11-17-2020, 05:07 AM | #133 |
Rep 770
grocerylist271.00 |
01-13-2021, 07:03 PM | #135 | |
Rep 11
I suppose you could just ignore the data lines if you only wanted to use it for charging, but I would recommend just wiring in the entire female USB cable in case you ever wanted to use it for something else. I also don't know enough about the data handshake to give an answer on that, but I wouldn't doubt it. I mostly use it for powering my RPi Bootmod3 wifi transmitter and have never had any issues. |
01-16-2022, 08:42 AM | #136 |
Rep 39
Great instructions and pictures. Did mine this morning and it only took about 15 minutes. Since the blue wire is a USB plug, where is the best place to get connector? I wouldn't mind plumbing in an a charger for the back seat. TIA.
2014 328d XDrive Sedan, M-Sport Estoril Blue
Former: 1999 F250 7.3L, 2000 Jetta TDI, 2009 Jetta TDI |
01-27-2022, 09:17 AM | #138 |
AH3 Owner
201
Rep 305
Drives: BMW 335i ActiveHybrid 3
I'm still surprised how much depth this gives you. You can't fit anything in there conveniently before you take the uneven cradle out, after that, it becomes a well. 100% worth it.
03-04-2022, 03:59 PM | #139 |
Rep 8
08-05-2022, 08:40 AM | #140 |
Rep 519
Anyone know if you still use the 51169227902 mat in a 2017 340i? My charger looks a bit different than the ones I'm seeing here.
2017 340i M Sport Alpine White / Coral
Dorch Stg2, CTS catless, xHP, Custom E50 Tuned by Shoup |
10-13-2022, 09:22 AM | #142 |
Rep 2
I need your help please! If you know how, I recently bought my BMW 328 and they set CarPlay up thru a usb that is connected under this black hole thing… I think the usb is loose and needs to be replugged because sound is only playing from the left side of my car but on regular radio all speakers work. I need to get under this black thing to replug it… would you know how?
10-27-2022, 06:18 PM | #144 | |
Rep 50
The correct Fakra connectors are available.... somewhere, but reusing the original from the phone cradle seems doable. The cradle will be going in the bin anyway. Last edited by Jakeinaka; 10-28-2022 at 03:07 AM.. |
11-04-2022, 01:40 PM | #145 |
Rep 1
Console cigarette lighter socket not working
Hi... I was able to remove my in console wireless charger and reclaim some much needed console space. It was fairly easy with this post. The only thing I noticed is that my cigarette lighter socket on the back of the console near the rear temp controls does not work. I reattached the temp control wire and the wire to the lighter socket. Has anyone else experienced this. The other connnectors (2 of them) went away with the wireless charger. Thanks for any advice.
10-27-2023, 09:57 AM | #146 |
Rep 125
Have you got a link (i know its along time ago now) as to something i can do the same with? ive got an old ipod hanging around with loads of films and music on id like to install like yours.
03-08-2024, 11:25 AM | #147 |
Rep 4
Insert Storage box
I also removed my useless cradle.
But since I was not gonna pay 30+ € for a piece of rubber, I did some measuring and made a 3D-printed insert. I put some 'faux-leather' trim on the bottom and voila! Last edited by Tatanka1961; 03-08-2024 at 11:37 AM.. |
