02-25-2018, 12:17 PM | #1 |
Rep 730
Cable routing
Which is the best way to remove the cupholders? I need to run a cable from the USB in the armrest to inside the cupholders. Any advice?
I've just inherited the Mrs old iphone 6s which will stay in the car as a spotify device, and maybe use a wifi ODB connector to occasionally use it as a gauge. Unfortunately you have to press the button on the phone to get Spotify to connect to the car, so i've made a holder for it which sits in the cupholders. Now i just need to route the cable. I fitted the LCI instrument panel and coded it the other week too, which is nice
F31 2015 BMW 335i - Manual
02-25-2018, 12:28 PM | #2 |
Rep 136
Wow looks nice! Not scared people will smash your window to take the phone?
I am not sure if the cupholders are part of the centre console (as in, if you can take them out).. otherwise you can easily pull the trim which holds your idrive controller (don’t pull it to hard/far as you don’t want to damage the wiring to your idrive).. otherwise maybe remove the leather around the gear. Not sure about the F30 but previously this was also a ‘pull’ job. But depending how far you want to go the whole center console can be taken out as well |
02-25-2018, 12:38 PM | #3 |
Rep 730
Thanks for the info.
If it is somewhere like the works car park it will fine left in, if i leave it somewhere dodgy, i'll cover it with a glove or something. If i go somewhere really dodgy, i'll take it out.
02-25-2018, 04:58 PM | #4 |
Rep 2,271
Check out this thread: (Not sure if you have a phone cradle to utilise the USB from but may give you some ideas)
http://f30.bimmerpost.com/forums/sho....php?t=1444631 Something similar but done in the arm rest
IG: project540ix
G30 540i xDrive / Stage 3 via BM3 / xHP Stage 3 / Pure 800 Cast Turbo / 5" Catted Downpipe / MST Intake / Remus Exhaust / MSS Springs / 19" JR SL01 & Conti SC7 / 20" BBS CI-R & Michelin PS4S / F90 Sway Bars & Braces / Lots of Gloss Black |
