03-26-2015, 06:43 PM | #1 |
Rep 264
Niche Esse + H&R Sport Springs = Tires?
I just bought some Niche Essen wheels for the MY15 sportline 335i. I already have a set of 245/35/19 tires and am trying to squeeze the widest tire possible on the back while keeping a similar rolling diameter.
The wheel specs are Front: 19x8.5 +35 19x10 +40 There isn't really a good 275 option since stock rolling diameter is 26" 275/30/19 - 25.5 275/35/19 - 26.6 - Leaning this way 285/30/19 - 25.7 - First choice. I'm hoping since the 285 is a little shorter i might be able to fit it without rubbing. All i could find is a guy running 285s on a 10.5" wheel with 42 offset and he's slammed. Thank in advance! |
03-26-2015, 10:47 PM | #2 |
Rep 444
Dunno if this will help but I'm on 19x8.5 et33 19x9.5 et40 245/35 & 275/30 with H&r sports. Mine is the mineral grey towards the bottom of the thread listed here, no rubbing issues whatsoever
19" MORR FS77 on Alpine White 335i http://f30.bimmerpost.com/forums/sho....php?t=1092175 |
03-26-2015, 10:55 PM | #3 | |
Rep 264
Thanks for the reply. How much room do you have between the outer lip of the tire and fender? How much room do you have on the inside? How do you like the 30 series? Would you go with a 35 next time around for a little more meat? |
03-27-2015, 12:22 AM | #4 | ||
Rep 444
03-27-2015, 07:49 AM | #5 |
Rep 264
Thank you. I think I'm going to play it safe and stick with the 275/35. The difference between that and the 285/30 is only .3" wider. Not worth the risk of rubbing just for looks.
