04-29-2016, 12:46 PM | #1 |
Rep 372
First interior wrap!
Was going to spend 800 dollars to buy the OEM Carbon fiber trim but I thought about it and just concluded that I was dumb so I spent 45 bucks to get 2 rolls of 1'x5' 3m 1080p vinyl and did it myself! There are minor flaws if you look carefully but I'm just happy that I saved a heck ton.
The hardest part was probably taking trim off since it was my first time doing it and I definitely broke some plastic clamp on all of my door handles trim but the metal ones are fine so it's still good. Wrapping was lots of fun, the 3m stuff is super easy to work with. I personally did not have any exeperience and I just got my hands on it and turned out pretty well I believe. Again. $45 vs. $800 I know it lacks the m performance thingy on the AC trim but for that kind of money saved, I'm not complaining at all |
04-29-2016, 04:22 PM | #6 |
Rep 23
Awesome, how did u post the carbon fiber on the steering wheel i have exact same setup as you but i dont know how to put the carbon fiber on the wheel?
04-29-2016, 07:58 PM | #7 |
Rep 168
I still need to do my wheel (haven't looked at how to take it off yet) and my key (also haven't looked at taking it apart yet).
It gets a bit trickier on the dash pieces when you expose the silver (or blue in my case) trim piece that you covered up. I did my big dash piece a few times because I couldn't cut cleanly on a line I couldn't really see. And I need to redo my shifter, that was all sorts of fail. |
04-30-2016, 10:07 AM | #8 |
Rep 372
The wheel piece is really easy to pop up.. Even with bare hand lol just pop it from the back of the upper two sticks
04-30-2016, 10:08 AM | #9 | |
Rep 372
04-30-2016, 11:45 AM | #10 |
Rep 749
Drives: 2016 528i Executive Edition
Does it really pop out that easily? I remeber reading instructions on the install for a replacement Cf one and it required removing the airbag and stuff. Because of that I didn't bother removing mine to wrap. But if it's that easy, I'm gonna give it a go too.
04-30-2016, 04:11 PM | #11 |
Rep 372
It's okay the silver trim. It's a relatively tiny piece of plastic lol
05-02-2016, 12:21 PM | #12 |
Rep 749
Sweet! Took a pry tool and popped the steering wheel silver trim piece out in a minute.
Pretty happy. Gonna wrap this tonight! |
05-02-2016, 12:38 PM | #13 |
A family of bimmers
2745
Rep 7,741
the only thing that would bother me is that the trim around the shifter and the rightside console trim have the pattern going opposite ways.
05-02-2016, 02:14 PM | #14 |
Rep 372
05-03-2016, 01:36 AM | #15 |
Rep 749
Crap realized when I tried installing it back that I broke a couple of the little clips! Now one corner (top right) doesn't clip in properly.
Can anyone tell me what the part number for this plastic insert/piece is? I'm going to buy a replacement and re-wrap that. See steering wheel as OP has pictured above. Thanks! |
05-25-2016, 06:28 PM | #16 |
Rep 32,881
Looks very nice cf wrap! I've ordered small pieces of this 1080 cf vinyl and the DI-NOC cf vinyl as well to see which I prefer.
Only thing about yours is I'm really not sure about is the wrap covering the whole dash trim, it looks a bit odd covering the trim finisher along the bottom. |
05-26-2016, 01:22 AM | #17 | |
Rep 372
Yeah I figured. I actually just took the bottom silver trim part off so now it's got some nice contrast |
05-26-2016, 11:28 AM | #18 |
Schmollbraten
12509
Rep 1,985
Puh, to be honest, a full wrap is not my taste but yours. I would rate the overall quality of your work on a scale from 1 (best) to 5 with a 3 and tendency to a 4. Onto the upper center panel you had left a few blisters at the line step and the cut line at the right grille frame has a mismatch with the frame line. Also to mention is the different CF lines flow onto the lower center trim and the shifter panel, if that wasnt intented.
All in all a good job but you could sure easily do better
Citizen of ///M - Town, where too much is just right Some say, that my scrotum has its own small gravity field and when Im slowing down that brake lights come on at my buttox |
