08-07-2012, 11:27 AM | #727 |
Rep 9,160
GTF, please stop pushing the sad little Renault. For once, there's a car the ROW can get that we can't that I'm actually kinda glad about. The Toyabaru is one thing, but this is really too much.
The only cool Renualts are the Alpines and the rear engine Clios. |
08-07-2012, 11:36 AM | #728 | |
Rep 1,247
Drives: fat cars are still boats
Location: compensating a fat car with horsepower is like giving an alcoholic cocaine to sober him up.
But please, don't deny what you don't know... With the Megane RS I was just proving to you that a FWD car can be much better than a LOT of the RWD cars and a real competition for the Toyobaru. For instace, EVO magazine says that they prefer it and even the Renault Clio RS to the automatic Toyobaru. Last edited by GoingTooFast; 08-07-2012 at 11:44 AM.. |
08-07-2012, 12:26 PM | #729 |
Rep 1,456
Drives: 2008 E92 335i
If there's a turbo model, then I'll get one. If there isn't going to be one... well, I'll still look at a red FR-S
08-07-2012, 12:41 PM | #730 |
Rep 9,160
Duh. I'd rather drive a Viano with a manual than a GTR, but I'm weird like that. I'd also prefer that same silly MB bus to the Megane. I've had my fwd cars, I've tried to make them fun, it just isn't the same thing as even a terrible rwd car.
08-07-2012, 01:52 PM | #731 | |
Rep 3,888
It won't. There is aftermarket for that, the ZX6 is built for being tuned. |
08-09-2012, 06:27 AM | #732 | ||
Rep 1,247
As for the FI I4 engines being 'laggy' let's take the Megana RS example again (I'm sorry Red Bread, I'm only trying to make my point clear about modern turbocharged engines' throttle response)... First of all, 80% of the peak torque is available from as low as 1900rpm, which means that at this point the torque (360*0.8 = 288 Nm) is already greater than the 981 Boxster's engine peak torque (280 Nm) which ONLY appears much later at 4500 rpm. So, the TIME that the Boxster engine will take to go from 1900 rpm to 4500 rpm at full throttle (maximum acceleration) in order to output the closest but still less torque than the RS' engine will ALWAYS be greater than any perceived 'turbo lag' from the latter in the same gear and for that rpm range because the turbo is already spooled up. Of course that you will tell me the Boxster's engine acceleration is so linear and progressive that there's no perceived delay between the moment you press the throttle pedal and the moment you get the engine response from 1900 rpm up to 4500 rpm and beyond. While that's true you must realize that for the same car (aerodynamics, weight and gear ratios) above 1900 rpm you would ALWAYS have greater acceleration with the Renault engine for the SAME rpm, gear and THROTTLE DEMAND! On the other hand, what you may perceive as 'turbo lag' in the Renault's engine response from 1900 rpm to 3000 rpm (where the RS' engine peak torque first starts) is NOT, in fact, 'turbo lag' but the engine's non-linear torque delivery which reachs its peak more abruptly (as opposed to progressively) at 3000 rpm, thereafter the engine seems to pull evenly up to the redline (and beyond... ). The thing is, thanks to the twin scroll turbocharger and continuously variable intake valve timing the Renault engine is ALREADY pulling harder at WOT from as low as 1900 rpm than the Porsche engine will EVER do up to its 7800 rpm redline. Also, the Renaultsport Dynamic Management system allows the driver to choose between three modes through the ESP button on the dashboard: - 'On': the default mode. The ESP, ASR traction control and emergency brake assist are all activated. The pedal mapping ensures smooth acceleration. In this mode, power is 250hp and torque is 340Nm. - 'Sport' mode (*), for less intrusive ESP action. This mode is selected by a short press on the ESP button. The ESP and ASR are still active but intervene at a later point and allow the car to slide to a certain extent, so long as the skid doesn't exceed a given threshold. The pedal mapping is modified to permit swifter engine response and provide extra torque at low revs. By specific mapping, power is increased to 265hp and torque to 360Nm . - 'Off' mode (*). This mode is activated by a longer push on the ESP button. The electronic stability programme is fully disconnected, while the pedal mapping ensures instant response from the engine and delivers all available torque and over-torque at low revs. The engine delivers 265hp of power and 360Nm of torque. (*) If the car is optioned with the Renaultsport Monitor it further enables the driver to modify the throttle pedal mapping from five different settings (linear, normal, snow, sport and extreme) in both these modes. Does this ring any bells to the 1M owner?! Talking of whom... I as an 1M owner will be the first to support a M2 with a turbocharged I4 as long as this means lower weight and less fuel consumption! Power is cheap these days, the focus should be on weight reduction and improved mileage. Quote:
Please, don't tell me the Megane RS is not fun... what you can say is because it is so damn' capable MOST will need a track to fully exploit it: Last edited by GoingTooFast; 08-09-2012 at 11:55 AM.. |
08-09-2012, 10:24 AM | #733 |
Rep 1,247
Stock Toyobaru engine with a small oil-less turbocharger and a FMIC (red circle in the picture) for a compact and low psi setup. The D4-S fuel injection system and the 12:1 compression ratio are retained. Now that is starting to get interesting...
