BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > F30 3-series Won’t Get Turbo 3-Cylinder N37 Engine. Bound for FWD 1-series Instead
      07-11-2011, 12:35 PM   #1
Jason
Administrator
Jason's Avatar
Drives: F80 M3
Post F30 3-series Won’t Get Turbo 3-Cylinder N37 Engine. Bound for FWD 1-series Instead
BIMMERPOST NEWS
23
COMMENTS
BMW's research and development head, Klaus Draeger, has confirmed that future BMWs will indeed utilize new turbocharged 3-cylinder gas and diesel engines. This begs the question which future models will receive these 3 cylinder motors. According to Draeger (via Autocar), the upcoming FWD 1-series models will receive the 1.5L turbo 3-cylinder and not the F30 3-series (at least not initially?)
“They are not a priority for the 3-series,” Draeger told Autocar last week. “We’ll start with the front-wheel drive architecture and more price-sensitive models.”
Instead, the smallest engine we expect to see for the F30 3-series in the US is the 245hp 2.0L turbo 4-cylinder N20 engine.
Draeger revealed that the petrol version of the engine, known internally as N37, has the potential to match the maximum 54bhp-per-cylinder rating of the firm’s recently introduced turbocharged 2.0-litre, four-cylinder N20. This suggests range-topping versions of the new triple will develop up to 160bhp.
The key to the new engine’s efficiency, says Draeger, is its
capacity-to-surface-area ratio,
which he describes as being better than any existing BMW
engine for thermal performance.
In a bid to dispel the idea that three-pot engines are used for cost-saving, Draeger said, “The three-cylinder engines are not cheap. They are every bit as hi-tech as our four and six-cylinder engines.”
We previously reported that this 3-cylinder engine range (gasoline and diesel) will receive the TwinPower Turbo treatment.
The TwinPower Turbo package combines a single twin-scroll turbocharger, direct injection and full variable valvetronic. It first debuted on the N55 motor in the 5-series GT in 2009 and most recently on the first 4-cylinder motor, with the 2.0L N20 gasoline engine in the X1 xDrive28i. The use of this technology allows for increased horsepower while decreasing CO2 emissions. As an example, the N20 outputs 245hp compared to just 156hp from the naturally aspirated version.
      07-11-2011, 01:08 PM   #2
esqu1re
esqu1re's Avatar
44
Drives: M Coupe
Don't know much about engine dynamics, but isn't a 3 cylinder inherently imbalanced?
///M Coupe: RPI Scoop, OE Strut, CDV, Volk RE30, SS Brake Lines, Stromung Exhaust
      07-11-2011, 01:16 PM   #3
ORIGIN M.
Drives: ///M
Balance shafts can keep it more than happy.
      07-11-2011, 01:31 PM   #4
v3.0si
v3.0si's Avatar
Drives: '08 Z4C 3.0si
it'll likely have a balance shaft similar to what benz uses in their v6's (272 motor). although, benz runs theirs down the valley, which isn't really possible on an I3... who knows what BMW might do?
| v3.0si | | '08 Z4Coupe 3.0si | BMW Aero | BMW Performance |
      07-11-2011, 01:33 PM   #5
KSERGEI-BY
KSERGEI-BY's Avatar
47
Drives: Skoda Kodiaq 2.0 tdi DCT
Someone said here - this 3 cyl "engine" will open the door to the low-buget ppl IMHO 3 cyl is ok for 2 weels only.
      07-11-2011, 01:42 PM   #6
mkoesel
Moderator
Drives: No BMW for now
Originally Posted by Jason View Post
Instead, the smallest engine we expect to see for the F30 3-series is the 245hp 2.0L turbo 4-cylinder N20 engine.
I guess you probably meant that comment with respect to the US, Jason.
Globally, I would be very surprised if we don't see a 320i with the lower output 184hp N20B20 recently confirmed for the Z4 20i and 520i. Additionally, I suspect some markets will get the two versions of the new smaller I4 that are slated for use in the F20 116i and 118i respectively. In fact, with the 1.6L I4 in the mix, it is no surprise that the three cylinder is not a priority yet since the 1.6L can cover that market for now.
By my math, the current N20B20 is so far capable of 60hp/cylinder. No?
I think the new I3 will introduce the new shared engine architecture which is said to yield almost 70hp per cylinder (0.5L standard cylinder displacement across the lineup).
      07-11-2011, 02:18 PM   #7
Wolf
Wolf's Avatar
Lebanon
228
Drives: on hold
I don't know but I think if you use all the balance shafts in the world, the engine will still vibrate.
Originally Posted by bimmerjph View Post
Originally Posted by SCOTT26 View Post
BMW have tapped into this by mirroring typical BMW dynamics and steering communication within the new UKL cars.
You mean massive body roll, a steering system that is not connected to the front wheels, and the engine note played through the speaker system?!?!?!?!
