BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > AH3 BBK?
      02-21-2017, 06:11 PM   #1
TrustButVerify
Drives: 2017 X5M, 2013 335ih
AH3 BBK?
Any options for bigger brakes on the AH3? I have a good feeling the answer is no being that is has a regenerative braking system.
      02-21-2017, 08:53 PM   #2
afranke
Drives: 2013 ActiveHybrid 3
I'll let you know for sure this week when my rotors come in. I think it should be fine with just the rotors and calipers, as the stock rotors and caliper part numbers are listed for multiple cars:
http://www.realoem.com/bmw/enUS/show...diagId=34_1949
http://www.realoem.com/bmw/enUS/show...12#34116799469
As far as I'm aware, the only change the hybrid really adds is the torque converter and the battery (http://www.realoem.com/bmw/enUS/show...diagId=24_1354). The regeneration happens in the electric motor:
"This is really what the regen mode is all about. With the electronic throttle closed and the vehicle still moving, all of its kinetic energy can be captured to both slow the vehicle and recharge its battery. As the onboard computer signals the battery to stop sending electricity (via the controller relay) and start receiving it (through a charge controller), the M/G simultaneously stops receiving electricity for powering the vehicle and starts sending current back to the battery for charging."
http://alternativefuels.about.com/od...genbraking.htm
      02-21-2017, 09:03 PM   #3
afranke
Yeah, even the BMW retrofit is listed for the AH3, so really anything that fits the F30 in general should work: http://www.realoem.com/bmw/enUS/show...diagId=03_0108
2013 ActiveHybrid 3 (335ih) • N55 PWG • Meisterschaft GT catback • Wagner tuning catless DP and Stage 2 Evo Comp Intercooler • ER chargepipes • CTS intake • io2V3 O2 simulator • Pure Stage 2 turbo with high-flow inlet and DV upgrade • Fuel-It Stage 2 LPFP • JB4 ISO firmware • Fuel-It DIY PI Kit • bootmod3 •
      02-23-2017, 12:34 PM   #4
Lancelot
France
568
Drives: 2017 m550i
I have the M performance BBK, mounted by BMW dealer.
2017 M550i | Sophistograu
Previous cars: 2014 F30 ActiveHybrid 3 | 2012 f20 M135i
      03-23-2017, 01:31 AM   #5
Kabrich
Drives: '13 AH3 (335IH) 3F93 MSport
I added Brembo GT BBK and rotors to mine this past week.
      03-23-2017, 01:47 AM   #6
Lancelot
France
568
Drives: 2017 m550i
Pictures?
      03-24-2017, 07:17 PM   #7
Kabrich
Originally Posted by Lancelot View Post
Pictures?
Here they are with my SportContact 6 - probably the only SC6 on a BMW in the USA.
      03-25-2017, 12:34 AM   #8
Lancelot
France
568
Drives: 2017 m550i
Nice! How's the braking feel?
I like your wheels too, which ones are they?
      03-26-2017, 02:47 PM   #9
Kabrich
OEM 437m wheels.
Honestly, mushy - or not what I expected. I think I need to wait for everything to set properly or code for bigger rotors.
      03-27-2017, 12:36 AM   #10
Lancelot
France
568
Drives: 2017 m550i
Originally Posted by Kabrich View Post
OEM 437m wheels.
'Mushy' makes me think of two things
- Brake bleeding not done by the book: IIRC there is an ISTA procedure whereby bleeding is done with assistance of the ABS pump, if not done this way it can feel mushy, I've read several threads on the topic here
One here for instance, mentions DIY but I think many independent shops are also not applying this procedure.
http://f30.bimmerpost.com/forums/sho....php?t=1318401
- Coding: perhaps coding for M performance brakes can improve by telling the ABS that a bigger brake system is present, although that won't match exactly I guess it could be something.
Kabrich354.00
      03-28-2017, 10:51 PM   #11
Kabrich
They claim they were bleed twice.
No idea if by the book.
