BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Is it worth 'unlocking' Sports + mode? F30 316
      12-18-2014, 10:56 AM   #1
RoundRound
Drives: 2017 F30 330e M Sport
Hello,
Appologies if this was already discussed.
I have a 2013 i316 and when visiting an indipendent specialist garage I was offered to re-program the car unlockign the Sports+ mode and other options.
I enjoy driving in Sports mode but not sure if I really need the sports+, as far as I understand this basically makes the throtle even more aggresive (it's a 1/6L engine, how aggresive can it be?) and Also disables lots of the driving safety aids - which I'd like to keep turned on.
What do you think?
Lastly, can this reprograming go wrong? Would BMW fix it if it did? The car is out of warranty. Can it lower it's resale value?
Your thoughts are appreciated,
Thanks!
      12-18-2014, 12:14 PM   #2
carzaddict
Drives: 2015 Cadillac Escalade ESV
Sports+ is the same as Sport...the only addition is that it disables traction control.
the throttle is already more sensitive because of sports mode.
Yes programming can go wrong, it can brick your car if you do something wrong. Something like this wouldnt put your car at much risk...unless the garage is planning on doing more work. BMW will fix it for you...it will cost you a lot if you're out of warranty
2015i Cadillac Escalade ESV
      12-18-2014, 04:47 PM   #3
snowghost
snowghost's Avatar
Drives: '13 335i M-Sport 6MT
You can always revert to the default settings. So I wouldn't worry about bricking.
F30 Sapphire Black M-Sport 335i 6MT
      12-18-2014, 06:29 PM   #4
RoundRound
Thanks guys.
I was told this update could open up many other settings in the car, is it true?
If it's the same as sport (with SDC off) than I won't bother.
Thanks!
      12-18-2014, 11:47 PM   #5
dreamspeed
dreamspeed's Avatar
Drives: 6MT
I don't know what a 316 is but I the 328 and 335 sport+ actually makes the throttle even more sensitive than sport. Too sensitive if you ask me.
It also turns off dsc and turns on dtc
      12-19-2014, 12:52 AM   #6
maldad80
maldad80's Avatar
Peru
Drives: 2016 420i GC M Sport
i have an 316i M Sport, it came with Sport+, i feel this mode more agressive than Sport, rpms get higher in every march
      12-19-2014, 03:16 AM   #7
RoundRound
Thanks Guys.
Are there any other settings that can be unlocked? (Other than Sports+)
Thanks!
      12-19-2014, 11:05 AM   #8
snowghost
snowghost's Avatar
I would think you'd like it having a 6MT. I drive 99% in Sport Mode. Nice smooth quick takeoffs.