08-09-2012, 02:20 PM | #734 |
European Editor
10532
Rep 22,992
I saw this car at the AMI show in Leipzig - I came away very un-impressed. What a slug. Sure on paper it doesn't look bad... but I found it very lacking in every way. Its under powered for now. Maybe once they put a turbo engine in it - it might be something. But for now its just an 'also ran" car that is RWD. I personally think a 128i would beat it in every performance category.
And what is with all this Advevo-Fanboy action? Geeez just PM him!!!
08-09-2012, 07:09 PM | #735 | |||
Rep 1,247
So, why do you think AutoBild says otherwise regarding the 125i (the European version of the US 128i)? Quote:
Now seriously... Advevo and his videos are the ONLY reason why I started to left-foot brake and do it on a regular basis now... so yes, I'm a big fan since long time ago! More recently, whenever I have questioned Advevo over the 1M forum about his driving tecnhique he was always kind enough to answer me until someone has banned me from that forum. So, I have NO problem talking to Advevo but someone decided that I couldn't do it over the 1M forum... I thought that was precisely what a forum is for. Quote:
Finally, knowing what Advevo values in a car I really think the Toyobaru was made for a driver like him and I would like VERY much that he could test it to the limit and share his findings with ALL OF US his fans (I'm not alone, you know!?). |
08-09-2012, 09:25 PM | #736 | |
FBO+Methanol Injection
70
Rep 346
08-10-2012, 03:41 AM | #737 | ||
Rep 1,247
Do you understand now why I'm insisting and asking for a turbocharged 1.6-litre petrol boxer engine with at least the same 200 hp as the current Toyobaru's 2.0-litre, naturally aspirated unit (but a LOT more torque)?! |
08-10-2012, 06:39 AM | #738 |
Rep 1,247
Powerful four-cylinder turbo to combine with lower weight for the next Nissan 370Z - given the Renault-Nissan Alliance the new model is expected to drop its 3.7-litre V6 engine in favour of a more powerful version (~300 hp) of the turbocharged 2.0-litre four-cylinder engine which will equip the hotter Megane RS recently spied testing at the Nordschleife: It will be a turbocharged direct injection petrol engine - MR20DDT 2.0 L (1998 cc) DIG-T. Last edited by GoingTooFast; 08-10-2012 at 08:58 AM.. |
08-10-2012, 10:16 AM | #739 | |
Rep 4,709
08-10-2012, 06:41 PM | #741 |
Rep 659
That looks fantastic!
This is why the BRZ is such a big deal, all other automakers will be following with their own version.
F97 X3M
F80 M3 (Sold) E90 M3 (Sold) EB M235i (Sold) E92 M3 (Sold) |
08-13-2012, 06:19 PM | #742 |
Rep 1,247
08-14-2012, 09:48 AM | #744 |
Spoolin' & droolin'
93
Rep 1,229
Awesome....they should of had it turbocharged though.
First modification I would do if it was my car is get rid of that wing. |
08-14-2012, 10:07 AM | #745 |
Rep 1,247
The competition is set on the track... 2.8L V6 Twin Turbo hybrid (300 hp) vs 2.0-litre Boxer Turbo (300 hp)... Mugen CRZ-GT vs BRZ GT300... what about outside the track?!
08-16-2012, 04:06 AM | #747 | |
Rep 1,247
GT86 is Top Gear’s Speed Week Champion!
08-16-2012, 04:15 AM | #748 |
Rep 1,247
Take note that Chris Harris always prizes Porsche above everything else much like Jeremy Clarkson prizes Mercedes above everything else and like Advevo, who races BMWs, buys mostly BMW's...
