BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > UK > Retrofitting lumbar support
      08-06-2017, 10:39 AM   #1
Dvr80
Drives: F31 335d Shadow Ed
I realise some have done this themselves but I'm not confident and don't really have the time so I'm looking for recommendations for a company that could carry this out from anyone that's had this done.
      08-06-2017, 04:51 PM   #2
Nobby Clark
Nobby Clark's Avatar
446
Drives: F36 430d xDrive M Sport
It couldn't be a simpler mod. Pull the plastic seat back down and off. Insert the plastic lumbar bag behind the wire seat frame. Re fit seat back. Literally a 5 minute job.
I've even got spare replacement plastic pins that retain the seat back if you PM me as you will damage them removing the seat back.
      08-06-2017, 05:04 PM   #3
CraigJ
CraigJ's Avatar
Drives: F30 Msport 20i Xdrive
Hi i'd like to do this mod, where did you get the plastic lumbar bag from?
320i Msport in MG with 400M alloys, black Dakota leather, Pro nav ,Auto box, Xdrive, Power fold mirrors.
      08-06-2017, 05:15 PM   #4
Nobby Clark
446
Honestly can't remember. It was a race parts company of some kind. If you search the forum, then google, I'm sure something will come up.
      08-06-2017, 06:41 PM   #5
37psi
37psi's Avatar
Drives: F32 - 435d X Drive M Sport AT
So does it come with the four way control switch and then you code it? What about the seat bolsters?
      08-06-2017, 07:44 PM   #6
Watsey
No, it's a much simpler mid. Basically a strong pvc bladder, rubber tube and rubber bulb to inflate the bladder by hand. There's a release valve to deflate it.
Purely lumbar support; no bolsters.
Current : F31 330sD, DMS remap, Ohlins Road & Track, Vorshlag adjustable top mounts, SuperPro front caster adjustable bushes, Bird's ARBs, MPSS, Quaife LSD, StopTech BBK.
Previous : E91 330D M Sport; E91 330D SE; E46 320D M Sport Touring; E46 330D M Sport Saloon
      08-07-2017, 01:42 AM   #7
37psi
37psi's Avatar
So you have to set the bladder in place?
As on the electronic version you can move the bladder up and down.
      08-07-2017, 08:11 AM   #8
Mattt1
Drives: 335d xDrive
Yes you place the bladder and it remains fixed there - it's a 15 minute job to do (faster if you wanted) and a lot cheaper than retrofitting the OEM (but not quite as good)
      08-07-2017, 03:53 PM   #9
Dvr80
Seems much easier than doing a genuine retrofit!
I've even started searching breakers for a replacement seat as I figured they might cut a deal with mine as a part ex but nothing around at the moment.
Will have a look around for a new bladder
      08-07-2017, 04:49 PM   #10
225
Drives: 340i
I was apprehensive but it is very simple and well worth it.
      08-07-2017, 05:57 PM   #11
dbramley
320d M-Sport
England
50
Drives: BMW 320si
I would love to retrofit electric adjustable seats, not bothered about memory settings. Anyone know a place that can do this? Only really bothered about drivers seat too.
      08-08-2017, 04:04 AM   #12
Alscoob
Alscoob's Avatar
Drives: F31 330d M sport+
Here you go......
https://www.corbeau-seats.com/access...umbar-support/
Easy job
      08-08-2017, 05:10 AM   #13
Nobby Clark
446
Originally Posted by Alscoob View Post
That's the one.
Remember and declare the mod on your insurance
      08-08-2017, 12:36 PM   #14
sensible
sensible's Avatar
110
Drives: BMW 320i M-Sport
I have bought the inflatable bag but not fitted it yet. I had researched how to do it. You also need a plastic A4 folder cover and put that between the springs and the bladder. That way, when you inflate the bladder it pushes against the plastic folder cover and inflates into your back rather than inflating through the springs...if you get what I mean.
See these pictures. The bladder would go behind it like it does with the electrically operated ones. The flaps on the card hold it in place on the springs. I have just got to work out how to attach the bladder to the plastic card so that it doesn't move. There is a rim around the bladder with holes in that could be used to secure it to the card by some means. You would only secure one side though (like the original electric one is only secured to the card at the top and hangs down)
      08-08-2017, 04:06 PM   #15
Alscoob
Alscoob's Avatar
Just to say the F30 seat back when uncovered does not look like that, but the principle is spot on.
      08-08-2017, 06:17 PM   #16
sensible
sensible's Avatar
110
Yes I know it is not an F30 seat as it is just an internet picture but you get the idea.
      08-15-2017, 08:28 AM   #17
Dvr80
Fitted in my m140i in under 10 minutes - so easy and for 39 a great modification (undeclared to insurer haha)
      08-15-2017, 03:31 PM   #18
sensible
sensible's Avatar
110
Did you do it with a backing card or did you just put the infatable bag behind the springs? If yoy did, did you secure the bag to the card? I haven't got round to doing mine yet so just wondering.
      08-15-2017, 05:00 PM   #19
Dvr80
No backing card, just inserted behind the springs and secured using a couple of mini cable ties to hold in position
      08-15-2017, 08:47 PM   #20
Imperial March
Drives: 2014 328i xDrive
This is really interesting. Is it available in the states and can it be used with heated seats?
      08-16-2017, 11:10 AM   #21
Alscoob
Alscoob's Avatar
Yip fitted it with my heated seats no problem. Think that you could just find a Corbeau seat dealer & they should be able to supply or just try https://www.corbeau-seats.com/ they do international shipping.
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
