04-07-2019, 08:37 AM | #89 | |
Rep 640
Drives: 2008 M3 (E93)
"Hard times create strong men. Strong men create easy times. Easy times create weak men. Weak men create hard times."
04-07-2019, 10:48 AM | #90 |
Rep 4,893
99% of the time, you only get the power drop at a gear change if you don't get off the throttle slightly. Bootmod3 is also a idea now, and it offers more for less money (of course I did some reading, now I have the itch). You do add the risk warranty issues with a tune vs piggyback though.
04-08-2019, 02:43 PM | #91 |
Rep 1,597
You need to fully warmup and then ease into the power at 3/4 throttle if you have an AT. Interesting is the MP transmission tune. I wonder how that would pair with Active 8? At the end of it all, an ECU and TCU flash is the best way longer term. I am still hanging with A8 for now.
04-09-2019, 01:53 PM | #92 |
Rep 150
Drives: 2016 BMW 340i
I have little knowledge of auto mechanics. Would A8 be less beneficial with no exhaust and air intake upgrades?
04-09-2019, 04:08 PM | #93 |
Rep 279
Drives: G80 M3 Comp xDrive
As an update, I recently installed the Bootmod3 Stage 1 91 tune. What I've noticed so far:
- Shifting at WOT is basically stock feeling - no more harsh shifts - Active 8 seemed to push me back into my seat way harder, could be all the extra torque down low. I think there may be some more power to be realized with my tune so I'll be sending PTF some logs to see if there is room for improvement. Will update afterwards. If the BM3 tune in its current state is meeting its full potential, I will probably be switching back to A8. |
BMWILUVU809.00 jimmy8904563.00 |
04-09-2019, 04:31 PM | #94 |
Rep 1,597
04-09-2019, 07:15 PM | #95 | |
Rep 1,334
Mods; 93 Octane, Active 8 Tune, ER Catless Downpipes, BMS Intake, Muffler Delete
X3 M40i G01, M235i F22, 335 F30 MSport, 135 DCT, 335 E92, Audi A3
04-09-2019, 08:08 PM | #96 |
Rep 640
04-09-2019, 08:55 PM | #97 | |
Rep 1,597
04-09-2019, 09:18 PM | #99 |
Rep 150
I assumed with the A8 the car would need more air intake and would produce more exhaust. Just thinking those would be a bottleneck.
04-09-2019, 10:50 PM | #100 |
Rep 1,334
04-18-2019, 09:22 PM | #101 |
Rep 27
I installed yesterday. I always get the "stutter" shifts at WOT. I will leave the tune on for a couple of weeks to see what happens. The car definitely is producing power, but I am hitting 7K and it seems to pull power as it is shifting. It is almost like bumping the rev-limiter that I have experience in other cars. Hopefully it works itself out, and is not causing any damage.
04-24-2019, 12:43 PM | #102 |
Rep 640
Has anyone experienced a power loss when going from WOT from gear to gear and rectified it by reducing the gap in spark plugs to overcome the boost increase?
04-24-2019, 12:54 PM | #103 |
Rep 132
Drives: OG M2
The power loss when shifting isn't caused by a spark plug gap issue, it's because of the transmissions torque intervention stepping in. It seems that the piggybacks have more issues with this than flash tunes.
M2 - TC Kline DA Coilovers - Apex SM-10s - 265 RS-4s - Dinan Intake - BM3 - CSF Intercooler - VRSF CP
Previous: 6th Gen Camaro SS 1LE | 2020 JLUR Wrangler | F30 340i | B7 Audi A4 APR Tuned | E46 330ci Instagram @track.n.trail |
04-24-2019, 12:57 PM | #104 |
Rep 640
I have a manual so I'm letting off the throttle at shift point. It's not that
05-01-2019, 07:26 PM | #105 |
Rep 1,597
05-02-2019, 08:05 AM | #106 |
Rep 640
Factory plugs and however they come gapped. I haven’t taken them out to check or re-gap so idk
05-03-2019, 07:33 AM | #107 |
Rep 49
Hi Alarmin
Can you clarify something please? I see you mentioned the M Package and the dyno shows 328 HP before the AA Do you have the M Package that includes the added HP? I do and my HP is approx. 355-60 - curious why your number is lower. Thanks |
05-03-2019, 08:08 AM | #108 |
Rep 1,597
M-sport does not give you 360HP. MPPSK upgrades the car to 360HP.
active 8, active autowerke |
