02-06-2013, 03:17 PM | #23 | |
Rep 101
02-06-2013, 05:35 PM | #24 |
Rep 1,075
What do you think your gut feel on the distribution would be if you tried more times?
1s +/- 0.35s? BTW, I like this thread as it is more real world than the typical drag time that can be posted.
Current: F87 M2 MT MPE, E84 PP SP LP
Previous: F30 - 335i AT, E90 - 335xi MT, E90 - 330i MT, E46 - 330i MT |
02-07-2013, 09:50 AM | #25 |
Rep 1,997
02-07-2013, 10:45 AM | #26 |
[Versatile]
355
Rep 1,683
the 335i needs to be a 10 second car.
'02 TS E46 330xi - SOLD
'06 SGM E90 325i - SOLD '13 AW F30 335i ///M-Sport 6MT. OEM(+) - SOLD '20 AW F87 X3MC - Sold Current: `23 Chalk G80 M3CX | Ordered: '24 M3CS - Week37 build. |
02-09-2013, 01:53 PM | #27 |
Rep 344
I got my stage 1 today (2 days after I ordered it!) and it literally took less than 5 minutes to install it on my 13' f30 335i sport. This is the best video instructions I have found:
02-28-2013, 08:19 AM | #28 |
Rep 70
Testing with JB stage 1
Finally return my car to stock mode and was able to do some baseline testing. Got 0-60 in 5.5 in stock and 5.2 with JB. I thought BMW claims that 5.2 can be achieved with stock car and most magazines are testing to be around 5 seconds? I would expect at least 5 sec with JB. Did my car just happen to be slow?
02-28-2013, 08:53 AM | #30 |
Rep 4,323
Traction/tire pressure can heavily impact this. Don't be to disappointed, you gained .3 seconds on a street car for <$400!
02-28-2013, 10:01 AM | #31 | |
Rep 1,997
It does seem slow. Wonder if the calibration is off or if your car is 'gasp' slow?! I'd expect high 4s fairly easily achievable with stage 1. A good driver with summer tires should actually be able to get 4.8-5.0 in stock form. I would expect to run about 4.7ish with the tune. There are alot of factors to consider though. Did you happen to dyno it? I think it should be putting down 300 hp to the wheels and around 315ish tq. |
02-28-2013, 11:21 AM | #33 | |
Rep 1,997
Edit went and looked myself, straight from Terry: "Stage1 is a single map, +3.5psi." |
03-01-2013, 08:54 AM | #34 | |
Rep 70
Next up I will put back the Challenge HFC downpipe and run another test... |
03-01-2013, 08:56 AM | #35 |
Rep 265
Drives: 340i M Sport
I'm interested to see what effect the HFC has on your time. We appreciate your efforts!
2016 340i M Sport Alpine White, BMS Intake, JB4 Beta
2012 335i Sport Line, RIP |
03-03-2013, 04:42 PM | #36 | |
Rep 1,997
03-04-2013, 03:40 AM | #37 | |
Rep 70
One thing I should point out about the HFC DP is that the CEL did not come on for me for the 3000 miles or so that I had it on my car. However, when I plugged in the computer to scan for error code, one error code did come back regarding the catalytic converter. I don't know if it would be an issue getting the car serviced. |
03-04-2013, 09:01 AM | #38 | |
Rep 1,997
03-04-2013, 09:16 AM | #39 |
Rep 70
03-04-2013, 09:21 AM | #40 |
Rep 70
Came across this thing called TMC Tuning Box... A new friend threw it at me and I gave it a try... It is said to have 9 maps?? Apparently the map 9 supports an aftermarket downpipe.... Wasn't expecting much but did a test run... Launch at around 2K rpm again and got 5-sec flat.... best time I've gotten so far.... about 0.2 sec faster than my JB stage 1. I'm excited about upgrading to JB stage 2 but for now the TMC is staying under my hood.... at least until after I have another run with the Challenge HFC DP!
03-04-2013, 02:44 PM | #41 |
Delivered!
Rep 139
Just got my F30 N55 stage 1 today...now if only I had the car to install it on! Another ~4 weeks to go...
Delivered!: 2013 F30 335i M Sport, 8-speed Sport Trans, Estoril Blue/Coral Red, 403M, Premium Pkg, Dynamic Handling Pkg, Driver Assist Pkg, HK Sound, Enhanced BT & USB
03-04-2013, 03:35 PM | #42 | |
Rep 1,997
I forget if I asked already, but are you getting any wheelspin with 2k RPM launches? May be worth it to launch at about 2.25k or 2.5k if you're not. Granted if you're running the stock all seaons the car may not hook up as well as decent summer tires, but I think the best launch should get a bit of squeel but not total spinning. Edit: Just looked them up, they're claiming a 76hp increase! That seems really high. I'm wondering if they're running a safe boost for that gain. I dont know if anyone has used them or has dynos/boost info on it so I'd be hesitant on it. I think the JB4 is closer to +30 hp to the wheels, so 76 hp is really high. That's like a DP+ Tune. Also found a thread that touches on it from last year: http://www.f30post.com/forums/showthread.php?t=688854 Last edited by tdizzle; 03-04-2013 at 03:43 PM.. |
03-04-2013, 09:21 PM | #43 |
Rep 1,159
is there any way the dealer can see if you have the tune even if u get the bms cable?
I was told that some how bmw can see there was a tune even if you have the bms cable and deleted codes. I spent extra $$$$$ on extended warranty and did not want to avoid anything. |
03-05-2013, 09:30 AM | #44 | |
Rep 1,997
With a flash tuner, if you returned it to stock, they could look for elevated boost levels (I presume they can do this) and see how many times the car has been flashed which would throw up a warning if it was higher than expected. |
