BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > [HELP!] Flat Tyre Monitor (RPA) failure [Error Code: 48070C]
      05-06-2019, 10:39 PM   #1
lawrencedchan
Drives: F30 316i (2013)
Exclamation [HELP!] Flat Tyre Monitor (RPA) failure [Error Code: 48070C]
The Flat Tyre Monitor (RPA) failure just appeared on my iDrive screen this morning when I started the car.
I read the code with ISTA+ / Rheingold and read the code "48070C" with a description of "Tyre failure indicator: Data implausible."
I have read posts about changing the ABS sensor behind the brake discs could solve the problem. However, I don't know which one to change.
  • Has anyone encountered this problem before?
  • Does anyone have a complete list of BMW error codes that I could take reference of?
  • Is it really the ABS's problem?
  • If so, how do I find out exactly which ABS sensor is faulty?
  • Or what solutions are there?
Vehicle Information:
Year: 2013
Model: 316iA (F30)
      03-31-2020, 01:10 AM   #2
lawrencedchan
anyone?
      04-21-2023, 10:55 AM   #3
AndyLivesey17
Drives: F30 335d 2016
Hi
I had a tpms failure. A local garage was luckily able to check the sensors were signalling. I believed it to bw the TPMS received but he couldnt tell me where it was. After a bit of research it pointed to under the car but my F30 2016 335d has its TPMS sensor located on the parcel shelf. You have to remove the rear seat side bolsters and pull out the pin-plug type fasteners and for the shelf (dropping down therear seat backs) then pull the fasteners lift the shelf careful and there are two modules. The smaller module is the TPMS receiver.
Old part number 9397846-01
New part number 61357928663
48070c, abs, dsc, error, failure, flat tyre, ista, rheingold, rpa, wheel
