01-21-2015, 02:55 PM | #1 |
Rep 101
Staggered X-Drive
Hello,
I have the 2013 335i x-drive M-sport. I am currently shopping for some 19" wheels. I am either sold on the new Vossens VPS-311 or Vorsteiner V-FF 103. Looking at these wheels I was wondering if it is fine to get staggered wheels for x-drive cars. I always thought and read in some places that it might not be good for the car to have different sized wheels for the front/rear. Also if you have any suggestions on wheel size/width/offset that would be great also. Any opinions and answers are welcome. Thank you. |
01-21-2015, 03:17 PM | #2 |
Rep 175
My E90 335xi had staggered's....Just use this formula and get very close to the same circumference.
Algebra (fun stuff): tire rating: A/B-C circumference=(C+(A*B)/2540*2) * 3.1415 What this is doing is taking your wheel diameter, C, adding the sidewall height, which is A*B (B is a ratio of tire width to sidewall) and converting it from mm to inches (with 2540) and *2 because you have sidewall on top and bottom, and of course we have pi. So, on my E90 335xi I had: 225/40-18 255/35-18 So my fronts were: 78.8096" in circumference And rear: 78.62408 So they were within 0.25% of each other. So those are pretty damn close IMO. At 19" and similiar setup, You're looking at: front: 225/35-19=79.168 rear: 255/30-19=78.611 delta~.7% 265/30-19=79.3538 delta~.25% Now, I'm pretty sure 255's are much more common, but I'd try and find 265's. |
01-21-2015, 03:24 PM | #4 |
Rep 175
The post just below this....he lists VMR wheels, with "beefy" tires:
http://f30.bimmerpost.com/forums/sho....php?t=1081833 Even has the offsets. One shot one kill. Those are nearly identicle circumferences: Delta of .077%...VERY small difference. Front: 235 35 19 80.03404134 Rear: 275 30 19 80.09588189 |
10-10-2015, 03:56 AM | #5 | |
BMW Fanatic
331
Rep 1,076
18 BMW M2 | ER DP | ER CP | Wagner Evo 2 Comp Intercooler | Aquamist HFS4 | BM3 | CSF Oil Cooler | AFE Drop-in Filter | Bilstein B16 PSS10 |
10-10-2015, 04:42 AM | #6 | |
Rep 5,140
But why do you want staggered tires on square 397 wheels? Just fit 245/45-18 square, then you also have the possibility to rotate the tires! |
10-10-2015, 05:49 AM | #7 |
Rep 31
No issue using a staggered setup. In Europe the xdrive msport models come standard with a staggered setup. By default this is 225/45R18 front 255/40R18 rear.
10-15-2015, 07:48 PM | #8 |
Rep 25,989
You can use a staggered setup with xDrive. You just want to make sure your rolling diameters are within 1% of each other. You can use this tool to check rather than having to do all the math yourself. Some of the more common sizes are 235/35 and 265/30 or 235/35 and 275/30. We normally recommend 19x8.5 ET35 in the front and 19x9.5 ET45 in the rear.
VMR|Wheels | 714.442.7916 |
sales@velocitymotoring.com | www.velocitymotoring.com | facebook | flickr | Instagram |
10-16-2015, 08:44 AM | #9 |
Rep 3,089
Thats a pretty conservative offset. Are you assuming the car is not lowered?
