07-25-2014, 02:41 AM | #23 | |
Rep 40,763
BMW has a problem with cafd_000009c8-006_000_030, and it should never have been included in PSdZData. In an older version of PSdZData, cafd_000009c8-006_000_030 was 0 Bytes. It seemed like BMW fixed it becuase the new version was 1.03 Mb, but it still is not fixed. It is corrupt, and can't be used. Any KOMBI with cafd_000009c8-006_000_030 will need to have it replaced if it is to be coded.
07-25-2014, 04:03 AM | #24 | |
Rep 10
11-21-2014, 11:33 AM | #25 | |
Rep 2
04-18-2016, 02:24 AM | #26 |
Rep 67
succeed! NBT KOMBI coding on F30
NBT KOMBI coding on F30 with ENET cable
and refer to http://blog.obd365.com/2016/04/18/bm...ng-with-e-sys/ |
03-29-2018, 06:58 AM | #27 |
Rep 58
Hello guys, I am in trouble. I am trying to programme the kombi but i have this results from esys
Caf's suchen Tal wird generiert Abarbeitung wird gestartet TAL execution started. ExecutionID=2018/03/29-13:51:41.095 [] prepareTALExecution started [] prepareTALExecution finished [] prepareVehicleForCoding started [] prepareVehicleForCoding finished [BKOMBI - 60] prepareECUforCoding started [BKOMBI - 60] prepareECUforCoding error [BKOMBI - 60] There was an error during TAL execution, please check the log files. [BKOMBI - 60] - [Exception - BKOMBI - 60] SVK-Ist does not match expected SGBMIDs for ecu ECUId:BKOMBI_0x60. Excpected (relevant process classes only): [hwel_0000088b-002_063_002, hwel_00000b09-002_067_002, hwap_00000140-255_255_255, hwap_00000ce5-255_255_255, btld_00000e4e-007_063_000, swfl_00000e4f-007_071_010, swfl_00000e50-007_071_000, swfl_00000e51-007_071_000, swfl_00000e52-007_071_000], Actual (relevant process classes only): [hwel_00003ef0-001_002_000, hwel_00003e54-001_003_000, btld_00003e56-002_000_000, swfl_00003e5a-002_000_001, swfl_00003e5e-002_000_001, flsl_00003e57-002_000_000, swfl_00003e5c-002_000_001, swfl_00003e5b-002_000_001, swfl_00003e5d-002_000_001], Missing SGBMID(s): [hwel_0000088b-002_063_002, hwel_00000b09-002_067_002, hwap_00000140-255_255_255, hwap_00000ce5-255_255_255, btld_00000e4e-007_063_000, swfl_00000e4f-007_071_010, swfl_00000e50-007_071_000, swfl_00000e51-007_071_000, swfl_00000e52-007_071_000], Surplus SGBMID(s): [hwel_00003ef0-001_002_000, hwel_00003e54-001_003_000, btld_00003e56-002_000_000, swfl_00003e5a-002_000_001, swfl_00003e5e-002_000_001, flsl_00003e57-002_000_000, swfl_00003e5c-002_000_001, swfl_00003e5b-002_000_001, swfl_00003e5d-002_000_001] [BKOMBI - 60] finalizeECUCoding started [BKOMBI - 60] finalizeECUCoding finished [] finalizeVehicleCoding started [] finalizeVehicleCoding finished [] finalizeTALExecution started [] finalizeTALExecution finished TAL execution finished TAL-Execution finished with status: "FinishedWithError". [C207] TAL execution finished. Duration: "23s". [C206] Abarbeitung beendet the kombi is not easy to connect. PleaseI need some info to solve it. Thanks. |
03-29-2018, 07:05 AM | #28 | |
Rep 40,763
03-29-2018, 11:24 AM | #30 |
Rep 40,763
You have this error during Flashing or Coding? It appears to be a flashing Error caused by improper I-Step Shipment.
03-29-2018, 11:29 AM | #31 |
Rep 58
Transaktions-Report: Aktion: Codieren
BKOMBI [60] cdDeploy FinishedWithError cafd_00000760-007_003_031 NotExecutable Detecting CAF and using the last doesnt work |
03-29-2018, 11:36 AM | #33 | |
Rep 40,763
"[BKOMBI - 60] - [Exception - BKOMBI - 60] SVK-Ist does not match expected SGBMIDs for ecu ECUId:BKOMBI_0x60...." Why are you detecting CAFD? ECU has no CAFD? Is this factory fitted ECU or Retrofit?
03-29-2018, 11:47 AM | #36 |
Rep 40,763
I have no idea what you have going on. You say you had 6WA, but error above shows BKOMBI, which is Basic Kombi. 6WA is KOMBIi and 6WB is DKOMBI.
All I can tell you is to inject CAFD, at a minimum FA must be correct (Type Code, Build Date, and Option Codes) and then your PSdZData must also have comptable CAFD with existing ECU firmware. SVT must also be correct, and if ECU is showing BKOMBI, and you have 6WB, your SVT is not correct.
03-29-2018, 12:11 PM | #38 |
Rep 40,763
05-01-2018, 10:15 AM | #39 |
Rep 7
05-01-2018, 10:18 AM | #40 |
Rep 40,763
Yes. You corrupted ECU CAFD, and ruined it. Now you must inject new CAFD into ECU and Encode it.
05-01-2018, 11:20 AM | #41 |
Rep 7
05-01-2018, 11:27 AM | #42 |
Rep 40,763
Connect => Read FA (VO) => Activate FA (VO) => Read SVT (VCM) => Left-Click on desired ECU => Click on "Detect CAF for SWE" => Select the CAFD from latest I-Level shown (bottom one) => Select OK => Right-Click on ECU (the ECU itself not the underlying CAFD) => Select CODE.
07-28-2018, 05:55 AM | #43 |
Rep 3
Please advise how can I change svt? Have same problem with retrofitting F20 basis kombi to 6WA. I cant see 6WA in diagnosis and esys Read ECU. So I need to delete BKombi from SVT and how to add 6WA KOmbi?
07-28-2018, 07:45 AM | #44 |
Rep 40,763
Load SVT in E-Sys => Editors & Viewers => SVT-Editor and modify SVT.
