BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > UK > Locking wheel nuts
      11-18-2017, 07:05 PM   #1
Sturrock
Drives: F31
Locking wheel nuts
Swapped out my summer's for winter and in the process the garage mangled my locking wheel nut. Think it might have been on the way but they made sure to wreck it. Was left with 3 winter tyres and 1 summer. So I popped into the stealers and got charged the princely sum of 24 for a new nut!
      11-19-2017, 05:52 AM   #2
teaston
teaston's Avatar
Drives: 335d M Sport Plus
They were able to supply you one locking bolt that uses the same key as the others?
Current: LCI F30 335d M Sport Plus in BSM/CR
      11-19-2017, 06:27 AM   #3
GEP77
Drives: F36 440i MPPSK
A full set of locking bolts is about 50 iirc and that comes with a key for them. I suspect you got lucky that the dealer had a spare sat around, otherwise they'd charge you for the set.
If you take care the locking bolts are quite resilient, the main thing is not to let an impact driver anywhere near them - almost certainly what has happened.
The problem these days is everyone is in too much of a rush to take care with these sort of things.
Out with the old...
... and in with the new
      11-19-2017, 06:49 AM   #4
Jeff123
Jeff
Drives: 330d M Sport x-drive F30
Thats exactly what happened to me, had to buy a full set.
      11-19-2017, 06:50 AM   #5
Sturrock
Drives: F31
Yeah same numbered key. Pulled out of a bag he had next to him. The pillock who was doing the swap was hammering it in until I told him to take it easy. They also managed to scratch up my alloys which i had powedercoated about 3 months ago. Not a good day. Ill be claiming for refurb costs of course.
      11-19-2017, 10:30 AM   #6
willjames
willjames's Avatar
Drives: F31 330d M Sport Touring Auto
It might be cheaper doing it yourself next time. A torque wrench a jack and a bit of patience should do the trick
      11-19-2017, 11:49 AM   #7
HighlandPete
Drives: BMW F11 535i Touring
I do wonder how many locking nuts get damaged or broken, through normal use? I suspect most are abused, over torqued or have been attacked with an impact gun.
      11-19-2017, 12:14 PM   #8
Incontinentia Buttocks
Incontinentia Buttocks's Avatar
3341
Drives: M135i
Over torquing is the work of Satan. Very impressed at my local Indy last month when getting a puncture repaired, the fitter knew the correct torque for my wheel, off the top of his head. Respect!
      11-19-2017, 12:42 PM   #9
willjames
willjames's Avatar
Is it 140nm?
      11-19-2017, 12:57 PM   #10
3341
Drives: M135i
Is it 140nm?
It is for my wheels
      11-19-2017, 01:43 PM   #11
Nobby Clark
Nobby Clark's Avatar
491
Drives: F36 430d xDrive M Sport
To be flair most wheel bolts are M14 or M12 in which case torque is 140Nm and 110Nm respectively. The only other thing he needs to remember is lefty losey righty tightly. Hardly mastermind
      11-19-2017, 02:18 PM   #12
sensible
sensible's Avatar
124
Drives: BMW 320i M-Sport
I have decided to change my own winter/summer wheels over so I can be as gentle as I like and wrap my wheel nut brace with something soft so I don't scratch my wheels.
Just ordered a rubber jack pad that fits in the rectangular jacking holes so I don't damage them with a trolley jack.
I will be taking off 442M summers and putting on 400M winters. Which nut's would I have so I know what the torque should be.
      11-19-2017, 02:48 PM   #13
Sturrock
Drives: F31
Was getting a tyre change onto same rims. Changed the wheels myself a little while back. Not that handless
