 AM | #158 |
Rep 2,152
A few interior updates.
-OEM cupholder lid -OEM M3/M4 shift area with leg pad -M Performance trim kit -M Performance M3/M4 Armrest -M Performance M3/M4 Brake handle -M Performance M3/M4 Steering wheel with race display -Recaro Leather Sportster CS -Brey Krause seat brackets to utilize OEM electric sliders Did a interior overhaul, cupholder lid helps me drink less sugary drinks, good place to put my phone for waze. I've always wanted the M Performance M3/M4 armrest, after getting it.. sorta had to get the brake handle too. Picked up the electronic steering wheel second hand, had to figure out the wiring myself, wasn't that complicated after doing some research, but definitely was a headache. Got some Recaros because I've always wanted these seats, they match the OEM black dakota leather perfectly! Also found out about Brey Krause seat brackets, they are compatible with the OEM electric sliders, which was wired up to E30 window switches so that I can move forward/backwards using a switch! Ridiculous wiring harness from my used steering wheel Recaro pics Untitled by johnnyboix, on Flickr |
06-13-2018, 12:43 PM | #159 |
Rep 67
06-27-2018, 05:58 PM | #161 |
Rep 2,152
New wheels!
-BBS LM 18x8, 18x9.5 -Blue M-Sport brakes front and rear, 340/345 setup Found a rare set of BBS LM's in an 18 inch setup (discontinued) and couldn't pass it up, it's a 18x8 (+25 to +30) ish offset fronts and 18x9.5 +34 offset rears. The front offset is around there just by guessing, I've ran quite a few wheels and that's what I came up with. I WILL eventually measure it to see what it is, but the reason I don't know is because it's a face off a 18x9.5 +34 LM wheel, onto an 8 inch wide barrel. I chose this setup due to the fact that it can run the OEM sized tires (225/45/18 and 255/40/18) without stretching the tires, I'm trying to keep the OEM radius as close as possible because the vehicle has x-drive. Installed OEM tpms sensors with BBS valve stem caps, and topped it off with Blue/Gold BBS caps (always wanted these, I remember the blue cap was rare since it only came with the mag BBS wheels, but I guess they started making them for everyone). Issues Of course, after I mounted up these pretties I would run into issues. Test fit went fine, until I tried turning the front wheel, the inside barrel was stuck on my bbk caliper (370 mm M Performance brakes). Initial Test Fit So I figured out I needed the 340 M-Sport brakes in the front to make it work, so I asked around for a car with similar specs, and someone was nice enough to help me test-fit. Second Test Fit Woohoo, it fits! but... If you don't know what you're looking at.. the rears are WAY too aggressive. Good news is I knew the rear was reverse-faced, if you don't know BBS LM's.. that means the face was mounted from the inside of the barrel, allowing for more lip and more aggressive stance. No problem.. let's reverse-reverse face this damn thing. After/Before (notice the face location) Finally! Ready to install this thing. I ended up getting some blue M-Sport 340/345 calipers from ebay, Stoptech drilled/slotted front rotors, and Hawk HPS 5.0 pads. Had Danny at Minicorsa install em and finally put on my rims.. from buying these wheels in March, to finally installing them in June, it was pretty satisfying seeing them on. Last edited by Johnny250; 06-27-2018 at 06:04 PM.. |
06-28-2018, 12:51 PM | #168 |
Rep 2,152
06-28-2018, 04:25 PM | #169 |
Rep 172
Pretty cool you found blue caps in 70mm, I didn't know they have it in that size. Was thinking of picking up a red set eventually. Last edited by Sam!; 06-28-2018 at 04:31 PM.. |
06-28-2018, 05:41 PM | #170 |
Rep 25,989
Love the way your car has progressed! The blue caps and the blue brakes are nice touches!
VMR|Wheels | 714.442.7916 |
sales@velocitymotoring.com | www.velocitymotoring.com | facebook | flickr | Instagram |
06-29-2018, 12:57 PM | #175 | ||||
Rep 2,152
Appreciate it. Thanks OG! |
Tags |
328d, estoril blue, f31, msport, wagon |
