06-16-2018, 11:21 AM | #1 |
Rep 585
Results from scan following codes
So as my previous thread Iv had the following codes
Fault codes 030120 PDC 0301A0 PDC 480134 direction of travel cannot be determined (presume this one is the one to throw my chassis light on) 8011F9 internal component failure PTC module CD0487 synchronization for flexray failed Can anyone help of advice me any further what could be the causes |
06-17-2018, 11:37 PM | #2 |
Rep 5,457
Drives: F30
06-18-2018, 06:00 AM | #3 | |
Rep 3,967
Looks like you have fault codes for the parking distance control (PDC) and the air conditioning? (PTC) Regarding code 'CD0487 synchronization for flexray failed', BMW uses flex ray to communicate between some of the modules, so you might get this code if one of the modules is failing. You have a code for component failure on the PTC module so that is also most likely related to that. |
06-18-2018, 06:02 AM | #4 | ||
Rep 585
06-18-2018, 06:22 AM | #5 |
Rep 3,967
06-18-2018, 07:06 AM | #6 | |
Rep 5,457
Drives: F30
06-18-2018, 08:34 AM | #7 |
Rep 3,967
I wonder then if parking distance control codes would throw up a chassis warning then for the OP!? .. or perhaps the error has to be logged a certain amount of times before the warning light comes on?
07-06-2018, 04:44 PM | #8 | |
Rep 585
Shown up a sensor on the shocker and my N/s shocker is leaking and my o/s shocker is on its way out too Apparently the oem shockers can't take the lowering springs so knocks the life down on them next route looking at coilovers good excuse to change them all now |
