11-06-2018, 04:28 PM | #89 |
Rep 19
They "could" have changed the grade of resin and there would be no way to know as it would look the same. They could have modified the mold slightly and again there would be no way to know unless one had the early and later version and examined both carefully. It takes a very little internal radius to increase strength dramatically. In fact it would be really had to see the difference. Now, if they increased wall stock or added a couple of ribs then they would be very obvious.
It is looking like I will have to get an entire engine. If so I will change the timing chain and oil pump chain before I put it in the car. So much easier working on an engine on a stand! |
11-06-2018, 05:13 PM | #90 | |
Rep 2,382
At the end of the day, while it can be scary to know that the issue exists, the chances are low in proportion to the amount of N2Xs in the world. Performing your preventive maintenance (including even changing out the tensioner), doing regular checks, turning off Auto Start/Stop, letting the car warm up, etc., should go a long way. I personally get my oil changed every 5k miles and ensure I check the filter for any foreign objects. I also throw in Ceratec (supposed to reduce friction) every few oil changes. My chain is checked every 1k or so to check for any deep scoring or change in the amount of slack. Those are just a few things I do and it can't hurt for anyone else to as well, should they see fit. I'm at 93k now with no foreseeable issues and hoping it stays that way. Lol.
2013 F30 328i: MHI Big Turbo, GFB DV+, Mishimoto CAI, ER TIC/CP/Catless DP, AWE Touring Quad Exhaust w/ Resonated Midpipe, NGK LI Plugs, BM3 with PTF Stage 2 91 AGG Tune, Fuel-it Stage 2 LPFP, Solowerks S1 Coilovers, and DEPO/M-Sport Retrofit |
rjd_F302000.50 |
11-06-2018, 07:22 PM | #91 | |
Rep 3,680
11-06-2018, 07:31 PM | #92 | |
Rep 5,458
Drives: F30
Also - dont get hosed on an engine. Freshly rebuilt ones with upgraded components can be had for $3.2k USD delivered. |
11-07-2018, 11:27 AM | #93 | |
Rep 19
Speaking of which, have a look at part of the wiring harness. It starts at the computer on top of intake, wraps around front and back and under the intake. Crazy. I have labelled and paint marked the connectors. About half a dozen and you can't really grasp or see most of them. This is not the entire wiring harness either. Then have a look at the water line. Reminds me of Dr. Seuss stories with the who's musical instruments. |
11-07-2018, 11:47 AM | #94 |
Rep 5,458
Drives: F30
11-18-2018, 12:51 AM | #95 |
Rep 153
I have turned off start/stop pretty much since I bought the car. I also changed oil about every 4K miles since I got the car. I drive mostly stop and go traffic with top speed limit of 45 mph, thus since new I don't over rev the engine when engine is cold.
I guess I have good change of not meeting this issue? Anyway, can someone please provide a link of YouTube video that accurately describes the whining noise? I saw many videos, but many were not whining sound. So kind of confused. Thx! |
11-20-2018, 07:13 PM | #96 |
Rep 59
Drives: F30 328i RWD
It doesn't help that our N20 naturally has faint whining noise. Makes it hard to tell if it's the timing chain whine or not.
Anyone tried or researched into doing the oil pump chain and timing chain themselves? Or had a shop do it for them? I've read that the timing chain is a big job and is not for a diyer, but any idea about oil pump chain? Last edited by canman111; 11-20-2018 at 07:24 PM.. |
11-20-2018, 08:59 PM | #97 | |
Rep 5,458
Drives: F30
Coincidence?! |
11-20-2018, 09:03 PM | #98 | ||
Rep 3,680
11-22-2018, 05:18 PM | #99 | |
Rep 57
https://www.newtis.info/tisv2/a/en/f...motor/HinAc4xE You can find the manuals for everything related to the n20 engine in the newtis manuals. Hope this is helpful |
11-26-2018, 09:02 AM | #101 |
Rep 2,382
You'll know when it's the timing chain starting to go. Between the turbo spool and the already noisy engine, it can be confusing but the failure noise is best described as a "dying cat" noise. It'll be pretty loud.
meltbox43.00 StradaRedlands4979.00 |
12-03-2018, 10:37 PM | #102 |
Rep 19
I finally got some more time to work on this project. I managed to pull the engine last weekend. I pulled the oil pump/balance shaft assy. Then finally I pulled a rod cap. Bearing looks just fine. I figured I would look at the main bearings as well. Wouldn't you know it, BMW designed the whole bottom of the block to split at the centre of the crank. It also holds the main bearing caps.
I doubt anyone at BMW ever thought any of these engines would be rebuilt! So if I want to look at the main bearings, the whole girdle assy has to come off. I figured before I did that I should pull the head. Do you know that a Torx T60 really long bit is difficult to find.I had to order on line. As well, to take off the fuel injector/spark plug well, you need to pull an injector. Now I will need to make a tool to pull the injector. If it takes too much force to pull you need to replace the injector No doubt this is the worst engine I have ever worked on. I am wondering if I will ever get all wiring hooded up again. Oh, pulling the exhaust manifold/turbo I did on the engine stand. Water lines and oil lines. Water lines were difficult and I have it on a stand. |
12-09-2018, 06:36 PM | #103 |
Rep 285
Drives: 2014 428i XDrive
Does anyone have a list of parts needed for an entire swap for oil pump, oil pump chain + timing chain, etc?
Also labor seems like it's around $2k? Thanks all |
12-11-2018, 10:11 PM | #104 |
Rep 943
Drives: F30 328i Msport
Correct. You can search for a timing kit which has all the parts needed theoretically, but in practice you never know what extra bolts/washers etc you’ll need on top of the special tools to lock out the moving parts in specific order.
12-12-2018, 10:38 AM | #105 |
Rep 285
Got quoted $3300 or so at an indy with all the parts
12-12-2018, 11:16 AM | #106 | |
Rep 5,458
Drives: F30
Are you having this done or just researching? |
12-12-2018, 11:18 AM | #107 |
Rep 5,458
Drives: F30
I think $2000 plus parts is about fair for this job.
12-12-2018, 02:27 PM | #108 | |
Rep 285
Researching. The parts are 1. Engine Sealant 2. Anti Freeze 3. Timing chain Kit 4. Oil Filter Kit 5. Valve Cover Gasket Set 6. Seal (?lol) 7. Mobil 1 Oil 8. Camshaft Adjuster Seal 9. Crankshaft Pulley Bolt 10. Timing Crankshaft Sprock 11. Washer 12. Oil Pan Gasket 13. Oil Pump Drive Gear Parts - $950 Labor - $2400 |
sspade2468.50 |
12-12-2018, 02:48 PM | #109 | ||
Rep 5,458
Drives: F30
In going to attempt to match part numbers to this and save for my own personal list in the future. |
12-13-2018, 01:15 PM | #110 | |
Rep 52
https://www.fcpeuro.com/products/bmw...-11318648732kt |
sspade2468.50 |
