11-11-2014, 12:46 AM | #1 |
Rep 161
Uneven Rear Height after Dinan Spring Install
Hi guys,
I just replaced only the rear OEM springs with Dinans (got late, didn't have time for front) and I noticed the rear passenger side sits lower than the rear driver side. Is this normal? |
11-11-2014, 12:58 AM | #2 |
Rep 766
Give it a day or two
Well weathered leather, hot metal and oil, the scented country air.
Sunlight on chrome, the blur of the landscape, every nerve aware! 2014 328ix EBII - Sport AT, Light Pkg, Blk Dakota, Moonroof, Navigation, Heated Seats, HK Audio, Driver Assist, Sport Pedals, Dinan Springs, Bilstein B8s, M-Performance BBK |
11-11-2014, 12:38 PM | #3 |
Rep 1,556
Give it some time or 100-150 miles. Springs can settle uneven as well. It is not uncommon for one side to be up to 1/8-1/4" off.
11-11-2014, 05:47 PM | #6 |
Rep 4,635
yes this is normal. This is because when you sit in the driver seat to drive it sits even. If they were equal when there was no load the drivers side would sag while driving.
Honestly should sell those dinan springs and purchase A real suspension upgrade. IE full coilovers. Dinan is a rip off and minimally improve anything
Follow my BMW instagram @CARMODIFICATION Let me know you are from bimmerpost and i'll follow back
04-07-2018, 09:01 AM | #7 |
Rep 177
I did this same exact search because I'm experiencing the same exact "issue" (if it's even an issue). I'm going to contact Dinan to see if this is expected even after a 4 week settling period.
///437m wheels///Depo Headlights ///3M 1080 Carbon Fiber Interior Wrap///M-Sport Bumper Conversion///Dinan Suspension///M-Style Kidney Grilles
"If we knew what it was we were doing, it would not be called research, would it?" |
04-07-2018, 11:08 AM | #8 |
Rep 808
Sounds like you've double checked everything, but if the problem persists take a look at that rubber piece at the base of the spring. When I installed my coils for the first time I had this problem as well, but visually from the outside everything looked installed correctly. The spring itself was seated in the rubber mount, but the mount was wedged into the hole at a weird angle, so it wouldn't go in all the way. Once I relieved the pressure on the spring I was able to fully seat the mount and then everything was all good.
04-07-2018, 12:36 PM | #9 |
Rep 1,568
Recommend viewing this thread: http://f30.bimmerpost.com/forums/sho....php?t=1355149
It appears the consensus (not all by any means) is that the suspension is designed for the Drivers side rear to be about 1/4" higher than passenger rear side when the car unoccupied and not loaded down. With the heavy Battery located in Right rear and gas tank layout. the speculation is that when a "normal" sized driver (no idea what is considered "Normal") gets in, the difference is reduced to minimal. I had a 1/4" difference on my 08 E90 335i and on my 13 F30 335i. So if you are seeing only about a 1/4", i suspect all is good. |
d_a_m92.50 |
04-08-2018, 11:19 PM | #10 |
Sedan Driver
389
Rep 1,018
That's odd. I've seen it only occur on xdrive f30s. do you have rwd or xdrive and did you get the correct corresponding springs?
Slapping on M Performance parts, ZHP, badges, and stickers does not ///M car make
ZCP | ZHP | ZTR | ZE0 | MSport | ZMP | DHP | MStickerPack | THP | MPPSK | MPPK BMW MSP Lightweight Jacket | DTM Motorsport Team Cap| BMW M Drift Cat 5 | BMW M Thermo Mug |
04-21-2018, 07:13 AM | #11 |
Rep 256
Mine is still 1/8-1/4 lower on passenger side after 20,000 miles but doesn't bother me as I know when I'm in it its even.
2013 335i xdrive BSM Sportline: FBO (ER FMIC, catless DP, CP, TIC, AFE dry filter, JB4 Map 2 or 5), Dinan springs, Doss Wheels (19x8.5), DWSO6 255/35/19, M4 Style Rear Spoiler, M Grille, Painted Whiskers/Front Reflectors
Previous: 2006 330i (stock), sold at 152k miles after 10.5 years |
