03-15-2018, 11:28 AM | #1 |
Rep 19
Another tire case .......... all rise!
Hello all. new to the forum and Xdrives but not to BMW's. I know at this point is like beating a dead horse but as you all know all cases vary when you get into specifics as such.
So I placed my 99 Firebird new set of MRR wheels and Continental Extremes tires on the F30 M xdrive. All fit perfect after adding a 3mm spacer in the back to clear the M calipers. Drove it for a bit but something feels off. A bit of hesitation on accelerating at any speed. Fronts 245/35/19. 8.5 wide Rears 295/30/19. 9.5 wide My question is, what is my percentage on the above set up? Do I just change the rears to a 275/30/19 and be ok or will I have others concerns to look out for? I saw on another thread someone stating NOT to go with the 35 F / 30 R profile. Any reason for this? Thanks First Thread. |
03-15-2018, 11:59 AM | #2 |
No 55mph
1619
Rep 8,476
I have been running 245/35-19 Frt & 275/30-19 RR tires on same width wheels as yours, on my 435iX, for years with no problems - they are within the 1% difference suggested
03-15-2018, 12:00 PM | #3 | |
Rep 483
In theory 285 (instead of 295s) in the rears would be even closer to the fronts, but you don't necessarily want to spend that much money on tires to realize it was something else... might wanna get it checked out to make sure it isn't something else.... |
03-15-2018, 12:34 PM | #4 | |
Rep 19
So you are telling me that 285's would be a better choice instead of the 275's? I have to learn how to calculate this crap. I can't find the calculator I ran into earlier on a thread. |
03-15-2018, 01:15 PM | #5 | |
Rep 47
03-15-2018, 01:26 PM | #6 |
Rep 4,315
actually...245/35/19, 275/30/19 is 1.2% however if it's been working for you maybe we should note that as the max difference for x-drive.
03-15-2018, 01:36 PM | #7 |
Rep 19
So this is what came up when I placed my actual numbers.
Size 1: 245/35/19 Front Size 2: 295/30/19 Rear Scale / Size 1 / Size 2 Diameter / 25.8" / 26" / +0.8% Width / 9.6" / 11.6" / +20.8% SideWall / 3.4" / 3.5" / +2.9% Circum. / 80.9" / 81.5" / +0.8% Revs/Mile / 784 / 777 / -7 Correct me if I'm wrong but it seems like this should work just fine. Am I missing something? |
03-15-2018, 01:56 PM | #9 | |
No 55mph
1619
Rep 8,476
245/35-19 = 25.8 Dia (V1) 275/30-19 = 25.5 Dia (V2) https://tiresize.com/calculator/ Percent Diff: (V1-V2) ------------ X 100 = 1.16959% difference - rounding ~1% (V1+V2)/2 Doesn't matter which diameter value you put in for V1 or V2 answer will be the same I don't think .2% has any effect (and I guess not since the car is fine) https://www.calculatorsoup.com/calcu...calculator.php And yes, a 285/30-19 tire would have been better @ 25.7 Dia for a 0.38835% difference ~ .4, plus Revs/Mi would be = @ 784, but at the time that I needed the tires that size was out of stock in the MPS A/S +3's I run that staggered setup only in summer months here in PA so roughly 7 months. Rest of the year I run square setup with OEM size Blizzaks on factory 400M wheels Come next time I get tires I will go for the 285's in the rear
03-15-2018, 01:56 PM | #10 | |
Rep 4,315
03-15-2018, 03:32 PM | #11 |
Rep 19
Fellas thanks for chimming in.
That's what I was thinking, it should be ok. unless their calculator is off. Like swapping wheels from a domestic to a import. LoL I'll post a couple of picture in a minute, Just got home. Last edited by The Godfather; 03-15-2018 at 03:49 PM.. |
03-15-2018, 03:56 PM | #12 |
Rep 19
It's not bad at all. However I think I'm going to add a 5mm spacer up front to equalize the stance a bit with the rear.
01-13-2019, 04:36 PM | #13 |
Rep 468
01-13-2019, 05:30 PM | #14 | |
Rep 106
Drives: 2014 335i xDrive M Sport
01-14-2019, 02:32 PM | #16 |
Not stock
472
Rep 617
The other, other problem is your Firebird bolt pattern is 5 x 4-3/4". BMW is 5x120mm. This means your bolt pattern is 5 x 120.65 on the GM wheels... be careful these don't actually fit. Also you will want hubcentric spacers which you're going to have a hell of a time making in the 3 - 5mm range.
2015 BSM 328i Sport Line - BSM
2015 BSM X1 M Sport - BSM 1992 525i 1987 325e |
01-16-2019, 02:15 PM | #17 | |
Rep 2,044
I ran Enkies with the GM bolt pattern for a few years on my E46, no prob (looked great!). The vendor said others do this too. YMMV! Murf |
01-16-2019, 03:08 PM | #18 | |
Not stock
472
Rep 617
I run GM wheels on my race car that use shank lug nuts (stud conversion). I had to make hubcentric rings (not the same hub size) and then machine the wheels because it was literally bending the wheel studs out which caused false torque readings.
01-16-2019, 04:33 PM | #19 |
Rep 808
Another thing to keep in mind re: tire sizing is that OEM staggered sizes aren't perfectly the same rolling diameter either, the fronts are slightly larger than the rears. I believe this is why the car will tolerate 245/35/19 front and 275/30/19 rear even though a 235/35/19 front gives a 0% difference.
I run the aforementioned setup and even though the fronts are 1.2% bigger I haven't had any issues for about 20,000 miles |
01-16-2019, 07:08 PM | #20 | |
Rep 2,044
Murf |
