BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > XHP Trans Tune - Experiences and reviews?
      02-06-2020, 02:00 PM   #45
anielsen71
Denmark
559
Drives: F36 435xd
Originally Posted by OzBMR View Post
ZF8HP50 has 550 Nm torque limit in all 8 gears. The 6 speed has lower limits in 3 and 6.
Stage 2 tunes can go over the 550 Nm limit, so either the tuner needs to send an altered torque value to the transmission, resulting in more slip in clutches and reduced effective torque transfer, or send correct value and use xHP to raise limits.
My bad...in the 35d, it's the8HP70 rated to 700nm from ZF.
Fits the 35d's 630nm from factory better...
Point is that with the tranny map, the tranny will not limit the engine until 1000nm.
And yes, it might result in more tear and wear.
But as long as you have some respect for the car, change the oil and filter regularly I don't think there's a big risk at this.
My former e91 330d was mapped to 670nm and had a similar tranny map and it has now over 500.000 km on the clock without issues
Brgds
Allan
‘15 F36 435xd Gran Coupé
Ex: E46 330d, E91 330dA
OzBMR574.50
      02-06-2020, 06:54 PM   #46
Supr3me
Supr3me's Avatar
Drives: Your mom crazy
Originally Posted by ilkthat View Post
I have the exact same setup as you wow and I’m dojng e50 with cpi kit right now do you recommend wedge performance for a custom tune ?
Yes, the experience has been very good with them. Since CPI is still so new I think you will benefit greatly from getting some focused expert attention to dial in your system. They are an MHD platform shop - is that the flash you're using?
2020 M340i
DAW UF-X; Wagner intake manifold/port injection; ID1050xds; Precision Raceworks St2.5 LPFP ECUTEK; Wedge Performance E70 tune
KW V2; BC Forged EH173
      02-06-2020, 08:02 PM   #47
ilkthat
Drives: Bmw 340i
Yes I use jb4 mhd xhp and have cpi kit mppsk dinan jntake and vrsf catless downpipe
      02-07-2020, 06:09 AM   #48
Stanio
Bulgaria
67
Drives: F30 335 2014 Xdrive
Originally Posted by Stanio View Post
I've been stage 3 for more than 10k miles and as soon as they came out with Stage 4 I flashed it.
This trans tune is amazing! Stage 4 has the drivability of stage 3 but once you move the shifter to the left the fun begins. It keeps the revs high and it has really aggressive shift points.
It's the only tune that would make me keep my car for longer than I anticipated and their customer service is top notch.
No issues so far, only smiles.
Money well spend in my honest opinion
Stage 4???
Sorry, I realized too late that it was for b58 but you guys will get it soon and when you do.... you'll see what I'm talking about
      02-07-2020, 09:27 AM   #49
Alarmin
Alarmin's Avatar
511
Drives: G80 M3 Comp xDrive
Quick question - has anybody used the MHD Wifi Adaptor option to flash XHP Trans tune? The pamphlet seems to say that you can use Apple products for the flash, but the mhd wifi adaptor says you can only use an android. Just curious if I can buy the MHD Wifi adaptor and use my apple products and call it a day rather than getting the android device, obd/dcan, and usb/otg cable.
      02-07-2020, 09:39 AM   #50
Supr3me
Supr3me's Avatar
I have used the MHD Wi-Fi adapter and can confirm that it works. But I used it with an android device, can't speak to the Apple compatibility.
2020 M340i
      02-07-2020, 10:53 PM   #51
CrushJelly
Drives: M140i
XHP confirmed iOS support will come by end of March.
      02-08-2020, 01:41 AM   #52
theone1973
Drives: M140 -18
I went back to stage 2 from stage 3.
In halv throttle and manual gearing its just slams in the gears..so damn hard. Full throttle or less is just fine. Hard shift is off in app.
Anybody feels the same ?
M140 Sunset Orange 2018. M719 Jet Black. Maxton sideskirts and spoiler, Ksb front splitter, RK Tuning diffuser, TPI spacers, MHD Stage 2, Xhp stage 3 , Wagner 300 cell cat, MPE silencer , Quaife LSD.
Supra pump and OTS E30, Spool ethanol analyzer (E35)
https://theone1973.imgbb.com/
      02-08-2020, 03:15 AM   #53
Mustard3
Mustard3's Avatar
Drives: F31 340i
Those of you with both xHP and a flash tune, if you could keep just one, which would it be?
