01-20-2013, 05:36 PM | #23 | |
Usofstance
78
Rep 671
Lets say it was rubbing so bad i almost killed my tire in 10 mins of driving. Check my picture out. If your car is higher than mine you will have no issues but if not you will run in to issues.
2013 328i 6MT Bagged
IG Stu_UnitedStatesOfStance United States Of Stance |
01-21-2013, 11:40 AM | #24 | |
Rep 556
Drives: 2012 BMW 335I
My height I am currently at is pretty much the same in your picture.. |
01-23-2013, 10:34 AM | #25 |
[Versatile]
378
Rep 1,683
19x8.5 ET 35 (Front)
19x9.5 ET 38 (Rear) w/ 1.3 inch drop in the rear - Will I rub?!
'02 TS E46 330xi - SOLD
'06 SGM E90 325i - SOLD '13 AW F30 335i ///M-Sport 6MT. OEM(+) - SOLD '20 AW F87 X3MC - Sold Current: `23 Chalk G80 M3CX | Ordered: '24 M3CS - Week37 build. Last edited by nsquared; 01-23-2013 at 12:29 PM.. |
05-03-2013, 07:06 PM | #26 |
Founder of Bimmers.cn
Rep 77
What's your LM's ET? Front & rear?
2017 F85 X5M
2008 E86 Z4 3.0Si |
05-06-2013, 11:02 AM | #27 | |
Rep 16
I see that you have the 335i muffler on your 328i, may i know if you need an adaptor for that, coz i m wondering if the downpipe on a 328i is smaller than the 335i? Hi all, i have been discussing with my friend and since we are planning to install forgestar CF10 Front: 245/35/19 8.5 ET35 and Rear 255/35/19 9.5 ET42. I wonder if the rear will rub? any suggestion? Tks in advance Chris |
05-06-2013, 11:48 AM | #28 |
Rep 1,029
Drives: 2019 440xi Gran Coupe
Is it safe to say for a square setup, I should go with 19x8.5 ET35 235/40/19.
What about 19x9 ET35 with 235/40/19? Stock would be 225/40/19 |
05-12-2013, 09:08 PM | #29 |
Rep 21
I'm running on H&R sport springs, and want to get new wheels and tires. I'm planning to buy the VMR VB3 19's, 19x8.5 front and 19x9.5 rear, but not sure about what offset and tire fitment I should go with. Any suggestions? thanks!
07-03-2013, 10:56 PM | #30 |
Rep 937
Drives: F30 & F25
I'm on 8.5 ET35 Front & 9.5 ET40 Rear, the rear looks flush but the front definitely need a spacer, I'm thinking of 5mm, my friend say 10, I just want to even out with the rear, what do you guys suggest? 5 or 10mm?
some lip, some springs, some brakes, some wheels.
07-04-2013, 06:02 AM | #31 |
Rep 5,140
Beautiful wheels!
What tire size did you chose front and rear? You dont have possibility to borrow either 5 or 10 mm and try? Hard to give advice only based on your photos, but i think 5 mm might be enough. |
07-04-2013, 04:49 PM | #32 |
Rep 937
Drives: F30 & F25
The tires are 225 front and 255 rear, my thoughts are it should be able to take a 10mm without any rubbing but it will not be even with the rear, it will stick out a little further more than the rear. 5mm should evenly flush with the rear. I'm not those hellaflush person, don't need to push it all the way out till it almost rub~
07-15-2013, 06:40 PM | #33 |
Rep 937
Drives: F30 & F25
I got 5mm put on the front, I felt that I really should have gone with 10mm, any suggestions? Should I go another 5mm/7mm further out in the front? Thinking on a set of 12mm spacers to be put on the front.
02-25-2015, 12:09 PM | #34 | |
Rep 47
hey Taichi, did you ever go with a 10mm spacers in front? i have 8.5 with 35et on my f30 335i, in the front as well and was thinking about going with 10mm spacers too. if so, any rubbing against the fender well while turning? pictures with it? i did the same on my m4 by putting on 5mm spacer and was thinking i could of gone 10mm instead, but was afaid of rubbing... don't want to make the same mistake again with ordering spacers fot the f30 though.. thanks in advance!!!! |
07-22-2015, 07:59 PM | #35 |
Rep 22
Hey guys,
will mine Advans from my old E90 fit on a F30, details as follows. (19 x 8.5) Offset: 35mm Backspacing: 6.10" Bolt Pattern: 5-120 Rec. Tire Size: 235/35-19 Weight: 31.0lbs. (19 x 9.5) Offset: 35mm Backspacing: 6.61" Bolt Pattern: 5-120 Rec. Tire Size: 265/30-19 Weight: 32.0lbs. Wheels are sitting in the garage atm doing nothing. Last edited by icandy; 07-22-2015 at 08:01 PM.. Reason: Picture |
07-31-2015, 09:46 PM | #36 | ||
Rep 417
07-31-2015, 10:25 PM | #37 | |
Rep 1,035
sick stance tho bro... just complete FILTH in my hall of fame for sure - luv it!! |
08-01-2015, 05:09 AM | #38 |
Rep 118
02-16-2021, 07:58 PM | #40 |
Rep 870
Hey man I don't think it will be an issue et30 for the fronts would be a better set up also this thread is over 5 years old try to look for newer more updated ones as info changes.
mburchette4.50 |
02-17-2021, 07:25 PM | #42 |
Rep 870
