BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > iPhone connection via USB
      04-05-2018, 09:23 AM   #1
dlylis
Drives: 2015 435i Coupe
When I connect my iPhone 6 to the USB port in the armrest the phone goes into a flash mode where the screen flashes on/off once per second. I thought it was my iPhone 6 so I tried it with an 8 and same thing. Then I thought it may be an aftermarket cable so I switched out to authentic Apple. No improvement. Anyone know what is going on?
2015 435i Coupe Sport
      04-05-2018, 11:34 AM   #2
dlylis
I called my dealer and they said they never heard of it. Its going in on Tuesday))
      04-05-2018, 02:45 PM   #3
dlylis
BTW interesting that you have a 2015 as well AND you live in Tampa
      04-05-2018, 03:13 PM   #4
kalalau
kalalau's Avatar
Drives: 2014 328i x-drive
Same issue here. Took my 328 into the dealership and they could not replicate the issue. Happens on my iPhone 6 plus and 8. It is extremely annoying, I have hard connect to use my connected drive apps instead of the Bluetooth connection.
      04-05-2018, 10:27 PM   #5
Arthurrs
Drives: 2017 430i xdrive Gran Coupe
Try taking the brightness down on your phone, it might be drawing more current from the USB port than the car is able to deliver.
2017 430ix Gran Coupe
      04-06-2018, 01:53 PM   #6
dlylis
I just checked my iPhone 6 and the brightness is at about 30 - 35%. I do that to preserve battery life.
      04-12-2018, 07:41 AM   #7
dlylis
Problem solved. Although the strange path this took, the dealership figured it out. After replacing the USB port it was discovered that you MUST use an authentic Apple cable. I thought mine was but it was a knockoff that looked identical. I went to the Apple store and bought a new cable and, voila, all is cool!
      04-12-2018, 07:55 AM   #8
x-m4n
x-m4n's Avatar
Drives: Gran Turismo (F34)
Good you got it sorted. I personally use Anker cables - solid performance and great customer service. Their new cables come with lifetime warranty!
      04-12-2018, 11:29 AM   #9
anthonyallergy
Drives: 2014 435i
It's not the cable. The USB port is only rated to power at a certain amperage. I don't remember what it is off-hand but after using a phone plugged into it for an hour or two with nav apps open it will start to draw more than the port is rated for and wonk out.
I confirmed this with a USB multimeter. It's also in the manual that you can't use the USB port for charging because it doesn't have the amperage.
      04-13-2018, 05:00 PM   #10
skierrob
Drives: 2014 BMW F30 White
WHAT phone can play music through USB without ALSO charging at the same time? By saying you can't use it for charging, you are also making it impossible to use the device to play music through USB. Dumbest thing I've ever seen in a manual!
BMW should be providing us with a recall for this issue, or should be compensating us for the lack of functionality given that we paid EXTRA for Enhanced USB. Period.
connection, iphone, usb
