11-22-2017, 11:28 AM | #1 |
Rep 134
Intercoolers
Hey guys. I tryed searching but couldnt find enough personal experiences with intercoolers. I eventually plan to go pure stage 2 turbos and was wondering which intercoolers everyone is using for this setup.
Will the VRFS race imtercooler be sufficent or the Wagner EVO 2 or Evolution Racewerks intercooler? Thanks |
11-22-2017, 04:51 PM | #3 |
Rep 1,499
What your IAT range above ambient before, during and after a pull?
11-22-2017, 09:34 PM | #4 | |
Rep 456
As far as during and after pulls, I reviewed several logs when running the standard Wagner and VRSF Race. According to data: - both FMICs dropped IATs below ambient - VRSF held lower IATs throughout the pulls and did not increase as more boost was produced (The Wagner however would heat soak and slightly increase IATs as more boost was produced) - I don't have enough data for "after pulls" as the JB4 is set to cancel logging once I'm off 90% petal. Hope this helps. |
11-23-2017, 12:26 AM | #5 |
Rep 190,777
VRSF race is a good choice for upgrade turbo
My favorite would be Wagner EVO II comp (its lighter and recovers temps faster than any other FMIC out there).
11-23-2017, 12:40 PM | #7 |
Father of Frankenfold
299
Rep 531
Drives: Yo daddy's 2014 X3 M Sport
I can tell you not to bother with a Phoenix. While better than stock, it still heat soaks and ramps IATs up 40* on pulls. It recovers decently, but it's not particularly efficient.
F25 X3 35i M Sport | Frankenfold 6662 | VRSF Race IC | FTP CP | BM3 tuned | XDI-35 HPFP | Stage 2 LPFP | Ethanol mixed | WMI | Oil cooler | xHP | X5/550i brakes
11-24-2017, 07:53 PM | #9 | |
Bright Sky
1164
Rep 922
Drives: BMW M235i (8AT)
Peter has quite a lot of experience and I trust his judgement (FD: He did my JB4 install/setup). He's always been a fan of the Wagner EVO2 and he also seems to like CSF's new intercooler!
BMW ///M235i (EBII) - BM3 (+TCU) - Wagner DP - ER CP - ER TIC CP - CSF FMIC - GFB DV+ - Pure Inlet - K&N Drop-in AF - MPE
Of all tyrannies, a tyranny sincerely exercised for the good of its victims may be the most oppressive. |
11-25-2017, 09:18 AM | #10 |
Rep 1,805
I got the dinan one, no complaints, easy install, looks clean.
However this was a couple years back, there might be better options on the market now.
2014 F30 335i / 2014 F31 328d / 2014 F22 m235i
2019 G05 5.0 / 2012 E70 X5 50i / 2007 X5 3.0is 2011 e93 M3 / 2009 E60 M5 / 2004 E46 M3 2017 Alpina B6 22 Ram Trx / 22 M5 CS |
Dinan_Rated169.50 |
11-27-2017, 12:43 PM | #11 | |
Rep 1,499
Something is not right here. It's physically impossible to cool charged air below ambient temps unless you are spraying meth or water. The FMIC is an air-to-air heat exchanger where the ambient air is used to cool the charged air.
11-27-2017, 12:48 PM | #12 |
DINAN SELLER
170
Rep 544
Dinan, best build quality and performance gains. Slick Separate air duct to pull air from bottom when needed as well as front and sides. Downside one of the more expensive IC’s on the market, worth it here, also running big turbo as well
Benefits of the Dinan High Performance Dual Core Intercooler: + Max gains of 15 HP and 13 lb-ft of torque @ 6250 RPM (greater gains and a wider power band can be achieved when paired with stage 3 DINANTRONICS) + Face area 240% larger than the stock intercooler setup for maximum cooling efficiency to deter heat soak. + Charge Air Pressure drop: 0.80 PSI (25% improvement over stock) + Charge Air Temperature drop: 155º F (11% improvement over stock) + Charge Air Temperature / Ambient Temperature Delta: 18º F @ 6250 RPM (60% improvement over stock) |
rphz70.00 |
11-27-2017, 12:53 PM | #13 |
DINAN SELLER
170
Rep 544
11-27-2017, 10:12 PM | #16 |
Rep 1,805
thats the only Dinan part I have.. running Pure Stage 2/BM3/pump 93 and required supporting mods for such
11-27-2017, 11:05 PM | #17 |
DINAN SELLER
170
Rep 544
11-29-2017, 05:47 PM | #18 |
3441
Rep 79,211
11-29-2017, 06:24 PM | #19 | |
Rep 206
11-30-2017, 01:28 PM | #20 | |
Rep 115,980
The Dinan FMIC definitely looks slick!! Mike |
Dinan_Rated169.50 |
12-01-2017, 12:13 PM | #21 | |
DINAN SELLER
170
Rep 544
12-11-2017, 08:08 PM | #22 |
Rep 75
Drives: e92 328xi / f30 335i m sport
Hello guys. So I just got the VRSF race intercooler and chargepipe. The intercooler did not come with the support brackets for the top like the ER does. For you guys with the VRSF, did yours come with the support brackets? If not, what did you do? Thanks.
