BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > UK > 335d Xdrive -1st Service - Gearbox leak!
      11-17-2017, 07:14 AM   #1
sixer
Drives: F10 520d
Hi all
Took my 335d in for its first service at 14k miles and they have spotted a gearbox oil leak! They said it may be the transfer box but need to investigate further.
Any idea what this could be or if there are any known issues?
Does anyone know what this job will do entail?
Taking it back in next week for investigation.
Thanks
      11-17-2017, 08:19 AM   #2
onstat
Wales
50
Drives: 335d Touring
Ive currently got the same on mine after a first service. It was described as a "misting" rather than a leak! lol
Mines going in beginning of December for 2 days to have the gasket replaced which is the fault.
F31 335d M Sport | Estoril Blue & CR | M Sport+ | Pro Nav | Comfort Pack | Adaptive M Sport suspension | Active Cruise
      11-17-2017, 08:26 AM   #3
sixer
Drives: F10 520d
I was assuming a duff seal too but not sure. Itís a slight weep rather than a dripping leak from what I can see. Wondered if they would refresh the full fluid as part of the job?
      11-17-2017, 08:47 AM   #4
Mr Whippy
Drives: Z4
Interesting to know.
Fingers crossed it's an easy fix.
They'll replace fluid I'd hope. Risk of contamination is too high otherwise.
      11-17-2017, 11:34 AM   #5
Jeff123
Jeff
Drives: 330d M Sport x-drive F30
This happened to me a couple of cars (BMW) ago. Saw a few spots of pink fluid on the drive and mentioned it to the dealer. They reckoned that it would need new oil and everything tightening up - quoted £180. I rang 2 indies who said that just tightening things up would not solve the problem and quoted me £360 to replace some type of tray/cover as well.
In the end I opted for the main dealer solution and it seemed to work, at least for the 18 months after that until I sold the car.
onstat50.00
      11-18-2017, 12:32 PM   #6
NanasBack
Drives: EB 335 oil burner
Have you done any/many launches?
14k is quite low by my standards.
      11-18-2017, 12:46 PM   #7
sixer
Drives: F10 520d
Nope none! Agreed 14 is low
      11-18-2017, 12:52 PM   #8
onstat
Wales
50
none here too. good job really!
      11-19-2017, 10:37 AM   #9
NISFAN
NISFAN's Avatar
Drives: The best kind of F30 :)
I think the gearbox is pretty much a single casting, with a plastic sump bolted to a machined surface underneath. There is also a wiring harness seal that could have popped out, and on xDrives the rear section has the transfer box add on, which is a mating face. I guess there are cooling pipes somewhere too.
So in other words, not many areas where it can leak as it is one big casting.
My bet would be the plastic sump.
onstat50.00
      11-19-2017, 10:46 AM   #10
MarkG_M3CP
Supreme Being
MarkG_M3CP's Avatar
Drives: M3 CP
I had exactly this 'fault' on my 2013 car - identified at the first service, fixed and never heard any more about it.
Current: F80 M3 Competition Pack / M135i
Gone: F15 X5 M50d / Saab 9-5 Aero HOT / F30 335d xDrive M Sport / E92 LCI 320d M Sport / E46 320d M Sport Touring / E46 318i Touring
onstat50.00
      11-20-2017, 04:41 AM   #11
sixer
Drives: F10 520d
The tech at BMW dealership suggested it may be the transfer box (assuming he meant seal). Hopefully an permanent fix can be done.
