06-14-2015, 11:05 AM | #1 |
Rep 5
F3X refitted F80 Dashboard. (90%)
I had refitted the F80 dashboard on my F34.
The degree of completion is about 90%. But...Now, the trouble is (1) the right-side area can not show the stalls as below: (2) can not show the digital Speedometer ( even if FDL the kombi module: BC_Digital_V = aktiv) Last edited by yourkey0718; 06-14-2015 at 12:25 PM.. |
06-17-2015, 07:50 AM | #4 |
Rep 3,225
Not sure if it is the extended display content (efficient dynamics)?
There is a setting on the IDrive where you can turn that off, maybe yours is turned off? Can't help you with the speedo, it's useless anyway. |
06-17-2015, 09:56 AM | #5 |
Rep 5,316
Drives: G80 M3 6MT
Did you have an extended contents cluster before? If not you might need to add that (6WA) to your VO and then code.
Scott, Partner
Insight Automotive Consulting Click HERE for all discounted BMW New Car Pricing Click HERE for all BMW In Stock Inventory Specials Call/Text: 516-416-5481 Email: scott@insightautoconsulting.com |
06-17-2015, 08:04 PM | #6 |
Rep 1,374
Drives: Audi R8 v10 Spyder
Is the coding for the F80 cluster similar to the 6WA Extended cluster? Did some of the functions work before you coded it?
06-22-2015, 10:19 AM | #8 |
Rep 931
Any info about coding in order to display gears ?
BMW F82 M4 Black MHD CS Map - GTS DKG - Navi -Performance Brake RSL1 Pads - USB - DivX-DVD - Bluetooth - VoiceControl - Connect - Apps - Online - H&K - TrafficInfo - SpLimInfo - WhiteMerino- PDC - Cam - Adaptive Led - Antitheft - CP Steering- Performance ST - Adaptive CP Setup - GarageDoorOpen - Pipercross - Stock Exhaust - Mdrivers Pack - 437M Wheels
10-06-2015, 09:54 PM | #10 |
25cent millionaire
252
Rep 1,220
Drives: 2020 m4 comp vert
if i just have the basic dash can i due this upgrade?
10-08-2015, 02:29 AM | #11 |
Rep 931
Fake for my point of view.....
10-21-2015, 03:50 AM | #12 |
Rep 84
You shoul have manual gearbox on your car.
Fluffy Russian СaT
01-22-2016, 03:05 AM | #13 | |
Rep 1,637
