BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Maybe I should have got the Adaptive Sport Suspension... :(
      01-29-2013, 06:01 PM   #1
stom_m3
Drives: Sequoia
So it ends up being that the standard sport suspension on the MSport is grossly undersprung and underdamped. I don't know how much better the Adaptive Sport Suspension is and I'm left wondering how much better it would have been... Of course, people on this board were telling me to get the adaptive but I was too damn cheap to shell out the additional $1k.
If I had to quantify it, I would say that the standard sport suspension needs to have a 15-20% stiffer spring rate and 50% more dampening ability. The high speed dampening (quick stutter bumps) is ok but the low speed dampening (big undualtions or turns) could use quite a bit of help. The car wallows and takes too long to settle in fast sweepers.
I guess I can use this as an excuse to get full blown aftermarket coil overs.
      01-29-2013, 06:02 PM   #2
bizzyqu
Drives: 2019 M240i xDrive
Nothing beats a good excuse
07 E83 X3 BSM Sport-->10 E90 335i xDrive BSM M-Sport-->13 F30 335i xDrive EB M-Sport-->16 MKVII LB Golf R --> 19 F22 M240i xDrive MG
      01-29-2013, 08:48 PM   #3
Seagull
Seagull's Avatar
Drives: F87 M2, E84 X1
No, it just gives you the ability to go softer so when you're downtown or going through construction, its more forgiving.
Current: F87 M2 MT MPE, E84 PP SP LP
Previous: F30 - 335i AT, E90 - 335xi MT, E90 - 330i MT, E46 - 330i MT
      01-29-2013, 10:29 PM   #4
FlyByNite
Drives: 2019 M4 Comp.
2019 M4  [0.00]
2016 BMW M3  [0.00]
2011 BMW 528i  [0.00]
^^This....
      01-29-2013, 11:16 PM   #5
pkimM3r
pkimM3r's Avatar
205
You driving this to the limit? As in no one else can drive this car faster than you.
      01-30-2013, 12:11 AM   #6
Tsuvoi
Drives: 2013 F30 328i
False, adaptive sport is stiffer in spot mode than standard sport.
      01-30-2013, 12:23 AM   #7
stom_m3
Drives: Sequoia
I don't know how you got that from my post. If you've ever done any amount of track time whether auto-x to road course, you would know that reaching limits of adhesion is not that difficult. Assessing what it would take to make the suspension perform better is half the fun. Just as is people trying to make the engine perform better, there are others trying to find an optimal suspension setup. What's wrong with that?
      01-30-2013, 12:34 AM   #8
jamesems
Drives: 2013 335i msport f30
I didn't find the standard msport suspension that bad on my 335i. It was somewhat sporty but with a comfort tilt. I have since replaced it with the m performance and am thoroughly pleased. Maybe you should consider it. I'm in San Diego as well.
      01-30-2013, 03:00 AM   #9
MarkW83
Drives: F30 330d M Sport
This is correct. Adaptive is both stiffer in sport mode, and softer in comfort mode, than the standard passive sport/non-sport suspensions, while also having more body control in BOTH modes, and constantly measuring the road to give the best result in both modes.
F30 330d M Sport Mineral Grey / Coral Red
Pro Nav/Visibility Pack/Comfort Pack/Harman Kardon/Head-Up Display/Electric Seats/Comfort Access/Adaptive Suspension...
      01-30-2013, 05:29 AM   #10
roadcarver
Drives: 13 e82 135i /13 F30 335i
I could definately percieve a difference between the regular sport suspension and the adaptive m suspension in sport mode. I felt the regular sport had a little bounce and float around corners especially if there were any undulations in the pavement through the curve. It seemed to get a little unsettled and sloppy in certain situaitions for a BMW. The sport mode in the adaptive suspension mostly eliminated this. This is why I ordered my wife's car with adaptive m.
