02-07-2013, 08:18 PM | #23 | |
Rep 4,323
Yeah, after looking at it tonight, it'll be tight, but the suspension (especially the struts) have such a rapid and tight rebound, I'll be very surprised if it's an issue given the camber that's naturally dialed in...and if it is, I'm hoping $99 mistake would be the least of my worries.
02-07-2013, 08:42 PM | #24 | |
Rep 941
2015 F15 X5 25d Space Gray | Pure Excellence | Dakota Leather/Brushed Aluminium | Anthracite Head Liner | Fender Flares | Connected Drive + Real Time Traffic
2012 F30 335i Sapphire Black 2006 E92 325i Titan Silver 2000 E46 318i Cosmos Black |
02-07-2013, 08:53 PM | #25 | |
Rep 98
With 8.5" et47 (400M), the centre of the wheel will be 13mm further IN compared to the 8" et 34 (397). With the additional 0.5" of the wheel, it will have extra 0.65mm on both inside AND outside. So the overall effect will just be 13mm - 6.5mm = 6.5mm, i.e., the 400M wheel will appear 6.5mm further IN compare to the 397 wheel. Please correct if I am wrong. |
02-07-2013, 09:36 PM | #26 |
Rep 4,323
Hey guys, spoke to Burgertuning before I ordered, turns out no more than 12mm all around to be safe with the lowered suspension...I'll post pics, they were helpful, so I hope it sorts out!
Ordered a nice set of Jack pads too (lol), my Evo never had these jacking issues...so Euro.
02-07-2013, 10:32 PM | #27 | |
Rep 941
Look forward to the pics Shiv.
02-08-2013, 12:54 AM | #28 | |
101
Rep 1,237
02-08-2013, 09:04 AM | #29 |
Rep 4,323
12mm all around per Jason at Burgertuning.
02-08-2013, 10:50 AM | #30 |
101
Rep 1,237
02-08-2013, 01:52 PM | #31 |
Rep 4,323
Yeah that's what I remember reading. Well, I'll give it a try, and if it doesn't work out, they'll have to take it back + shipping since it was their recommendation!
02-08-2013, 02:34 PM | #32 |
101
Rep 1,237
Well good luck. Keep us posted. A 12mm in the rear would be ideal for sure. I tried a 10mm non-hub-centric spacer one time and it looked near perfect.
02-13-2013, 08:49 PM | #33 | |
Rep 4,323
12mm is PERFECT for the 397's...I would say probably same for the 400M's too... Here's the separate thread with pics...
04-12-2013, 03:10 PM | #38 |
Rep 1,053
They look like the perfect sizes.
Current: 2021 340xi
Retired: 2018 330xi | 2016 340i 6MT | 2013 335i 6MT | 2011 328i 6MT (N52) | 2008 335xi (N54) |
04-13-2013, 12:32 AM | #41 | |
Rep 344
H&R sports with the stock 18" sport lines just does not seem to sit right, so I am going to get the wheels before springs (or m-perf suspension.. they should sit about the same right?). 19" fills the gap so much better. Did you have any spacers in those pics? |
04-13-2013, 07:43 AM | #42 |
Rep 265
My opinion:
Yes, my pics below are with spacers and springs installed.
My opinion: 10mm in front is perfect, 15mm in rear is a bit to aggressive but flush with my stock bubble tires. With different tires it could be perfect. 12mm would have been perfect but H&R only makes 5mm, 15mm & 20mm for rear. 5mm, 10mm, 13mm, 15mm, 20mm front. 12mm rear is supposedly not safe but some have done it anyway with different brands. You can read why by searching this form. H&R Sport springs: I feel less body role, slightly stiffer but comfortable and the sport drop looks sporty and classy. My car has not bottomed out on big pumps but my biggest issue is with small road fluctuations. The front end seams to bounce a bit. Bounce is a little to strong a word but its bad enough that I will eventually change to coil overs. Overall I'm happy considering the look for the low cost. |
04-13-2013, 02:21 PM | #43 | |
101
Rep 1,237
As far as the M-Pref Suspension being the same drop as H&R Sport, that is not the case. The M-Pref Suspension will lower it 10mm more than the US Spec Sport and M-Sport Suspension. The H&R Sport Springs will lower the car about 24mm more than the US Spec Sport and M-Sport Suspension. Again, this is only on the US Spec 335i. A US Spec 328i on M-Pref will still lower the car 10mm more than the US Spec Sport and M-Sport, but the US Spec H&R Sport Springs will lower it less than 24mm in the front due to the lighter engine. Basically, in the USA, we only get the 335i H&R Sport Springs. In the EU, they get different H&R Sport Springs for the 328i and the 335i. Hope this makes sense. As far as ride quality vs performance, it's up to you. IMO, the performance gains of lowering the car is a moot point since most people won't drive their car at it's limit. However, if you do drive your car like that (hopefully only on the track), you should consider more than just swapping out springs. So for daily drivers, I always consider ride quality before performance; and H&R Springs alone will make the ride quality suffer. This is just my opinion and everyone's tolerance for what is acceptable will differ. Hope this helped. |
04-13-2013, 02:49 PM | #44 | |
Rep 344
If I were to really get into autox, i would probably get a lightweight set of 18" arc-7's or something similar, but for daily driving, the 19's are pretty. |
