12-13-2017, 09:07 AM | #1 |
Rep 18
Coding F36
Hi I am looking to code my new F36 and wanted to know exactly what I need?
I have coded my previous cars and had a bluetooth OBD2 connector, would this be sufficient to connect to the car? If not, what is a cheap recommended connector? Also, if I was to sell the car in the future, could I reset all changes to default? Lastly, where can I find a good software as well as a guide for the different codes? |
12-13-2017, 10:55 AM | #2 |
Rep 2,387
Depends on how sophisticated you want to get with your coding. Carly is a very easy approach to code a variety of things, but it doesn't offer the full capabilities that Esys does. Go to the Carly website and see what you can code for F30s.
2016 340i XDrive, EBII/black, 6 MT, M Sport, Track Handling, Cold Weather, Tech, Lighting, Driver Assistance Plus.
2012 Z4 35i, ED 2/24/2012, Melbourne Red Metallic, Black Leather, Carbon Trim, 6MT, M Sport, CW, PP, PS, NAV, CA. |
12-13-2017, 11:02 AM | #3 |
Rep 1,342
I use the Bimmercode app on my iPhone with a Wifi to OBD adapter.
http://www.bimmercodeapp.com/ The app has a demo mode that shows you all the stuff you can code. It's quite a bit. Also, there is a separate sub-forum for coding here: http://f30.bimmerpost.com/forums/forumdisplay.php?f=429 So much info your head will explode! |
12-13-2017, 03:50 PM | #4 |
Rep 3,225
The cheapest, and in my opinion best, is to use Esys (its free).
Best bet would be to have a look through the coding section of the forum. You should also check the UK regional forum as there are quite a few guys who "code" active. Good luck. |
12-13-2017, 09:40 PM | #6 | |
Rep 324
Drives: 2018 440ix Gran Coupé
I use this cable.
Speed-NYC_________________________________________________
Current: 2018 BMW F36 440ix Gran Coupe AT, Tanzanite, 2002 BMW E46 M3 Coupe 6MT, Titanium Silver Previous:1998 BMW E36 328i Coupe AT, Blue; 1996 BMW E36 323i MT, Orient Blue; 1992 BMW E36 318i MT, Slate Grey; 1973 Ford Cortina XL, Copper |
12-18-2017, 10:06 AM | #8 |
Rep 18
I don't want to be making new threads every time I have a new question so I gathered I would ask in here. I want to make some changes to my new F36 (when it arrives). It has professional media option but not the enhanced bluetooth option. Would my car be able to get the enhanced bluetooth option via coding? I've read elsewhere about needing a combobox so wasn't sure if my new car would be compatible.
12-18-2017, 02:17 PM | #9 |
Rep 108
Don't know if your wireless OBD2 interface will work. If it doesn't work most people here use a $20 ENET cable which connects the OBD2 port to a laptop ethernet jack.
https://www.amazon.co.uk/Ethernet-In...enet+bmw+cable Then just get all the free software along with some instructions here: http://www.bimmerfest.com/forums/sho...d.php?t=983244 The other forum where you can get coding help is here: http://www.bimmerfest.com/forums/forumdisplay.php?f=175
2017 X5 xDrive40e - Driver Assistance Plus, Adaptive LED Lights (decoded VLD + Glare Free High Beam), ACC Stop & Go, Night Vision, 275/40R20 315/35R20 Pirelli PZero + Pirelli Scorpion Ice & Snow
2018 330e - Driver Assistance Plus, Adaptive LED Lights (decoded VLD), Active Blind Spot Detection, ACC Stop & Go, Parking Assistant, Side/Top Cameras, HUD, Comfort Access, 225/45R18 255/40R18 Pirelli Cinturato P7 + Winter Sotozero Serie II |
01-04-2018, 09:56 AM | #11 |
Rep 327
In order to code in Enhanced Bluetooth you'll need to have a laptop, Esys, Esys launcher (Costs $50 USD), psdzdata files and time to learn this stuff so you don't screw it all up. All of this information can be found in the Coding forums.
Mods: MHD Stage 2+ FlexFuel, xHP Stage 3, VRSF 5" HD Intercooler, VRSF Charge Pipe, CircuitWerks Catless DP, AFE Pro Dry S Intake filter, Eldor coils, NGK 97506 @ .026, Bilstein B14 coils.
01-04-2018, 04:20 PM | #12 |
Rep 2,197
I read in the coding section that Esys was no longer working.
