10-30-2015, 02:00 PM | #177 |
Rep 40,733
PM sent.
11-06-2015, 06:18 AM | #179 | |
Rep 40,733
I have no idea on "shadow codes". I never worry about them.
11-08-2015, 11:30 AM | #180 |
Rep 6
Hi all,
I recently started coding my 2013 F31 330d msport touring and successfully coded a number of the usual items so decided to have a look around the svt at other modules to see what they do. The car is a good spec with a lot of the options already fitted such adaptive m sport dampers, variable sport steering, enhanced function NBT with BMW assist, adaptive visual pack etc Cut a long story short I found a function called m_performance_hard and switched it to activ which I foolishly thought may give me another harder damper level above sport+. After coding it threw up a chassis fault in the check control so I went back in and changed it back thinking that would sort it but the car still flags a chassis fault every time I start it even though that option is now back to nicht_activ. Any advice how to resolve this or have I royaly ballsed up? Thanks in advance Brad. |
11-08-2015, 11:37 AM | #181 | |
Rep 40,733
Click "External Applications" in the left menu. Click "External Application" Double-click "Transmitter" Scroll to the bottom and click "14 FF FF FF,31 01 0F 06,31 01 40 00 00,31 01 40 00 05,31 01 40 00 01;Clear all DTCs (clear DTC,clear Infospeicher,ZFS – DM_Lock,clear ZFS – DM_Clear,ZFS – DM_Unlock)" Click Connect Click Send
11-08-2015, 07:52 PM | #182 | |
Rep 6
Thanks for the reply, unfortunately this didn't work and it still gives a warning gong at start up saying "chassis - drive moderately" 😔 |
11-08-2015, 08:53 PM | #184 | |
Rep 40,733
No.
11-09-2015, 09:23 AM | #186 |
Rep 40,733
What if any ECU's do not have CAFD, or have CAFD named cafd_ffffffff-255_255_255?
11-09-2015, 02:58 PM | #187 |
Rep 6
11-09-2015, 03:03 PM | #188 | |
Rep 40,733
If E-Sys and Tool32 cannot clear error, I don't know what is going on. I would reset all ECU's by VO Coding them with original FA and see if error goes away.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE Last edited by shawnsheridan; 11-09-2015 at 03:16 PM.. |
11-09-2015, 03:07 PM | #189 | |
Rep 6
So now I should use the original FA file that I saved before doing any coding yes? And read the instructions on how to VO code 👍🏻 |
11-09-2015, 03:22 PM | #190 |
Rep 40,733
Yes, just load original FA, and Right-Click on any ECU you previously coded and select Code.
11-30-2015, 03:04 AM | #191 |
Rep 30
11-30-2015, 06:27 AM | #192 |
Rep 40,733
PM sent.
12-03-2015, 10:04 PM | #194 |
Rep 40,733
PM sent.
12-04-2015, 04:50 PM | #196 | |
Rep 87
Looking for EDIABAS / E-Sys / Tool32. Thanks!
'22 M240i Portimao/Cognac
(Sold) '14 335i Estoril/BK • M Sport • Prem/Tech Pkg • M Perf INTR • VMR V710FF • Shifteck DP (Sold) '95 M3 Avus/Dove • PSS9 • Vorschlag Camber Plates • 3.46 Torsen Diff • etc. |
12-04-2015, 05:34 PM | #197 |
Rep 40,733
PM sent.