      02-08-2020, 03:18 AM   #54
kriszty
kriszty's Avatar
329
Drives: B58 M240ix pureturbo800 dorch1
are you still happy with the stage 2 xhp , i,m still thinking, but i do not want to stress the tranny that much, so i,m not sure if i,m flashing xhp ... , my car is almost simular in specs ( horse power , downpipe etc.. ) but i have xdrive
Aldor2788.00
      02-08-2020, 06:44 AM   #55
theone1973
Drives: M140 -18
Xhp is still great I think, I will try Stage 1 instead....like you say its stress the gearbox might a little bit.
Give it a try mate
      02-08-2020, 10:10 AM   #56
Solid67
Drives: 2019 M240i xDrive MP Edition
I have been on xHP stg 3 since 5,000 miles and my car currently has 17,000 miles on it. I have xdrive as well and so far no problems to report.
2019 M240i M Performance Edition / xDrive / ZF8 / BM3 Stg 2+ E30 / xHP Stg 3 / Dorch Stg 2 HPFP / Evolution Racewerks Catless Downpipe / MPPSK Exhaust / FTP Drop in Filter / FTP Intake Pipe / FTP Chargepipe / NGK 94201 Spark Plugs .022 / Michelin PS4S - 225/35/19 + 245/30/19
      02-10-2020, 04:55 PM   #57
TBONE1969
Drives: AW '18 340i
Shift points
I've been running stage 3 for about 2 weeks, almost always in Sports+. My big complaint is how the car shifts when left in automatic mode. It shifts at or around 2000rpm at mid-throttle around town. It then drops even further out of boost in the next gear. I've tried pushing the shift points up by 50% (which should be 3000 rpm?), but I'm still not happy with it. Ideally the car would never drop out of the boost range when it grabs the next gear. Anyone have a fix for this?
      02-10-2020, 06:02 PM   #58
Supr3me
Supr3me's Avatar
Without seeing exactly what's going on it's a little tough to comment, but my first thought is that although xHP adjusts the logic in the transmission, it still has adaptive logic to read how aggressively you're driving and select shift points accordingly. If you're accelerating and decelerating aggressively, it should read that input and keep your rev range higher and tighter. If you're driving in traffic, it's not going give you the same 'track mode' type shifts- nor I think would you want it to.
Does that make sense, or am I misunderstanding?
2020 M340i
      02-10-2020, 11:57 PM   #59
theone1973
Drives: M140 -18
Originally Posted by sitetech View Post
Stage 1 is boring. Just remove torque limiter and shows gear number. Stage 2 is a minimum. But I highly recommend Stage 3. Drive mode is still safe and comfort, but sport+ like a beast
BTW, you can change stages and settings without re-adaptation. Just reflash and you are ready.
yea I try stage 1 and lost my pops and bangs in manual shifting
Stage 2 is on its way again...flassh in 15 sec with MHD Wifi adapter
      02-11-2020, 10:56 AM   #60
conradb58
conradb58's Avatar
Drives: 2022 M240I Thundernight Metall
Before I begin I want to say I purchased the super 8 license. I daily the the stage 3 flash and the stage 3 flash license is "stock" , I haven't found time to mess with the parameters yet.
1. Absolutely ! Well worth the $350+ tax spent.
2. So far so good although I've only driven a thousand miles give or take
3. I would absolutely recommend it.
P.S I have MHD so after I installed I had to re flash and check the "xhp flashed 8AT" option so the tunes can work harmoniously
YT: Conrad B
IG: conradb_93
      02-11-2020, 12:28 PM   #61
marcthedark
Drives: M240i xdrive Convertible
That is for the MHD tune not to restrict torque > now you get whatever the tune gives you and not cut at the stock transmission limits
      02-11-2020, 12:30 PM   #62
conradb58
conradb58's Avatar
Thank you for informing me I did not know that.
YT: Conrad B
IG: conradb_93
      02-11-2020, 12:41 PM   #63
theone1973
Drives: M140 -18
This is one of the "problem" I can relate to. The caracter of the car is very different to original..when you dont think the car will shift you push more throttle..suddenly the car shift and like you can't drive the car. Now when I get the costum tuna its more noticble..its getting worse.
Driving more aggresive its easier..but crusing is a mess
      02-12-2020, 09:30 PM   #64
les anderson
Drives: 340i
Does it ever go on sale?
      05-20-2020, 02:58 PM   #65
efrant
Drives: 2016 BMW 340i xDrive
I have a Dinantronics Elite V2 installed. Would there be any issues if I flash xHP (and xDelete for that matter)?
      05-20-2020, 03:12 PM   #66
yokata
yokata's Avatar
Bulgaria
156
Drives: Bmw F30 340xi
Yeah st3 in direct is very messy, it shifts way to early and when you are not wot it changes last gear possible and you cant accelerate normally.Have to smash it to the ground and its really a mess.In S mode is perfect so im happy overall
