11-24-2014, 01:30 PM | #1 |
Rep 32,881
Brake squeal! [Solved]
Since fitting my 400M winter wheels I've had brake squeal, when coming to a stop or slowing to a near stop they squeal for the last couple of seconds. I had no squeal at all with my 403M's!
I know quite a few people have complained about this in the past, but it seems to not be around so much since the M Sport plus pack came out, which further suggests that it's because of the 400M's. Has anyone else noticed this since putting your winter wheels on? Last edited by teaston; 11-25-2014 at 05:24 AM.. |
11-24-2014, 03:08 PM | #5 |
Rep 2,511
8500 miles on summers, 400 miles so far on winters.
Squeal is surely friction induced vibrations. Could it be something simple like some grit knocked under pad or possible different wheel bolt tensions leading to a slightly different alignment of the rotor?
Driving i4 M50 (G26)
Previous 340i Touring MSport (F31) |
11-24-2014, 03:12 PM | #7 |
Rep 32,881
Could be worth trying different torques. I've done them to the recommended 120nm, but the summer wheels were done really tight from the factory, I had to get the breaker bar out for some of the bolts!
11-24-2014, 03:18 PM | #8 | |
Rep 2,511
I needed I 2' breaker bar and my weight to undo my wheel bolts. However, 140Nm was easy to apply with a 2' torque wrench. Highlandpete and Brigand recommended the 5 point star torquing technique at 140Nm. Basically, number the bolts 1-5 clockwise and tighten them 1,3,5,2,4. Evenly torques up the wheel.
11-24-2014, 04:09 PM | #11 |
Supreme Being
1804
Rep 5,425
My brakes started squealing again over the last couple of days - I think it's the weather. Planning a couple of heavy braking sessions tomorrow, that stops it every time.
Current: F90 M5 Competition
Gone: F80 M3 Competition Pack / M135i / F15 X5 M50d / Saab 9-5 Aero HOT / F30 335d xDrive M Sport / E92 LCI 320d M Sport / E46 320d M Sport Touring / E46 318i Touring |
11-24-2014, 08:34 PM | #14 |
Rep 2,612
Just stand on the bastards, that'll sort it
Gone: 2006 BMW E60 520d SE 6MT Gone: 2009 BMW E90-LCI 330d SE 6MT Current: 2012 F30 328i Luxury 8AT On Order: 2015 Audi A6 Avant Ultra, Black Edition (sorry!) |
11-25-2014, 03:38 AM | #15 | |
Rep 32,881
11-25-2014, 06:26 AM | #17 |
Stormtrooper
170
Rep 806
A couple of years ago on my F30 I used to have 'brake squeal'.
It was a brake disc steel weather shield which had worked loose and was rubbing on the disc. Only seemed to happen at low speeds when braking. |
11-25-2014, 09:58 AM | #18 | |
Rep 2,511
I wonder how many BMW technician man hours have been spent on this?...
11-25-2014, 10:15 AM | #19 | ||
Rep 32,881
Yep bet they would try all sorts and still not fix it! |
11-25-2014, 12:04 PM | #20 | |
Rep 20,651
Then road test. Can't imagine it has changed since Adam was a lad. One big issue of people not putting wheels on correctly, as in tightening up incorrectly is warped disks, noisy brakes etc. I have seen mates just tightening them up as if a clock face. |
11-25-2014, 12:12 PM | #21 | |
Rep 32,881
