11-29-2015, 01:31 AM | #67 |
Rep 236
So, is this a design flaw (length) in the B8's? Even though they claim to be designed for pairing with lowering springs? Does it happen only under extreme conditions (eg. Road course) and during the odd, freak accident of running into a giant pot-hope? I'm awaiting a reply from my local distributor but I expect him to tell me Bilstein denies anything is wrong...
I just got some H&R Sports (ie. relatively conservative drop) and was about to pull trigger on some B8's for my 335i XDrive, so seeing this thread is bad news! What other shock options do we have to go with something like the H&R Sport Springs? Thx! Fred |
11-29-2015, 02:40 AM | #68 | |
Rep 647
11-30-2015, 02:34 AM | #69 | |
Rep 236
Fred |
11-30-2015, 06:09 AM | #70 | |
Rep 3,943
11-30-2015, 01:45 PM | #71 | |
Rep 647
We're notorious for blowing charge pipes, ones "real engineers spent countless hours designing." Driveway mechanics aren't so bad after all. |
11-30-2015, 03:14 PM | #72 | |
Rep 3,943
I'm waiting for driveway mechanics to tell me I should just "eyeball" my alignment specs. |
11-30-2015, 04:47 PM | #73 |
Rep 3,089
I am as guilty as anyone of being a "driveway mechanic". I actually do have my mechanical engineering degree and yes I do believe at times my analysis and modifications are better because I am not constrained by price points, timelines, or the myriad of other compromises "real engineers" are forced to accept in the corporate environment.
That being said, what happened in this situation could simply be a matter of product failure due to a defect in the material or manufacturing process or both. It does happen and could have happened regardless of what the OP did or did not do to his suspension. My point is, it is not fair to simply say the part failed because of what the OP did. An analysis needs to be done of the failure and the part itself before we can definitively say the "real engineers" are not fault.
12-01-2015, 06:08 AM | #74 | ||
Rep 3,943
The "real engineers" have designed a system (OE suspension) that has not yet failed in such a spectacular way as the "amateur engineers" that are piecing together suspension components. It's a matter of credibility. Are we to believe that the "real engineers" messed up when their design has so far been show to work OR is it more likely that our "amateur engineers" didn't take into account the actual design of each component they replaced and how they work in tandem with each other? I think it's really on the "amateur engineers" to prove that their design should work and the failure is a design flaw with BMW's top hat design. So far, not many with premium suspension kits (Bilstein PSS10 coilovers, Ohlins Road & Track, KW, BMW M Performance Suspension, etc.) have reported the same failure. Has either Bilstein or H&R said that their spring/shock works well with the other? http://www.turnermotorsport.com/p-19...28i-m235i.aspx Quote:
12-01-2015, 08:18 AM | #75 |
Rep 176
12-20-2015, 07:21 PM | #76 |
Rep 236
So, guys, I thought it was clear that I'd get some Bilstein B8's to go with the H&R Sport Springs that I already have (this combo has been raved about by so many forum members)...what are my shock options if I don't go with the B8's?
No offence to my local Bilstein distributor, but he gave me the expected "I've heard of no complaints" type of answer when I asked him about the issue with the B8's paired with H&R Sports and the F30 front tophats. I still don't understand why we have not heard (at all?) about other aftermarket shocks or coilovers having same outcome on the tophats. It's just a Bilstein thing?? Fred |
12-21-2015, 01:55 AM | #77 | |
Rep 31
12-21-2015, 02:03 AM | #78 |
Rep 1
12-21-2015, 11:14 AM | #79 | |
Rep 3,943
Has anyone with Bilsteins + OE springs experienced the same issue? If not, then I'm not inclined to say it's Bilstein's problem. Bilstein can't control what type of lowering springs the customer uses. |
12-25-2015, 11:01 AM | #81 |
Rep 3,943
12-25-2015, 11:12 AM | #82 |
Rep 3,089
Was it a massive pothole? I wonder if the stock setup would have also broke the top hat??? I know its impossible to say without a proper controlled test.
12-25-2015, 11:50 AM | #83 |
Rep 3,943
01-12-2016, 09:05 AM | #84 |
Rep 69
I went over TWO (yes wtf TWO) mother flipping pot holes (looked to be about 15cm + deep with a 20cm diameter) with my 20" on stock suspension (non-adaptive) this was a few weeks ago. so far nothing wrong AT ALL with the suspension. no noise no nothing, everything seems fine. however when i ran over those pot holes it felt like my car was going to fall apart
01-15-2016, 02:44 AM | #85 |
Rep 236
Are the B8's actually shorter than the factory shocks? (I have a 335i xDrive.)
If so, how come we're seeing this issue with the B8's and not the OEM? |
06-30-2016, 10:05 AM | #86 |
Rep 241
strut mount
Reviving a dead thread.
Last year I replaced my left strut mount after hitting a pot hot. Suspension- B14's Last night I destroyed my passenger side. $173 at Schomp BMW Highlands ranch.. or $117 https://www.ecstuning.com/BMW-F30-32...ion/ES2664936/ or $115 http://www.rockauto.com/en/catalog/b...ut+mount,7600? Mfg Part # 31306863135 ECS Part # ES#2664936
Charlie Vu
2013 328iX Melb RED- JB4 - AFE 5R Intake - B14 Bilstein - Morimoto H1 Projectors and LED Angel eyes- Morimoto HD Elite 50w 5500k H.I.D. |
06-30-2016, 11:21 AM | #87 |
Rep 31
It has been a year since I have Eibach Pro Kit (E10-20-031-06-22) + bilstein B8 with 20" wheels now and they work great. I NEVER heard any hit from my suspension whereas with my first combination of HR + Bilstein B8 it was happening everyday including destroyed strut mount top hat. Go for it!
06-30-2016, 12:43 PM | #88 | |
Rep 66
