11-16-2016, 05:35 PM | #1 |
Rep 1,894
Cold Air from Central Vents
Hi all,
Anyone experienced an issue where the central vents are not blowing hot air and the central dial (just below the hazard light button), is set between red and blue. The strange thing is when I switch on the front windscreen heater button, it pumps out lovely warm/hot air! Any tips would be appreciated. |
11-16-2016, 05:46 PM | #2 | |
Curmudgeon and Pedant
690
Rep 3,489
11-22-2016, 05:33 PM | #4 |
Rep 310
Does anyone know if there was a software update to cover the air con ?
My centre (and side) vents have very strange behaviour. You can be driving a while and everything will be fine. Temperature stable, then without a change to the level of light - i.e. it doesn't suddenly become sunny, the drivers vents will start blowing icy cold air. Then after a while, it will go back to normal and slightly warm air will come out and the passenger air will blow icy cold. I understand it is automatic A/C, but the air is so cold you have to close the middle vents. All my previous 4 BMW's didn't do this. And it is unrelated to the centre position of the blue red dial |
11-29-2016, 10:02 PM | #5 |
Rep 2,354
I have a similar issue. When I start the car up it sometimes blow A/C cold air even though the A/C is turned off (no green light) and the centre vents knob is on hot. Switch the climate control off/on solve the issue
(A Dane in China) |
kevinjt151.50 |
12-20-2016, 05:00 PM | #7 | |
Rep 131
01-14-2017, 01:34 AM | #8 |
Rep 499
The automatic climate control is a complete disaster.
I have to change the temp in four places
I don't think they could have implemented a worse system if they tried. As you stated, the AC comes on whenever it wants, despite having it off. Also, the temp in mine has gone haywire a few times -- I'll have it set to 67 in the winter and the automatic climate control system starts cranking out 90 degree heat. I just can't figure this thing out. Total fail. |
