05-02-2016, 02:54 PM | #23 |
Rep 446
In that case the advice from others regarding tyres will probably be your best bet.
Current: '71 Tesla M3P.
Previous: F87 M2 Comp, F80 M4. |
05-02-2016, 02:58 PM | #24 | |
Rep 39
It sounds like most people recommend the MPSS tyre then, any other options or do these stand above all the others? Thanks for your opinions everyone! |
05-02-2016, 03:00 PM | #25 |
Rep 39
05-02-2016, 03:01 PM | #26 | |
Rep 8,493
05-02-2016, 03:03 PM | #27 | |
Rep 2,666
335d xdrive 2016 M-Sport
745Le xdrive 2020 M-Sport |
05-02-2016, 03:04 PM | #28 |
Barge driver
8656
Rep 12,425
Could be something as simple as a greasy surface and little bit of adverse camber at the point you planted it rather than an issue with tyres or the drive train, however I was always taught to have the steering wheel straight before opening the taps fully.
My 335d xdrive was stonking in the wet full bore launches with zero wheel spin but was in a straight line.
730d/Z4C
05-02-2016, 03:04 PM | #29 | |
Rep 1,580
I remember watching a video of an independent test where a Subaru and a number of cars with 4wd made by different manufacturers were driven onto an inclined rolling road. They simulated different gap conditions, and if I remember right the Subaru was the only car that could move forward with only 1 driven wheel with grip. Not sure if that relates to the OPs post
G20 320dx. Every option except a tow bar
'20 Subaru XV 2.0. Gone; F30 335dx, F30 330dx, F21 LCI 125d, F48 X1 20dx, F10 520d |
05-02-2016, 03:17 PM | #30 |
Rep 145
I have asymetric 3's on the front of my car and they are excellent tyres for the money. The rears should be available this month as soon as they are they are going on the car. A lot of people recommend MPSS, however, I have been pushing the f1's and the grip is excellent wet and dry.
05-02-2016, 03:28 PM | #31 |
Rep 25,112
Welcome Adam, I think everyone has helped on the drivetrain stuff.
Quick note on the bendy body panels, you're correct I think up t0 6mph the panels just bend and pop back into place rather than shatter, to save you in low speed bumps.
My car made front page of Bimmerpost
05-02-2016, 03:30 PM | #32 |
Rep 1,797
The back will step out if you want it to in the wet with MPSS and ACS springs but it does come back.
The rear bias is evident as my rears are at 2mm after 12k but the fronts have 5.5mm, a few bends may have been wiggled round to help that
G20 M340i
Gone F36 435d F30 335d |
05-02-2016, 03:32 PM | #33 | |
Rep 39
Stating that they have poor resistance to aquaplaning and that they can oversteer easily in the wet. Would you say this is rubbish? Many Thanks, Adam |
05-02-2016, 03:36 PM | #34 |
Rep 39
Thanks Chris! I see that makes sense then, hopefully they pop back with the paintwork still in tact then
05-02-2016, 03:37 PM | #35 | |
Rep 39
05-02-2016, 03:37 PM | #36 | |
Rep 25,112
Any pics of the old Scooby....blue with gold wheels classic?
05-02-2016, 03:45 PM | #37 |
Rep 39
05-02-2016, 03:47 PM | #38 | |
Rep 39
It was a great car, but was definitely time for a change. |
05-02-2016, 03:50 PM | #39 | |
Rep 2,666
I had a evo 7 about 8yr ago loved that car
05-02-2016, 04:03 PM | #40 |
Rep 39
05-02-2016, 04:04 PM | #41 | |
Rep 19,982
The other thing no one has asked about is your driving (don't mean to be cheeky)... you can get the back out on one of these in the wet, but you really do need to be trying very hard or very clumsy with the right foot. So clumsy that I'm now inclined to think you hit a bit of diesel on the road to be honest.
05-02-2016, 04:05 PM | #42 | |
Rep 32,881
05-02-2016, 04:46 PM | #43 | |
Rep 39
Tbh I'm quite a conservative driver but I did want to see if I could safely accelerate out of the corner like I did in the Impreza which I only ever drove to perhaps 70% of its grip limit. I would have perhaps wondered if there was some grease of some sort on the surface but I did it on 2 separate round abouts, and my foot was quite far off the floor and I had come past the apex when I accelerated. I know I couldn't come out of the corner as fast as I could in the Impreza but like I said I only ever pushed the Scooby to approx 70% of its grip limit which is expect the f30 to be able to match which hopefully it will with better tyres. |
05-02-2016, 04:57 PM | #44 | |
Rep 19,982
Seriously, I've a got a remapped 335d, and I can probably completely floor it if I was starting to unwind the lock already and not worry about the tail going anywhere. In fact, unless I was in Sport+ I'm not even sure it would But as a I said earlier, with a 6 pot diesel the torque comes in very strong at 2000rpm, so if you press the throttle hard and fast, rather than squeeze it then you risk that coming in and overwhelming the tyres momentarily. When this happened, did you lift or let the car sort itself out? Between the TC and xdrive it would only ever be momentary,
grip, tyres, xdrive |
