04-07-2013, 01:38 PM | #309 |
Rep 40
when wiring the stage 2 the directions say to tap in to the yellow wire and black/blue stripe wire. its showing these wires by the passenger side strut. I only found these wires by the DRiver side strut. After looking further thru threads i seen another post that i may need to tap into Red wire and Blue/red stripe wire near the driver side strut.
Has anyone else have this issue? What is the correct wires to tap into? My car is 2013 AT 8 with Xdrive. |
04-07-2013, 07:12 PM | #310 |
Rep 72
Make sure your running high octane fuel when running map 2. Don't wanna blow that motor.
2013 335i F30 N55
04-08-2013, 11:39 AM | #311 |
Rep 478
Drives: '15 AY F80
Anyone noticed rougher starts since hooking up stage 2? Almost as if the battery is low and having trouble turning over? Could be completely unrelated to the tune but I have been experiencing this quite often over the last week or two.
04-08-2013, 01:03 PM | #312 |
Rep 195
Sounds like the motor is running more advanced vs stock which can make it harder to start.
04-08-2013, 07:46 PM | #313 | |
Rep 72
It's not the JB4. Have had mine for months and no issues.
2013 335i F30 N55
04-08-2013, 09:05 PM | #314 |
Rep 1,334
mine has been flawless as well...from stg 1 to stg 2 with absolutely no issues and the best support to boot.
X3 M40i G01, M235i F22, 335 F30 MSport, 135 DCT, 335 E92, Audi A3
04-08-2013, 10:28 PM | #315 |
Rep 556
Drives: 2012 BMW 335I
04-08-2013, 10:54 PM | #316 |
Rep 72
Yes.
2013 335i F30 N55
04-09-2013, 01:20 AM | #317 |
Rep 556
04-09-2013, 06:45 AM | #318 |
Rep 1,975
As long as you have access to 93 octane, you're good.... Seperate user error I've been having - I tend to hold my volume down button on the steering wheel when I turn down my music and it keep switching to Map 0 without me knowing! Frustrating. I now have a yellow sticker on the volume down button so I don't use it, lol
2013 F30 335i ///M-Sport
Forgestar/Challenge/BMS JB4 Wagner/Evo Race/M-Performance 2016 F15 50i ///M-Sport BM3/H&R/Borla |
04-09-2013, 09:09 AM | #319 |
Rep 1,997
04-09-2013, 09:12 AM | #320 |
Rep 478
Drives: '15 AY F80
I've been running Map 2 with catless downpipe + 93 octane and is has been a wonderful trip from 26mpg to 18mpg but aside from that everything has been running great.
Just need to find out what is causing these rough starts in the morning. Only seems to happen with cold starts. |
04-09-2013, 12:14 PM | #321 | |
Rep 556
I have been running map 2, but I use a mixture of 91 with 100 octane. I also have another gas station that has E85, and when I cant get to the 100 octane station, I fill up mostly with 91 and mix in maybe 4 gallons of E85.. The 100 octane runs best though. Since I am on map 2, I will make sure to fill up with the 100 octane as much as possible. |
04-09-2013, 02:18 PM | #322 |
Rep 1,334
There is no E85 / autolearning map at this time (which would most likely be map 5) and it is recommended to use map 7 with a 60/40(e85) mix of E85 or race gas...with or without DPs.
04-09-2013, 04:13 PM | #323 |
Rep 556
So if I want to stay on map 2, stick with the mixture of 91 and 100 octane, correct? What sort of mixture is best or recommended?
04-09-2013, 04:17 PM | #325 |
Rep 1,334
Actually, you can do map 2 if you have a DP but "preferably" at least 93 or higher octane as well.
04-09-2013, 05:07 PM | #326 |
Rep 478
Drives: '15 AY F80
04-10-2013, 06:14 PM | #328 |
Delivered!
Rep 139
Eek, just installed the stage 2, and now I get a drivetrain malfunction, reduced performance. Anybody have any ideas?
Delivered!: 2013 F30 335i M Sport, 8-speed Sport Trans, Estoril Blue/Coral Red, 403M, Premium Pkg, Dynamic Handling Pkg, Driver Assist Pkg, HK Sound, Enhanced BT & USB
04-10-2013, 06:22 PM | #329 |
Rep 478
Drives: '15 AY F80
04-10-2013, 06:39 PM | #330 | |
Delivered!
Rep 139
Is the CAN connection only needed for steering wheel control? I did hook it up, but I am curious if this is all it is for so far.
