BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > 328i JB4 (Stage2) E85, 13.0@109 Run
      08-08-2013, 12:11 AM   #23
SergioK
Drives: F30 328i
Originally Posted by RSXDC5 View Post
To get to the desired 100oct to run Map7, I mixed my 91oct with 45-50% E85 (~105oct) as recommended. I can't speak for the N20 engine, but the N26 that I have will not successfully work with a 45-50% E85 mix while close to or at WOT. The engine hesitates, studders, and bogs down. To troubleshoot at the time, I switched to Map2 and then Map1, all Maps had the same problem. Once I filled up again, I blended my 91oct with enough E85 (roughly 15%) to get to 93oct so I could run Map2. Once I did this, all problems went away...this applies to Map1 as well. In the future, if I would like to run Map7 again, I'll have to fill up with 100% (traditional) 100oct.
At what rpm did the engine start to display this behavior?
      08-08-2013, 12:26 AM   #24
RSXDC5
RSXDC5's Avatar
707
Drives: M3
Always between 3400-5000rpm, but *usually* around 4100-4800rpm
2015 M3 - AW 6Spd w/ CCB
MCS 2WR Dampers, Spec Twin Disk Clutch, MaxPSI CH, F80Paul Ethanol Tune, 3.5in DPs
      08-08-2013, 04:51 AM   #25
MyFragileHalogen
Drives: '16 M4 6MT
Did you install flex-fuel wires? I didn't get any problem when I ran map7 with 50% E85 on my stock n26. However, Terry pointed out there's some undesirable overboost after seeing my datalogs, and told me to wait till the solenoid is controlled. So I am going to stay on map2 till then.
By the way, the huge delay I see between boost and target curves on datalogs due to lack of solenoid control makes my butt really get excited about the improvement that will come when the beta is over....and the answer to that is pretty much written on the top of this thread!
      08-08-2013, 08:43 AM   #26
SergioK
Drives: F30 328i
Is your car an AT or MT? What gears does it do it in?
      08-08-2013, 11:39 AM   #27
RSXDC5
RSXDC5's Avatar
707
Drives: M3
8AT
It did it in all gears as far as I can remember, and to answer another post, yes I have the flex fuel wires installed as well.
      08-08-2013, 11:45 AM   #28
slmdgee
Usofstance
Drives: 328I 6SPD
What do you mean by solenoid that is controlled?
2013 328i 6MT Bagged
IG Stu_UnitedStatesOfStance
United States Of Stance
      08-08-2013, 08:00 PM   #29
SmokeShank
Drives: 328xi M-Sport
The n26 has electric wastegate (solenoid). BMS is working on trying to be able to control this to be able to turn the boost up more. N26 motors are limited right now due to no pneumatic wastegate.
      08-08-2013, 08:34 PM   #30
slmdgee
Usofstance
Drives: 328I 6SPD
My n20 also has an electric wastegate...
      08-08-2013, 08:41 PM   #31
RSXDC5
RSXDC5's Avatar
707
Drives: M3
Yeah there are a small percentage of early 2013 builds that have the N20 w/ electronic wastegate, but the great majority of 2013 builds are N26's with the electronic wastegate. Correct me if I'm wrong!
      08-08-2013, 08:42 PM   #32
slmdgee
Usofstance
Drives: 328I 6SPD
Mine is a 6spd with the electronic waste gate fml! Anyway to get manuals ?
      08-08-2013, 08:44 PM   #33
RSXDC5
RSXDC5's Avatar
707
Drives: M3
Haha, I think we are just going to have to wait for someone to gain wastegate control, just keep your fingers crossed with BMS
      08-08-2013, 08:54 PM   #34
slmdgee
Usofstance
Drives: 328I 6SPD
:mad0 259:
      08-09-2013, 09:43 AM   #35
Jamesons Viggen
Drives: '98 M Roadster stg 2+ S/C
At this point, most N20's are now outfitted with the electronic wastegate.
'98 Dinan/RMS stage 2+(VAC cams, CES Cutring etc)
'15 Buick Regal "T"(wife)
'06 Saab 9-5 Combi 5mt (full suspension, LSD, clipped turbo etc)
      09-09-2013, 04:12 PM   #36
SmokeShank
I haven't seen a pneumatic waste gate car in over a year. EVERY new car prep has been electric
      10-30-2013, 01:05 PM   #37
NosceTeIpsum
Drives: 2013 328i xdrive
+1 should we wait and see what happens? I want to get stage 2...
I really think this engine has the potential to get close to 400hp
      10-30-2013, 03:43 PM   #38
David328M-Sport
Australia
101
My car has had stage 1 since lat Feb. Fantastic. The car has the electronic waste gate, so the connector is wrapped up & sits with the control box.
I'm very happy to sit and wait for stage 2 to come out of beta before upgrading.
Currently, stage 1 is ample for me, but it would be nice to upgrade as well.
328i M-Sport, Estoril Blue, Carbon XP 35 Tint, front heated seats, black Dakota, Sports Suspension, Anthracite Headliner, HUD, Pro Nav, Sunroof, hk 600w, Bi-Xenon, 19" 403M wheels, Reversing Camera, DAB+, Xenon, BT Ext Connect, MST turbo intake pipe, MST Cold Air Intake, JB4 on Map 2 with Catless DP produces awesome performance in Sport.
      10-31-2013, 08:23 AM   #39
NosceTeIpsum
Makes sense, ill take your advice
      11-09-2013, 03:14 PM   #40
leon_516
Anybody know where to buy the stage 2? I can't seem to find it anywhere.
      11-09-2013, 07:48 PM   #41
David328M-Sport
Australia
101
You can buy if from Mike at n54 Tuning.
http://www.n54tuning.com/index.php?_...08197c970e805c
      11-11-2013, 08:39 AM   #42
the pulstar
Drives: 2012 bmw 328i sportline
Any word as to when stage 2 will be out of betta?
      11-11-2013, 06:06 PM   #43
SR20Fastback
Drives: 2012 F30 328i
Can't wait for my stage 1 to arrive in the mail (hopefully this week), but excited to hear about when stage 2 will be out of beta...
      12-15-2013, 08:39 PM   #44
SR20Fastback
I'm having this exact same issue right now! It's not every gear/every time I go WOT, but it's pretty damn close. Did you ever try this with pure 100 octane rather than a mix of 91/E85? I might do that once my tank has been drained some more if you had better luck with actual 100 octane.
