BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Help with Comfort Access: 2nd Touch to unlock does not unlock all doors?
      11-20-2012, 02:47 PM   #1
ewill858
Drives: 2013 335i M-Sport
I'd really appreciate a confirmation to see whether I have a malfunction in my Comfort Access feature, or whether I am misunderstanding something.
In my Idrive settings, under Door locks-> Unlock Button, I have it set to "Driver's door only".
If when the car is locked, I touch the inner part of the external door handle, the driver's side door unlocks as expected. However, if I touch it again, the other doors do not unlock. I can unlock the other doors by using the button on the center console, or by using the CA on the passenger side door.
Of course, if I set the Idrive setting to unlock "All doors", it works as expected.
However, I'd like to know if other folks are able to use the "Driver's door only" setting, and unlock the driver's door first, and then the other doors with a 2nd touch?
Thanks in advance!
      11-20-2012, 02:54 PM   #2
Cyberdemon
Cyberdemon's Avatar
1538
Drives: 2020 X5 40i, 2018 M3 Comp
I asked this question before since it's a common feature on most other cars with keyless entry. As far as I know, the answer is no. I just set it to unlock all and left it as is. If someone jumps in the passenger seat and murders me I'm SOL.
Wouldn't be so bad if they put an unlock switch on the drivers door, at least then you could unlock the other doors without getting in the car.
That is one of those German oversights that makes me want to yell at their engineers.
Current: '20 X5, '18 M3 ZCP
Previous: '11 E90 335i, '11 E90 M3, '16 VW GTI, '15 M235i, '13 335i, '08 TL-S, '00 Corvette
      11-20-2012, 04:01 PM   #3
ewill858
Thanks for the reply, and sharing your experience. The strange thing is that if you use the key fob, and press unlock a second time, the car will unlock all the passenger doors. I'm surprised that the CA doesn't work the same way. I guess I'll set the Idrive to unlock all the doors at once and take my chances.
      11-20-2012, 04:27 PM   #4
shivaswrath
shivaswrath's Avatar
Drives: 2012 335i
Thanks in advance!
You have to set it as all to get all te doors unlocked using your hands with CA...goofy huh?
SOLD: 2012 335i Mineral Gray
      11-20-2012, 04:38 PM   #5
sr5959
Drives: 428GC M-Sport
Never really got the point of this 'unlock driver's door only'. If someone is crazy enough to jump in your car while you're getting in wouldn't they just do it from the driver's door?
      11-20-2012, 06:43 PM   #6
zagaone
Drives: 550i sport
In my 550 I just pull the left passenger handle if I need all doors to unlock. If it is just me I pull the driver door handle. Both handles are within arm reach.
      11-20-2012, 06:48 PM   #7
DarkTrigger
Professional
DarkTrigger's Avatar
Drives: 335i MPPK
Only the front's have CA.
      11-20-2012, 06:56 PM   #8
zagaone
Drives: 550i sport
I guess they are different CA systems. In series 5 you can open or close all doors from any doors. Setting the system to "Driver door only" allows the choice as stated above.
      11-20-2012, 06:58 PM   #9
DarkTrigger
Professional
Drives: 335i MPPK
Mini 5 series means we get 1/2 the standard features
      11-20-2012, 11:49 PM   #10
c.cash
Drives: 2013 328i modern line
This is a nuisance. A small one, granted... but sometimes it's the little things in life. Which is why, I admit, Comfort Access was a big reason I bought the Premium Package. I'm used to having automatic unlock/lock and knew I would miss it.
But the setup in the 3-series is lacking. You should be able to touch the rear doors (ok, it would cost more to implement -- I'll give 'em that) to open them. At least add the ability to touch the driver's door twice to unlock all the doors. And I can't get used to the unlock being in the middle of the car instead of on the driver's armrest.
      11-20-2012, 11:56 PM   #11
DarkTrigger
Professional
Drives: 335i MPPK
I think most BMW's are like that. My old Z4 had it in the center console.
      11-21-2012, 05:38 AM   #12
jsedlak
jsedlak's Avatar
Drives: F30 335i 6spd
I think it's a matter of striking a balance between options, usability and not over-engineering the car.
In terms of usability, the efficiency provided by CA falls apart if you have to touch the car twice to get it.
      11-21-2012, 08:53 AM   #13
Cyberdemon
Cyberdemon's Avatar
1538
I wouldn't agree with that. My wifes Nissan is 1 push for the drivers door, 2 for all the doors. It's not capacitive so it's easier to just quickly double tap the button.
That's also the standard I've seen on most of the new cars that I've rented from Chevy/Ford.
I don't have a real issue with it, but the wife thinks someones always going to pop out and car jack her.
      11-21-2012, 10:52 AM   #14
vern
Drives: 2012 F30 335i Sport 2006 X3
IMO if its such a "nuisance" I would trade it in for another make car that would make you happy.
cheers
vern
      11-21-2012, 04:04 PM   #15
c.cash
cheers
vern
Say Vern... so if I don't like every little thing about the car, I should just go trade it in? (or at least I shouldn't bring it up in a thread about it)
What excellent advice!
      11-22-2012, 07:25 AM   #16
emtrey
emtrey's Avatar
92
Drives: 16 M235IX, 06 Carrera S, 335i
if you have your passengar grab the passenger side door handle, all doors will unlock. OR, just touch the pass. side button before going to drivers side
Weird, but, it works.
      11-22-2012, 07:30 AM   #17
fshubert
fshubert's Avatar
89
Drives: 2015 F30 335i
I noticed that too. Was fine when I open the door for my wife when are out in my car, but when I pick up the dry cleaning, was a pain that only the driver's door unlocks. So I set the car to open all doors rather than just the driver door. Minor thing.
2018 Mustang GT | Royal Crimson | Black Leather | 6-speed | Cold Weather | Premium Pkg | 20" Alloy Wheels | Tuned to 510HP | Less than $45K
Previous loves: 2015 F30 335i / 2013 F30 335i / 2009 E90 335i / 2007 E90 328xi
      11-22-2012, 10:34 AM   #18
vern
Say c.cash to bring it up is one thing but to whine about it is another.
cheers
vern
      11-22-2012, 10:44 AM   #19
Elk
Drives: 2012 335i
As well as perceived tradition. BMW buyers are a conservative bunch, a conservatism to which BMW actively caters.
It is fascinating to witness the howls of protest when BMW makes a small change, be it styling or function.
The trick seems to be to pretend the irrational aspects of these cars equal personality.
      11-22-2012, 11:22 AM   #20
SubzeroVR4
SubzeroVR4's Avatar
70
Drives: F80 M3/F85 X5M
If you touch the CA twice how would the car know the difference between locking and unlocking?
Then we'd see a thread "Comfort Access Unlocking All Doors When I just want to Lock the Vehicle"
'16 BMW M3
'16 BMW X5M
'23 X3 M40i (On Order)
'21 Civic Type R
      11-22-2012, 02:22 PM   #21
c.cash
You touch a different part of the handle (above the key hole to lock it).
      11-22-2012, 02:29 PM   #22
c.cash
cheers
vern
It's just a criticism of the CA design -- if there's the slight chance that BMW engineers look at forums like this for feedback. But you've wasted 2 of your first 8 posts on this forum criticizing... me, and quite rudely. I'll never stop being amazed at how people will talk to others behind the anonymity of the Internet.
"Cheers"
