03-09-2018, 11:40 PM | #1 |
Rep 26
TIC Charge Pipe
I know that replacing the Charge Pipe on the throttle body side to metal is important, but I was looking to maybe get the Turbo to Intercooler side changed too.
Is the TIC side nearly as important to get changed out to metal, as the throttle body side, or will it be fine with the stock plastic pipe? (FYI I only run a piggyback and may do a down pipe in the future) Just looking to get everything done at the same time I upgrade my intercooler. |
03-10-2018, 03:18 PM | #4 | |
Rep 26
Thanks guys. |
03-13-2018, 06:34 AM | #5 |
Rep 95
Mine did crack
So my stock TIC did crack. However I replaced it with another new stock one because the dealer had it in stock and I use my vehicle as a daily driver. My intent was to baby it until I could get a metal one in. Long story short I never got around to ordering the metal one and the stock one is still on there and has yet to crack on me since. Been about 2 months now.
03-13-2018, 08:56 AM | #6 | |
Rep 2,382
2013 F30 328i: MHI Big Turbo, GFB DV+, Mishimoto CAI, ER TIC/CP/Catless DP, AWE Touring Quad Exhaust w/ Resonated Midpipe, NGK LI Plugs, BM3 with PTF Stage 2 91 AGG Tune, Fuel-it Stage 2 LPFP, Solowerks S1 Coilovers, and DEPO/M-Sport Retrofit |
03-13-2018, 11:12 AM | #7 | |
Rep 3,533
The 328d uses the rubber hose type TIC pipe too, and stock boost is 26-27PSI. It also uses the rubber hose type on the IC to intake side too. |
03-14-2018, 10:22 AM | #8 |
Rep 95
At the turbo. It is a more flexible plastic ( I wouldn't call it rubber) in the center and hard plastic on either end on my 328i.
03-16-2018, 04:36 PM | #10 |
Rep 115,955
The TIC is a good idea if you are doing the FMIC and the Charge pipe.. I wouldn't do it unless you are doing the full FMIC setup as its a PIA if you are not actually doing the FMIC at the same time.
Mike |
BunkerJ1032.00 |
03-16-2018, 10:30 PM | #11 | |
Rep 26
I was planning on doing the Charge Pipe and the vrsf street core IC at the same time |
03-17-2018, 10:09 AM | #12 |
Rep 2,382
That would be Chargepipe, FMIC, and TIC.
