03-07-2015, 02:04 PM | #8229 | |
Rep 40,310
03-07-2015, 03:57 PM | #8230 |
Rep 1
Hi Seansheridan,
I am just going to start coding my 2014 320ed (it was delivered in June) I am also in the UK. I was wondering if you could send me the files that I need? I have just completed an upgrade from business nav to professtional and was a lot easyier than I expected (minus a few cuts) but I now need to do some coding. Also if anyone needs advise on the upgrade I did I am more than happy to help!! |
03-07-2015, 07:35 PM | #8231 | |
Rep 40,310
03-07-2015, 09:20 PM | #8232 |
Rep 198
Drives: 2021 BMW 540i xDrive Shadowlin
This sounds awesome, and an awesome thread. I'm going to order a cable.
I'm getting a 2015 328i with tech package. Will I still be able to code or will I have the v55.0 Psdzdata problem? If the F30 is not affected please PM all the relavent links. |
03-07-2015, 09:31 PM | #8233 |
Rep 40,310
All Fxx cars are affected, and yours certainly will be if you have not already taken delivery of it.
03-07-2015, 10:00 PM | #8234 |
Rep 198
03-07-2015, 10:08 PM | #8235 | ||
Rep 1,002
So basically what I'm asking is can I backup my CAFD files now (pre 55.0), and if my ilevel ever gets updated, just inject the old coded CAFD files back? |
03-07-2015, 10:29 PM | #8236 |
Rep 40,310
I would not take coding data backed up from old CAFD A and inject it into new CAFD B as it may not align. You do not know what changes were made to the new CAFD structure.
03-08-2015, 02:17 PM | #8237 |
Rep 179
I've started making my own E-sys ethernet cable. Done with the soldering on the OBD-II connector. But when I started to work on the RJ-45 connector I noticed that I need a shielded RJ-45 connector. I got a normal non-shielded RJ45... Is there any way I can get this one shielded? Or am I best off buying a new shielded RJ-45 connector?
03-09-2015, 08:09 AM | #8238 |
Rep 100
Hi, I own a 2014 bmw f21 has pack m, bussines browser, speed control, usb, bluetooth expanded, called sos, teleservice, conectdrive, xenon, etc ...
I want to re-equip with esys and enable live bmw, bmw apps, bmw internet online , and if there is possibility to activate something else, leave it on the step. Can anyone help? |
03-09-2015, 09:39 AM | #8239 | |
Rep 40,310
03-09-2015, 04:29 PM | #8241 |
Rep 40,310
PO sent.
03-09-2015, 05:37 PM | #8242 |
Rep 7
Newbie question
Hey guys, I'm trying to connect my Esys 3.26.1 to my 2012 328i xDrive w/Nav via ENET cable. I'm getting the "No ZGW Available" message. I do not have the ZGW_Search utility that I see referenced in other threads and I'm guessing it's because it was used in the older version of Esys? Any direction would be much appreciated.
03-09-2015, 05:40 PM | #8243 | |
Rep 40,310
1) The Target Connection Window should not be blank (It should show multiple target connections for different chassis') 2) ENET Cable must be good 3) Car must have proper voltage (Make sure motor is running if car is not on a Charger). 4) Laptop must not have Firewall or any Antivirus software running. 5) PC Lan Adapter should get a fallback IP address of 169.254.xxx.xxx (Make sure it is using DHCP and does not have a Static IP address assigned to it)
03-09-2015, 06:22 PM | #8244 | |
Rep 7
03-09-2015, 06:46 PM | #8245 | |
Rep 40,310
Let car sleep for an hour and try again.
03-09-2015, 07:07 PM | #8246 |
Rep 40
Recode after dealer update
Recent brought my f10 M5 2013 to the dealer for coolant issues. They updated my software and now when I was trying to recode cannot find files for HU_NBT, CAS, etc.
I currently have V54.0_PSdZData_Full E-sys_v.3.26.0 Do I need an update? My media software is MN-002.052.001 telephone TN-002.052.001 Thanks for any assistance. Last coded car in January 2015. |
03-09-2015, 07:44 PM | #8247 |
Rep 7
03-09-2015, 08:09 PM | #8248 | |
Rep 40,310
03-09-2015, 08:13 PM | #8249 | |
Rep 40,310
03-10-2015, 12:29 PM | #8250 | |
Rep 7
