07-31-2015, 03:35 PM | #9021 |
Rep 40,765
PM sent.
07-31-2015, 05:42 PM | #9022 |
Rep 1
Hi Shawn,
I'm looking to start coding etc. Could you message me details on how I can get the E-Sys and things required to start? Thank you in advance from Sweden! :-) |
07-31-2015, 06:33 PM | #9023 |
Rep 40,765
PM sent.
08-02-2015, 04:21 AM | #9024 |
Rep 14
Coding error...
Hey,
when I want to VO code the enhanced bluetooth functions, I get a "cafd_*** Not Executable" error. This happens when coding the ENTRYNAV module. I searched a bit for this error and the only thing I found out, was that my psdzdata version maybe doesn't match!? My extracted ISTA-P version is: 3.56.1.002 E-Sys: 3.24.3_rc_b38445 I step current is:F020-14-07-503 Also FDL coding shows no results at all. If I just want to change the startup emblem or so, it finishes with no error, the screen reboots but no changes. Same with foglight as cornering lights. Any ideas? Cheers Max |
08-02-2015, 07:04 AM | #9025 | |
Rep 40,765
Are you using the latest version of E-Sys Launcher? As for coding changes doing nothing, is it just these two changes or all FDL Code changes? These two you list may not be applicable to your car.
08-02-2015, 08:05 AM | #9026 |
FNG
Rep 35
Do you guys know if E-sys will still work on Windows 10 since Microsoft is pushing it out now. Don't want to upgrade and find out it's not working anymore.
08-02-2015, 08:06 AM | #9027 |
Rep 40,765
It works.
08-02-2015, 11:21 AM | #9028 | |
Rep 14
I use Launcher Premium 2.1.2.
But cornering lights should be possible when I have foglights? My VIN: F935972 |
08-02-2015, 11:23 AM | #9029 |
Rep 40,765
Why would you assume that? Are your Fog-lights motorized? Do you have Adaptive Headlight Option, because if you do, then your headlights are your cornering lights.
08-02-2015, 11:31 AM | #9031 | |
Rep 40,765
Does you car have AHL?
08-02-2015, 01:23 PM | #9032 |
Rep 14
The one thing is when you stand at a crossing with indicator active.Then I thought the foglight will go on at the indicator side.
The other thing is when you drive along a road with turns, the headlight is moving in the direction of your steering wheel. I don't have AHL. The coding reference says that foglight are needed, no mention of AHL, so I thought it will work then, as no cameras or other hardware would be necessary for this function. |
08-02-2015, 01:26 PM | #9033 |
Rep 40,765
It may be possible, I am not saying it isn't. I was just under impression that cars with Fog Lights for Turning Lights had Fog-Lights that swiveled. I may be wrong though.
08-02-2015, 04:11 PM | #9034 |
yunior
18
Rep 23
Drives: 2018 430i Xdiver (f36)
Hi guys, can anybody send me link for E-Sys software, datafiles, token and PIN for my 2012 (prod.10/31/2011) 528i xdrive. thanks.
08-02-2015, 07:33 PM | #9035 |
Rep 109
Thank Shawn for providing me the info for coding my F30 after almost two years since I did it last time. As I have many items to modify, the best way is to perform the coding "offline" -- i.e. connecting the laptop with the car to read/download and save necessary info, then disconnecting the laptop from the car, making desired changes sometime later on the laptop either once or several times, and finally reconnecting the laptop with the car for actual coding process. I did the coding in this way two years ago. But I don't remember the exact steps. Does any one have the detailed instructions for such offline coding?
08-02-2015, 09:50 PM | #9036 |
Rep 1,035
I can normally do this just fine:
Connect => Read FA (VO) => Activate FA (VO) => Read SVT (VCM) => Left-Click on desired ECU => Click on "Detect CAF for SWE" => Select the CAFD from latest I-Level shown => Select OK => Right-Click on ECU (the ECU itself not the underlying CAFD) => Select CODE. I just recently purchased ordered a newer 61359362394 REM for a PDC retrofit. When i received the pkg, the dealer said it was replaced by the 61359374506 REM which they said is newer. However, i can no longer select "Detect CAF for SWE" Its greyed out when i get to that step. Is this because my version of PSdZData Lite is too old? I'm running: E-Sys v.3.26.1 PSdZData v.54.1 Lite E-Sys Launcher Premium 1.07 I have a 2014 F30 328i M-Sport (production date 8/19/2013) I-Step: F020-13-07-506 What do i need to upgrade to be able to VO Code this new ECU? |
08-02-2015, 11:41 PM | #9037 |
Rep 40,765
PM sent.
08-02-2015, 11:50 PM | #9038 | |
Rep 40,765
08-02-2015, 11:52 PM | #9039 | |
Rep 40,765
08-03-2015, 12:36 AM | #9040 |
Rep 1,035
08-03-2015, 05:04 AM | #9041 |
Rep 109
Thanks. I also found this video which describes the offline coding in detail
08-03-2015, 03:33 PM | #9042 |
FNG
Rep 35
Hi guys. I use E-sys 3.24.3 with psd data v56.1 (lite).
When connecting to the car (F31) and reading FEM_BODY it seems like a lot of values are not being populated by E-sys Launcher. Any idea what's up with that? Cheers. |
