08-27-2016, 03:32 AM | #1 |
President of ELMOC
19
Rep 232
Dash Cam Reccomendations
With my new 330D not having the USB slot in the glove box my existign dashcam is useless at the moment.
I am looking for options. 1. keep my existing really cheap dashcam and find a way of powering it via usb. PRO's keep camera, cheapest option, retrofit cable for CIC available, can get hardwire kit for USB micro Cons camera crap, retrofit cable might not work in new Prof nav unit, dotn konw where to tap into for hardwire kit2. get a new camera system that can be hard wired professionaly PRO's better camera and properly wired Cons not that cheap Now if anyone can help with solution 1 i will go for that but if not then recommendations for solution 2 would be welcome.
08-27-2016, 05:10 AM | #2 |
Rep 616
I've got a Mobius ActionCam in both my F30 and my wife's F20 with a custom mount which tucks it way up behind the mirror and totally out of the way.
https://www.mobius-actioncam.com Powers taken by splicing into the lighter socket under the glove box. |
08-28-2016, 10:34 PM | #3 |
The Schwab
474
Rep 1,605
Drives: 2020 AW M340xi
Just got the top of the line dashcam by Thinkware (F770)...it's amazing. Check out my thread over on the 2addicts forum for a quick review and test footage.
mbfanos54.50 |
08-29-2016, 09:59 AM | #6 |
Rep 694
One of these https://www.ebay.co.uk/itm/141723701622 under your glovebox?
08-29-2016, 11:09 PM | #7 |
Rep 12
I use a iPhone6S 64GB in 4k on my dash using a magnet mount lol.
2013 BMW 320i - Jet Black - Black Dakota Leather - Premium Package - Heated Seats
08-31-2016, 04:27 AM | #9 | |
President of ELMOC
19
Rep 232
dont know if that applies to you in over there
08-31-2016, 07:14 AM | #10 | |
The Schwab
474
Rep 1,605
09-04-2016, 10:22 AM | #11 | |
President of ELMOC
19
Rep 232
I have ordered a usb 12V adapter for a toyota that will also do what i need it to do but i now have a fault on my cheap camera so im back to looking at a replacement.
09-05-2016, 02:47 AM | #12 |
Rep 547
I use the Blackvue DR650. It's pricey but one of the best dashcams and in the event of an accident it will pay for itself.
What I love about it is that its discrete and not in my sight when driving. The few LED lights it has can be switched off so that it's 100% incognito. If I want to view recorded videos or live view, I simply use the phone app over Wifi. I've hardwired it using a Power Magic Pro so it records continuously 12 hours after ignition has been switched off.
Previous Bimmers: F25 X3 20d LCI xLine, F30 320d Luxury
09-08-2016, 08:33 AM | #13 | |
Rep 125
Noise is not coming from connector cover, but seems to be from the buttons. Do you have similar experiences or is it just me? |
09-08-2016, 08:34 AM | #14 | ||
The Schwab
474
Rep 1,605
09-08-2016, 08:37 AM | #15 |
Rep 125
After installing the Thinkware F770 (front & rear) in my car, and having never before installed any wiring in any car, I can tell you it was quite easy to do it yourself. No need to pay anyone to get it installed and hardwired.
Biggest annoyance was that the power cable supplied with F770 doesn't reach to the trunk, so you'll need a soldering iron and solder some more cable to the end of it. |
09-12-2016, 09:19 AM | #16 | |
The Schwab
474
Rep 1,605
Its a really loud rattle/buzzing and I need to fix it haha |
09-12-2016, 09:39 AM | #17 | |
Rep 125
What I was thinking of was a small piece of insulating tape pushed into the gap of every button, to try to make them more stiff. Haven't attempted it yet. |
09-12-2016, 09:40 AM | #18 | |
The Schwab
474
Rep 1,605
09-12-2016, 09:56 AM | #19 | |
Rep 125
https://dashcamtalk.com/forum/thread...-5#post-277938 |
10-09-2016, 03:10 AM | #20 | |
Rep 125
Here's how I solved it myself: cut 2 pieces of black insulating tape approx 1cm long, just about so that it can fit into the gap around the button. I put it only on two buttons, Format and Mute, this seems to have been enough. Only important thing was to make sure that the tape went about 1mm inside the gap, and then stuck it to the casing. Quite unnoticeable, really. Also I put tape on the connector flap. In driving since yesterday this seems to have solved it 100%. |
10-09-2016, 07:24 PM | #21 | |
Rep 261
@OP: go with Thinkware, do the dual cam setup and hardwire it. You'll not be disappointed. I hardwired the kit to the fuse box in the trunk.
It's strange that this started 1 month after I bought it. My theory: because it is black, during use it gets very hot and expands. When it cools, it does not contract to the original shape but deforms a little bit -> hitting something inside |
