09-15-2015, 08:31 PM | #1 |
Rep 190,725
F Chassis Tune Comparison N20/N26/N55/S55 - LAST UPDATE 09/19/2018 ** Bootmod3 Added
This post is copied from Extreme Power House's Blog
Today, I would like to write about the different piggyback options available for the BMW new F chassis cars. This market is oversaturated with tunes priced from a couple hundred dollars up to a couple thousands. Not all piggybacks are equal, which ones are worth it and which ones are not? Read this post and decide for yourself. DINANTRONICS Sport Performance Tuner How: Connects to TMAP sensor only Pros:
$299 Burger Tuning F Chassis N20/N26/N55 JB+ How: JB+ connects to TMAP sensor only. Pros:
$199 Active Autowerke Active 8 Tune How: A8 tune works by connecting to the Manifold air pressure sensor, boost pressure sensor, camshaft sensor and air mass sensor. Pros: •Since the A8 connects to the camshaft sensor, it controls boost by RPM. The ability to do so offers a smoother / more linear power delivery. •9 different maps (Compatible with catted downpipe cars only and pump gas). •A8 is offered standard with a waterproof enclosure. Cons: •Install process is the most time consuming for a stage 1 tune (although it has quick detach button to uninstall the module, but not the wires). Price: $699 for Non-M models / $999 for M models. AFE Module Scorcher How: AFE scorcher connects to the MAP and TMAP sensors of the car. It alters the pressure sensor signal to increase turbo pressure. Pros: •AFE is easy to install with only 2 sensors. It offers a clean solution for more power. Cons: •AFE Scorcher offers no flexibility for the user. It is available with 1 map only and no option to adjust boost. • It does not have the ability to control boost by RPM, the Scorcher adds a constant boost value across the RPM range. Price: $473 for Non M Models / $627 for M Models Burger Tuning JB Stage 1: How: The BMS JB stage 1 connects to the MAP and TMAP sensors and works by altering the boost pressure signal (identical to AFE and Race chip ultimate). Pros: •Easy install, takes less than 10 minutes. •BMS JB stage 1 gives its users the ability to increase boost if he / she is looking for a more aggressive map (will need an optional $35 BMS Data Cable). •Weather proof box is optional and will cost an additional $59. Cons: •JB stage 1 does not have the ability to control boost by RPM. It adds 3.5 psi across the RPM range over stock boost (value can be changed using the USB cable). Price: $379 for M and Non-M models Burger Tuning JB4 Stage 2: How: The JB4 stage 2 connects to the MAP sensor, TMAP sensor and Canbus. It is also offered with flex fuel wires for E85 users. Pros: •Pre-loaded with 7 maps each optimized based on the car’s modifications and fuel. The Jb4 is also offered with a custom map allowing the user to set his / her own boost targets. •The Jb4 controls boost by RPM. It also controls boost by gear and can set a max boost limit for the first 3 gears in order to achieve better traction control. •The JB4 stage 2 can read / delete codes and auto clear the CEL code in case car has catless downpipes installed. •The JB4 is compatible with E85 fuel as long as the mix does not exceed the fuel pumps maximum capacity. •The JB4 is capable of gauge hijack and can control the exhaust valves for a louder exhaust sound. •Ability to get free firmware upgrades from the user’s laptop without the need to ship the module back every time an upgrade is available. •Option to get the Jb4 with a weather proof case; it will cost the user an extra $59 for the aluminum enclosure (No additional cost for M cars). Cons: •In order to achieve all these pros mentioned above, user will need to purchase the optional USB data cable and / or OBD cable ($17 for the OBD cable and $35 for the USB cable). •Install time takes around 45 minutes because of all the extra connections that the JB4 needs. •If user does not purchase the OBD cable, JB4 will need POSI-Tap wires to connect to the Canbus. Price: $529 for Non-M Models / $799 for M models (Aluminum enclosure and OBD cable is offered with the M series JB4 at no extra cost). Race Chip Ultimate: How: RCU connects to the MAF, MAP and TMAP sensors and work by changing boost pressure signal and tricking the ECU into making more power. Pros: •Easy install •Weather proof box (standard) •3 different maps Cons: •Cannot control boost by RPM Price: $679 for M and non-M models ESS E-tronic Tuner How: The ESS tuner connects to 4 sensors. Intake Cam shaft, Map, TMAP and MAF. Pros: • Control boost by RPM for a smoother power delivery • 3 different maps • Standard weather proof enclosure Cons: • One of the hardest stage 1 tunes to install Price: $995 for all models Dinan Tune How: Dinan connects directly to the ECU to cover as many sensors as possible. It adds a constant boost value to the car across the RPM range (3.0 psi for stage 1 and 4.0 psi for stage 2). Pros: • If BMW denies your warranty claim, Dinan will cover any damages caused or related to any of Dinan tunes or parts • Weatherproof box • CARB certified • Tune monitors and adjust AFR / ignition timing for a smoother power delivery • Increases water pump pressure for better cooling Cons: • You get 1 map with each tune only • Install time takes from 1.5 to 2 hours Price: $1499 for the stage 1 Summary Table: Tune Comparison.doc Active Autowerke OBD Flash Tune How: Connect Simon Cable to OBD port and upload your new map (No ECU removal needed). Pros:
Price: Starts at $800 Bootmod3 By PTF How: Connect Enet cable to OBD port and upload your new map (No ECU removal needed). Pros:
Cons:
Price: Starts at $595
https://x-ph.com/sale/ Phone number 702-494-9435 Last edited by mike@x-ph.com; 10-02-2018 at 11:05 AM.. |
09-15-2015, 09:56 PM | #3 |
Assassin
144
Rep 156
Drives: 2013 F30 335i Xdrive M-SPORT
This is very much needed! There is definitely too many options for piggyback setups. As such I'm very happy with my choice.