      07-11-2011, 03:44 PM   #8
SomeRandomer123
SomeRandomer123's Avatar
England
306
Originally Posted by blipit View Post
FWD = FAIL!!!!!!!!!!!!!!!!!!!!!!!!!!
1 "Life is too short for front wheel drive" - Sabine Schmitz whilst driving the E60 M5 around the Nurburgring.
Gone: 2006 BMW E60 520d SE 6MT
Gone: 2009 BMW E90-LCI 330d SE 6MT
Current: 2012 F30 328i Luxury 8AT
On Order: 2015 Audi A6 Avant Ultra, Black Edition (sorry!)
      07-11-2011, 04:06 PM   #9
and 1
winter mode
and 1's Avatar
Italy
62
Drives: 08 135i, 88 M3
1988 BMW M3  [0.00]
2008 135i  [7.50]
this
88 M3: BMWCCA J Sport
08 135: because streetcar
      07-11-2011, 06:28 PM   #10
Alchem
Drives: 335xi
Why do you guys care if BMW makes FWD? Don't buy that model. FWD will be in the new low cost models. You guys are acting like every model is going FWD.
      07-11-2011, 09:10 PM   #11
Alchem
Drives: 335xi
Because of the ads they use to run.
They look like dumbsh*ts.
Well times have changed. They are adapting to the needs of new markets especially in emerging economies.
      07-11-2011, 11:33 PM   #12
335_MI6
335_MI6's Avatar
115
Drives: 335xi
FWD= Failed at life
      07-12-2011, 01:50 AM   #13
Touring
Touring's Avatar
Norway
178
Drives: i3,E21,M2,E23, Skoda Kodiaq
The 160 hp 3-cylinder would be perfect engine-swap for my E21.
      07-12-2011, 03:55 AM   #14
ron_jeremy
ron_jeremy's Avatar
Norway
513
Drives: 13' F25 X3 20d & 16' i3
I thought this tread was about the new 3 sylinder engine.
Not FWD?
Oh well, i suppose BMW should rather give up, than follow EU regulations and other (stupid) CO commisions.
There is a need for such actions people, it doesn't mean you have to buy them though, but i can assure you, some will, and coming from BMW, these engines will sure be good, and most of all, others will follow.
It's not like BMW will be alone making 3 sylinder engines, and small FWD cars, look at A and B class from MB.
Rant over?
3 series: E30: 89 325i, E36: 92 325iC, 94 320iC, 96 320i Convertible, 94 320iaC, E46: 99 320ia, E90: 06 318i Le mans, E91: 07 318dt
5 series: E39: 97 520ia, 01 530Dat, E61: 09 520Dat
X series: E83 05 X3 2.0d, E84 10' X1 2.0 X-drive DA, F25 13' 2.0da X-drive.
      07-12-2011, 11:05 AM   #15
M340i Pride
Drives: 2020 BMW M340i
FWD made by a company such as BMW... its the principle of it that saddens me.
FWD cars isnt bad or anything but it will always underperform compared to RWD. law of physics is firm on that. for a purist car company such as BMW to do that... saddens me. ah the tragedy.
      07-12-2011, 07:56 PM   #16
Yogijet
British Virgin Islands
Drives: 2009 BMW 135i, Jet Black
Not FWD?
Rant over?
I agree with you and Alchem on this but you can rest assured that the rant will continue until we no longer have free speech for the masses. In the meantime, bring on the innovation, BMW!
BMW Performance Exhaust, Michelin Pilot Supersports F-225/40, R-255/35, BMW Performance Suspension, BMW Performance black kidneys, Quaife LSD, M3 rear sub-f bushings, M3 front control arm, rear guide rod and rear upper link kits, BMW Performance cross-drilled/slotted rotors, AFE Cold Air Intake.
      07-13-2011, 03:24 PM   #17
XC
XC's Avatar
Drives: BMW Z4 M Coupé
2010 135i  [0.00]
But... this might be the beginning of the end...
      07-14-2011, 04:04 AM   #18
NightVisitant
NightVisitant's Avatar
Drives: BMW F10 M-Sport 2011
^ Indeed
This doesn't make any sense, with the 3 series getting ever bigger, the 1 series was beginning to replace it in terms of being small compact sporty - but making it FWD immediately cuts off that progression, perhaps that is the thinking behind it - by giving the 1 series a step backwards in handling/driving, it keeps the 3 series on top...
Having said that, we must try to keep a little faith in BMW, we are after all, good fans - perhaps their decisions are for the best, only time will tell
      07-14-2011, 07:32 AM   #19
Pentium
Pentium's Avatar
Drives: BMW 335i
2011 BMW 335i  [0.00]
I don't like the idea of FWD with BMW, but looking to all what's going on to automarket they have a point maybe!
I can't resist the BMW drive, even the smallest 1 Series is something special...don't know what will look like with FWD!
160 bhp from 3 cylinder is very nice actually!
The Best Is Yet To Come!
E36 - E39 - E53 - E60 - E87 - E90
