10-14-2016, 03:51 AM | #1 |
Rep 8
iDrive screen upgrade
Hey guy,
I have a 2013 F30 NBT with ‘small screen’. I see that there are 8.8” and 10.2” monitors and wanted to do an upgrade. Here’s my concerns: 1) 8.8” is the official SatNav screen hence no modification (cutting dash) needed? 2) What addition hardware do I need to buy other than the screen? iDrive control or I can still use the existing one? 3) What additional functions are for using a bigger screen other than looking nicer? 4) I have bimmer-tech smartview so I always use google map when needed. I don’t need the BMW SatNav. Last edited by g_ngan; 10-14-2016 at 03:57 AM.. |
10-14-2016, 05:46 AM | #2 |
Rep 565
1) No, 8.8" fits perfectly.
2) No additional HW needed. You only need to code your car, so an OBD2 cable/adapter. 3) Splitscreen is a good example. 4) Sure, same here ;-). See this thread for more info. EDIT: I see you have NBT - do you have 6.5" with nav? We have done this with 6.5" no nav 2014+ (with HU_ENTRYNAV), read through the thread - there was someone with a similar config as you have, but I'm not sure if he posted the results. Last edited by MarkoSK; 10-14-2016 at 05:50 AM.. Reason: Added text |
10-14-2016, 11:56 AM | #3 |
Rep 263
I'm not aware of any NBT (nav Professional) with small screen.
2013 can also not be Entrynav as this was introduced from 2014 on. So I rather guess you have HU Entry which can't be coded for 8,8" screen. |
10-14-2016, 07:59 PM | #5 |
Rep 5,897
Drives: 2014 335i Black F30 M Sport
10-15-2016, 03:26 AM | #7 |
Rep 565
01-16-2020, 01:52 PM | #8 |
Rep 44
01-24-2020, 10:11 PM | #10 | |
Rep 10,473
1) Retrofit HU and bigger screen 2) Some knockoff Android Unit. |
01-31-2020, 12:17 PM | #11 |
Rep 3
As I understand it, HU_ENTRYNAV starts from 03/14 if you have the business navigation package and 07/14 if you just have the professional radio package. You must have ENTRYNAV to upgrade to the 8.8 inch screen.