2013 F30 335i w/ Xdrive M-SPORT
MHD Tune, M Performance stainless pedals, M Performance trunk spoiler. |
09-15-2015, 11:23 PM | #4 |
Rep 262
Drives: 2013 BMW 335i M-Sport
Great writeup!
09-16-2015, 04:19 PM | #6 | ||
Rep 190,725
The JB4 is offered with POSI-Tap wires that you will need to use in case you do not get the OBD cable. I mentioned that under cons of the JB4 Quote:
Thank you for the kind words guys More tunes will be added soon.
09-18-2015, 12:19 PM | #7 |
Rep 1,721
What about GSR ECU tune and Dinan Piggy-back?
BMW CCA Track Instructor
Join to win a M School Day at the Performance Center! Enter Referral ID: 420186 |
09-18-2015, 12:21 PM | #8 |
Rep 190,725
I will do that later once i covered all the piggybacks
09-18-2015, 04:17 PM | #9 |
Rep 1,721
GSR currently has my Manual 228 N20 ECU. I'm curious to see if it'll be smoother than the JB4 Map 1 I was running before.
09-26-2015, 10:59 PM | #11 |
Rep 93
Just installed a GSR ECU tune on my F30 N20. It is amazing. I love the power gain. The sport transmission and the engine works much smother. Didn't have a chance to do the dyno. Hope to do it soon. I would highly recommend this tune.
09-26-2015, 11:32 PM | #12 |
Rep 190,725
What tune were you running before the GSR ?
10-01-2015, 02:29 PM | #13 |
Rep 190,725
Dinan tune added to the first post and to the summary table
10-01-2015, 03:46 PM | #15 |
Rep 190,725
10-04-2015, 09:24 PM | #16 |
Rep 261
Wait sorry there's a Dinan Stage 2? I only see Stage 1 around
2014 BMW F30 328i - Base line 8AT, Alpine White, metallic black roof, Megan Racing CF decklid, CF canards, CF eyelids, CF rear diffuser, matte black kidney grills, gunsmoke tail lights/reflectors, VMR 721 Hyper Silver 19x9.5/19.x8.5, 5mm spacers all around, Bilstein B8s, Injen CAI, H&R Sport Springs, muffler-deleted quad pipe, 20% 3M rear tint, M Performance Pedals
10-05-2015, 01:21 PM | #17 |
Rep 190,725
Not for all engines. The N20/N26 is not available yet
10-06-2015, 10:38 AM | #19 | |
Rep 190,725
1- you won't have a map optimized to take full advantage of catless downpipes 2- You will get a CEL code. You can take care of the code if you get the BMS can flap module
10-08-2015, 12:21 AM | #20 |
Rep 261
Ohhh okay thanks for the info!
10-15-2015, 09:50 AM | #21 |
Rep 1,721
It is AMAZING. Compared to the the BMS stage 2 (map 1) that I was running before, it's a night and day difference. The total overall power gain is probably pretty similar but the smoothness and immediacy of the power delivery is what makes it worth it, especially in a manual.
With the BMS tune, once I took my foot off the gas, shifted, and put my foot back on the gas, there was a whole 1 second delay before the power came back. I assume that's because the BMS tune is tricking the ECU into thinking it can provide more boost. This delay was driving me crazy, I thought it was the car and not the tune until I got the GSR flash tune. With the GSR, the ECU is reprogrammed to provide that extra boost by default, no tricking anything with fake environmental variables. So the car feels exactly like it did new, just with a lot more power! Very very smooth and immediate power delivery the entire way through the rev range. It's also a lot cleaner, no cables running across my engine bay. Overall I couldn't be happier. I have M235-like power in a car that weighs 250lbs less and cost me 6k less. I'll be at the track this weekend, if there's a M235 there - I'll see if I can get some lap time comparisons.
10-18-2015, 11:28 PM | #22 |
Rep 647
Posted this in the tracking section but figured I'd ask here for a more complete detailed response.
Any cons to running a piggyback and constantly pushing it on the track? I remember reading somewhere that the added boost cracked the charge pipe. I have the A8 tune. |