      01-30-2013, 05:53 AM   #11
ridin135
Drives: Depends on the day
Just placed an order for an m sport 335i and wondering if I should have gotten the DH package. Is the steering any tighter with the adaptive suspension? I have it on my z for but wasn't sure if it was worth it or not on the new car. I could care less about comfort mode but if there is a big difference between sport mode and the m sport suspension I might have to change my order
      01-30-2013, 06:22 AM   #12
Vitoco
Infidel
Vitoco's Avatar
122
When in sport, you get heavier steering regardless of what other option you got. Variable Sport Steering, which is the other part of the adaptive package, doesnt affect the weight of the steering, only ratio.
But you should absolutely, most definetely, without a single doubt, get Adaptive M Supension.
      01-30-2013, 06:58 AM   #13
Seagull
Seagull's Avatar
Really? Can someone show/confirm this? Maybe through part numbers etc?
Don't get me wrong at all, I'd love for the M-Adaptive to be stiffer than the normal sports suspension, but all I have is word of mouth to go on. And all that does is cause endless debates on no real facts.
For example, my source was a BMW race engineer at a BMW drive event. Admittedly, the Adaptive was just coming out at the time. I specifically asked him while in Sports mode if the suspension would be stiffer than the normal sport suspension. He said no. But then again, it was new at the time and he may not have had a chance to look at it.
Still, I find the M-Adaptive "feels" less stiff than my old e90's ( although I am on winter non-RFT's right now, but I am trying to compare winter apples to winter apples ).
      01-30-2013, 07:55 AM   #14
SamS
M Adaptive in Sport feels stiffer to me than a normal Sport Line car in Sport mode.
Dunno if part numbers will clarify anything, because some of this is going to be software related.
All I know is M Adaptive is the best $1K option I ever got on a car.
      01-30-2013, 09:38 AM   #15
Tsuvoi
I think the only reason for not getting the adaptive would be if you're planning on installing aftermarket suspensions, then you save $1000, and I've heard that it was easier to install the aftermarkets if you don't have to undo all the adaptive hardware and software.
But no aftermarket is going to give you that variable suspension setup... Just a stiff setup, assuming you're going for sport suspensions.
      01-30-2013, 09:45 AM   #16
SamS
Exactly! Coming from an M3, I can tell you that a very stiff suspension 100% of the time is not very fun.
If I'm just cruising along on the very straight roads we have here in TX, then Comfort with M Adaptive is perfect. When I get to some curves or on-ramps, it only takes me one second to flip over to Sport.
      01-30-2013, 10:09 AM   #17
stom_m3
Drives: Sequoia
Very cool! Can you PM me with the specifics. Maybe you can take me for a spin sometime. I would love to assess the difference between cars with M Sport and M Performance suspension.
I'm getting the front splitter on today if you haven't seen that. I'm hoping it looks good on a stock height car. I'll have to take pics and post them.
      01-30-2013, 02:16 PM   #18
jamesems
my car
yes i have seen the splitter. here's a couple images of my car with suspension
      01-30-2013, 02:20 PM   #19
bananachipz
Drives: F30 Mineral Gray 335i
buy the //M Performance Suspension kit....
you're welcome
      01-30-2013, 03:47 PM   #20
stom_m3
Drives: Sequoia
Seen it? You seem to have it!! I just picked mine back up 10 minutes ago. Love it! Looks like you got the whole kit. I'd like to check out that rear diffuser.
      01-30-2013, 04:19 PM   #21
RyanC
RyanC's Avatar
Drives: 2012 M3 DCT
Is it possible to put in the M performance suspension if you have the adaptive suspension? Would that eliminate the adjustability?
      01-30-2013, 04:56 PM   #22
jamesems
as far as i know BMW has not released an adaptive version of their performance suspension. However, i have read that there will be a version available sometime. It's hearsay, nothing definitive but i think you'll see it eventually
Looks like you went with BMW Encinitas too..Work with service advisor Sean Puno and their Tech Ian. Mention James.
What part of town are you in? Im in Del Sur/Santaluz
